8th September 2019, 16:01 | #17301 | Link |
I have already copied the error log above, at the bottom of page 865.
I encode into x265, two passes, and always encode multichannel lossless master audio tracks into 640k AC3. It's very frustrating getting that kind of an error at the end of 10:34 hours of work. This is the third file on which I am getting that error. Apparently the audio encoder does not encode DTS-MA track into AC3, which is why mkvmerge cannot find that track. Yes, I have checked the job folder each time, and there has never been an 'Encoded_Audio_1.ac3' file in the folder each time I get this error. If Ripbot had not immediately deleted the encoded video, then I would have encoded and muxed the audio track myself in cases of such errors. Atak, would you please consider that option: leave the encoded video intact in the job folder, and delete that only when all the temporary files are deleted? Such a simple option can save hours and hours of work going to waste in case of an error such as the one I posted above, and also in cases where the error is 'video.265 could not be opened.' (I used to get that sometimes in the past, not anymore). Please leave the encoded video intact in the job folder for the file being encoded, for a user to delete as and when they please. Last edited by lemaireus; 8th September 2019 at 16:04. |
8th September 2019, 21:25 | #17305 | Link |
Cosmetic Change. Can the text in the DE window be breaked into 2 lines or can the window be enlarged. As some of the text is truncated until I resize the column on every DE start.
https://imgur.com/YMFB3tb |
9th September 2019, 08:59 | #17306 | Link |
Thank you, Slalom. The question for a relative novice with cmd is 'how'?
May I assume that by 'chunks folder' you mean the job folder, thus, for example, 'job1'? How to I run 'CombineAllChunks.cmd' in that folder. A run down in three to four steps will be very helpful, and much appreciated. Thanks a lot for what I hope will soon become a working suggestion. |
9th September 2019, 12:00 | #17308 | Link |
9th September 2019, 16:14 | #17309 | Link |
Slalom, I did a bit of work on your suggestion, and there is an issue. I think you are working with the assumption that I am using distributed encoding. I am not. I am encoding my video on the one machine I have.
Atak, would you please consider the option of leaving the encoded video intact in the job folder, and delete that only when all the temporary files are deliberately deleted by a user? Such a simple option can save hours and hours of work from going to waste in case of an audio or video muxing error (Encoded_Audio_1.ac3 cannot be opened, or video.265 cannot be opened). Here are references back to my previous two posts on the issue, with the first showing the error log: https://forum.doom9.org/showthread.p...32#post1884332 https://forum.doom9.org/showthread.p...33#post1884333 Last edited by lemaireus; 9th September 2019 at 20:27. |
12th September 2019, 15:43 | #17313 | Link |
This is becoming routine, and therefore very, very frustrating. Got the error once again today; each time I have to encode DTS/DTS-MA audio into AC3, at the end of a two-pass encode I get the message:
Error: The file 'E:\Temp\RipBot264temp\job2\Encoded_Audio_1.ac3' could not be opened for reading: open file error. I can copy the entire log file, if you like. Atak, the solution I have suggested is really a straightforward one, even if it takes time writing some fresh code, but it will save a lot of people a lot of frustration if they could simply pick up the encoded video and mux is manually in case of these errors, rather than having to do the entire encode from scratch. Please allow Ripbot to leave the encoded video in the job folder, till a user deletes that job folder manually. That is all it will take to save hours and hours of encoding from being flushed down the drain. Keeping my fingers crossed for a positive response from you. |
12th September 2019, 16:19 | #17314 | Link | ||
ByteShare
Does it happen consistently on the same source, aka if you ran a sample that had an issue again and again does it happen each time? |
12th September 2019, 18:25 | #17315 | Link | |
The issue has been coming up since the move to LSMASH. I have had the error thrice since that shift, with three difference sources. Common to these three sources was a DTS audio track: lossless DTS-MA tracks in two sources, and 1504k DTS track in the third source. I haven't yet tried converting .thd audio. Will give that a run through and post an update. I shall do a thorough test tomorrow of samples with three different kinds of audios: DTS-MA, DTS, and TrueHD. Shall post the results after that, and will upload a sample in case that is necessary for analysis. More tomorrow. Desperately looking for a solution to this because the problem is intensely frustrating: it ruins the encode right at the end of two passes, when it's time to mux the audio-video streams. Last edited by lemaireus; 12th September 2019 at 18:29. |
13th September 2019, 07:48 | #17317 | Link | |
13th September 2019, 10:25 | #17320 | Link | |
(Not included in ripbot) fixed vc1 decoding and that random skips in avc and hevc. Just test your files in my tool seektester to see what i mean.
