7th October 2007, 21:38 | #22 | Link | |
Errant Knight
@Dark Shikari
Thank you,@squid_80
8th October 2007, 01:28 | #23 | Link |
I'm not good in avisynth, but I made a small test on a VOB source.
In the first 177 frames (the duration of a movie scene), the filter is working. At frame 178 and after this frame when the action of the movie is changed, the filter is not working anymore. Screenshots: Frame 177 http://i23.tinypic.com/10z7q85.jpg http://i22.tinypic.com/if0kyu.jpg Frame 178 http://i20.tinypic.com/1231p4x.jpg http://i22.tinypic.com/28kuhpc.jpg The first screenshot from 177 and 178 is the original. enjoy, Mtz |
8th October 2007, 02:05 | #24 | Link | |
x264 developer
8th October 2007, 03:48 | #25 | Link | |
Richard |
8th October 2007, 04:02 | #26 | Link | |
If anyone is still having problems install the Visual Studio 2005 SP1 Redistributable Package. |
8th October 2007, 04:06 | #27 | Link |
x264 developer
Yup, there is a MAJOR bug in the current version that drastically decreases its capability. I have a working version right now and I'm recording bitrate decreases of over 30% in some cases, and on longer clips also (the bug caused anything other than short clips to end up in uselessness). Updated version will be uploaded soon.
8th October 2007, 05:18 | #28 | Link |
x264 developer
Results on Cruncher's source material, settings 4-25-10-true, 2484 frames, 1920x800, at CRF 18:
Without GrainOptimizer: 18301kbps SSIM: 0.961 With GrainOptimizer: 13970kbps SSIM: 0.959 This is with the new, fixed version. Uploaded and fixed |
8th October 2007, 05:57 | #29 | Link |
Works great, the 4,25,10 setting is much more effective, or seems to be, than the default. The strength of 25 actually resulted in a smaller file size than that if it were set to 50! (only slight, 4kb on the clip I used but thats still significant). I did find a few other things, although this is with only testing on that one 30 second segment of video...
- It does not work well with other noise reducers. I tried a clip with a couple of different types, enabled and disabled, and with the grainoptimise above and below them. In all cases the grainoptimiser by itself seemed to be better... and resulted in a smaller file. The actualy quality would be better than the combined settings unless the source is chronic. - The optimiser HAS to be run before the resize filter, not after. On the test clip I used having it before the resize filter increased its effectiveness close to 100 percent over that of when its placed after the resizer (its twice as effective if placed before). The clip Dark Shikari used for his test wasn't resized (from what I can tell), and hence he got his 30 percent effectiveness. I got 15 percent reduction with the filter right after the resizer (spline64resize) and 30 percent right before the resizer! - Its quite fast, faster than most other noise reducers I've seen. Once optimised it will likely to be one of the fastest available! Last edited by burfadel; 8th October 2007 at 05:59. Reason: Correction |
8th October 2007, 06:18 | #30 | Link | |
x264 developer
8th October 2007, 15:24 | #32 | Link | |
x264 developer
Edit: Ah yes, I see the slight horizontal lines... I would suggest you use slightly weaker settings. Last edited by Dark Shikari; 8th October 2007 at 15:28. |
8th October 2007, 15:29 | #33 | Link |
x264 Tester
first example the background wall, left of johnny's shoulder.
also there are 4x4 blocks during motion scenes, do you want a shot of it as well? EDIT: oh, the images are from the avs-script, before encoding Last edited by ToS_Maverick; 8th October 2007 at 15:35. |
8th October 2007, 17:55 | #36 | Link |
Also bad encodes with the file from attachment. I uploaded the file to test yourself your plugin because I don't want to post here too many screenshots. On this source I think xvid encode will look better than x264 with or without grainoptimizer.
The vob is here. enjoy, Mtz |
8th October 2007, 18:40 | #39 | Link |
Testeur de codecs
Encoder like VC1 PEP or Cinevision encoder use particular HVS masking filter for grain: spatial/temporal filtering in dark area.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
8th October 2007, 19:04 | #40 | Link |
x264 Tester
@Dark Shikari:
here is a still active link to the source. as Sagittaire suggested, you could include something like that to x264, so that x264 behaves like XviD with grain, if somebody is interested in such behaviour. maybe the more you compress, the less random the grain gets. |
