Old 28th April 2009, 18:37   #2061  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
Originally Posted by Balthazar2k4 View Post
... I suspect my problem stems from the fact that FFDshow will not load in Win7...
FFDshow works just fine in windows 7 x64.
Here it is decoding 1920x1080 VC1:
RunningSkittle is offline
Old 28th April 2009, 20:37   #2062  |  Link
Balthazar2k4
Have you experienced any problems converting VC-1 material with either MeGUI, RipBot264, or HDConverToX? I can't get any of them to do it and yet they all work fine under Vista x64...
Could it be a Haali Media Splitter problem?
Balthazar2k4 is offline
Old 28th April 2009, 22:53   #2063  |  Link
RunningSkittle
Skittle
directshowsource works
Old 29th April 2009, 00:10   #2064  |  Link
Balthazar2k4
I can't figure out the problem to save my life. I installed a fresh copy of Win7 x64 build 7100. I turned off UAC. I installed ffdshow build 2913, haali media splitter, and AviSynth 2.5.8. I opened RipBot264 as an admin and proceeded to demux an m2ts containing VC-1. At the end of the demux, MPC pops up and tells me the graph filter has timed out. This happens with every VC-1 title I have tried. Anything else works great....
When I try and playback video via MPC Home Cinema, ffdshow does not show in the system tray and does not show it is doing anyting in the info & cpu dialog box under video decoder configuration.
I have tried setting ffdshow VC-1 to WMV9 and libavcodec and neither work.
HELP! This is driving me mad....
Old 29th April 2009, 00:55   #2065  |  Link
Balthazar2k4
Also, when I try and load the extracted stream into MeGUI, I receive the following error:
AviSynth Script Error
DirectShowSource: Timeout waiting for graph to start.
I just can't get ffdshow to play nice. I have even tried the x64 version, but predictably that did not work either.
Old 29th April 2009, 19:46   #2066  |  Link
DexterLab23
Help me understand something:
I ripped a serial, and have a file: "VTS_01_1 T80 1_0ch 192Kbps DELAY -8ms.ac3"
megui puts automatically the delay: "-8"
and inside the "VTS_01 - Stream Information.txt" file is written "Delay: -88ms"
Which is to be believed ? Which one to put inside megui ? -8 or -88 ?
P.S. You guys didn't answered my previous question.
DexterLab23 is offline
Old 29th April 2009, 20:17   #2067  |  Link
nurbs
a) Kurtnoise answered your previous post and I wrote a little longer explaination, you just didn't bother to read it.
b) You believe the -8ms, because that's what dgindex says.
nurbs is offline
Old 29th April 2009, 22:51   #2068  |  Link
onesloth
...but I am really stumped on VC-1.
Do you have an NVidia card? DGVC1DecNV should work.
onesloth is offline
Old 30th April 2009, 09:57   #2069  |  Link
DexterLab23
Thank you Kurtnoise, nurbs.
I understand it. I will try and post here if the audio is out of sync or not.
I am sorry, you are right, next time I will read more carefully.
Old 30th April 2009, 11:26   #2070  |  Link
DexterLab23
It's MeGUI also available for linux ?
Old 30th April 2009, 12:12   #2071  |  Link
deets
add Device Types to the Adaptive & Manual Muxers. Now, we can force either iPod, iPhone, ISMA or PSP output when we select MP4 Muxer.
what difference does this make if you do or dont select PSP as the device type?
deets is offline
Old 30th April 2009, 14:09   #2072  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
@DexterLab23: nope, or at least, not yet.
@deets: the difference is the file wont play on that device if the option is not selected.
Sharktooth is offline
Old 30th April 2009, 14:28   #2073  |  Link
DexterLab23
b) was wrong option/value, the true/corect value was -88
@Sharktooth, Please put two options in megui where can it read the audio delay.
A. In the "*Stream Information.txt", correct.
B. In the name of the audio that is created during after DGIndex processed audio file name, ex. "VTS_01_1 T80 1_0ch 192Kbps DELAY -8ms.ac3"
Also I should mention that the clip was a short one, 00:07:08, but I think if the audio was wrong (-88 ms), it should be completely desynced.
Old 1st May 2009, 13:33   #2074  |  Link
turbojet
Any chance of an option to not make .backup files when updating?
Out of curiousity are they ever used by the program anyhow?
turbojet is offline
Old 1st May 2009, 16:09   #2075  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
no...this is not used. There is a bug or something like that because such files must be deleted.
@DexterLab23: then, extract your audio stream with DVDDecrypter instead...
Kurtnoise is offline
Old 3rd May 2009, 09:35   #2076  |  Link
Ryu77
Ryu77's Avatar
Recently dgavcindex was added to the MeGUI tools folder... However, the version used is 1.0.1. I am wondering is there any reason why the newer 1.0.9 version isn't used?
I actually copied the newer version and .dll into the appropriate folders and eventually MeGUI updated back the older version.
Ryu77 is offline
Old 3rd May 2009, 14:18   #2077  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i already said ill update it as soon as i get home
Old 4th May 2009, 09:52   #2078  |  Link
Ryu77
Ryu77's Avatar
Was this directed at my post? If it was, I can't see when did you state (in the last 3 days) anything to do with updating dgavcindex?
Ryu77 is offline
Old 4th May 2009, 15:03   #2079  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
yes, it was directed to you... http://forum.doom9.org/showthread.ph...53#post1279853
and no, im still not at home.
Old 4th May 2009, 15:11   #2080  |  Link
avdw
Banned
If you get home, will you take your medications first ?
avdw is offline
