13th November 2009, 13:05 | #2323 | Link |
Hi all. I'm new here and using me gui for about 1,5 month now. I like the program, very easy to use. But I made a clean installation with windows 7 x64(from vista x64). I installed the latest avisynth, me gui, k-lite coedec pack(5.4.4). I updated megui with the auto-update function.
The first problem I got was when i wanted to convert a h.264 blu-ray rip to a .mkv file. I used the dxva-hd-insane profile and adjusted the bitrate to 12100 kbs, no other changed to this profile. I got the first error saying it couldn't use the " --rc-lookahead 40" option . Never had this before with the original x264.exe, but I downloaded the newest x264.exe from x264.nl and replaced it. It worked, which before on my old vista installation wouldn't work. The other side was that the encoding now took a lot more time(10 hours for the first step on a intel E8200 @ 3.2 GHz), and i got a large mbtree file, while the option in the profile stated " --no-mbtree". Ok, it encoded, and even the colors of the .mkv file look more like the original blu-ray then before with the other 'olde' version of x264.exe. An other problem is when I try to open a blu-ray rip which is encoded with WVC1 or the older MPG2 with the AVS script creator. I got the error "Avisynth script error: DirectShowSource: Timeout waiting for graph to start.". If I remember good I also had problems opening WVC1 sources on the old installation with vista. At K-Lite codec pack I ran the program "Preferred DirectShow Filter Tweakers for Windows 7" to change some 32-bit directshow filters from microsoft to ffdshow, but no result. I have a other machine running windows 2003 server x64 with megui, k-lite 5.2, avisynth. And tried to openen the WVC1 and MPG2 sources but on this machine I don't got any problems. So are there other people having problems with Windows 7? Or are there some known problems with windows 7(x64)? Kind regards, |
13th November 2009, 17:56 | #2325 | Link | |
Maybe the author doesn't have that much time to keep it updated as frequently as before. As long as he/she will update it once in a while i'm happy |
17th November 2009, 14:31 | #2326 | Link |
I'm a little bit further with one problem, encoding orginal blu-ray with WVC1 to x264. I used the program GraphStudio, http://blog.monogram.sk/janos/tools/...m-graphstudio/ , to see the links that are used to render the video. On my Windows 7 x64 machine the WVC1 blu-ray is rendered thru the 'WMVideo Decoder DMO', while on my Windows 2003 x64 is is rendered thru 'ffdshow Video Decoder'. I think here's the problem why Avisynth isn't able to open the WVC1 source. Anyone have idea's to change this of have a solution for this? It isn't possible in the Win7DSFilterTweaker where i can only choose Microsoft..
17th November 2009, 23:33 | #2327 | Link | |
Unregistered User
Especially check the core current and update version: (image attachment pending approval)
avi + m2t -> Vdub + DGIndex -> AE CS3 -> x264 -> Hell On Earth Woop, woop! That's the sound of the police! |
18th November 2009, 12:10 | #2328 | Link | |
Site: http://www.sf.net/projects/megui Direct link: http://downloads.sourceforge.net/pro...se_mirror=garr Mirror: http://sourceforge.net/settings/mirr...1056-setup.exe Else send me a private message with your email and i can email it to you if you want. Edit: at another megui thread i red that people are using v1057, don't know where to get that one, gonna ask them, post it here later. http://forum.doom9.org/showthread.php?t=105920&page=251 Last edited by rudiev; 18th November 2009 at 12:17. |
18th November 2009, 12:47 | #2329 | Link |
Unregistered User
Thanks, that's indeed the one I found and am using.
I don't know why the image isn't approved yet so I guess you cannot see it, but it sais in the update dialog: Core Existing Version: 0.3.1.10.56 Core Latest Version: 0.3.1.10.51 So if I update, I am back to the 'broken' version, even though this one seems to have the same problem. If I remove settings.xml and autoupdate.xml, it sais nothing for Existing Version, but after update it is back to the way it is now. So I don't have a connection problem and I've downloaded the new version just fine, but there's simply no change in the dead updates. It's like the 'bad update server' is hardcoded in the registry and I cannot find it. -edit- I cannot find that .57 either, maybe some internal test build?
18th November 2009, 14:29 | #2330 | Link |
@Redsandro
I now see that i have the same: Core Existing Version: 0.3.1.10.56 Core Latest Version: 0.3.1.10.51 I assume it is a bug, cause it also sais: There is 0 file that can be updated. So i again assume that it's alright. But when i downloaded v1056 and ran the updater there where, if i remember good, 42 updates to update, and it did so without any problems. In the other thread where i asked for version v1057 the anwser was that v1057 is a development version, so that why i wont update, unless you configure the updater to use development version, but remember these could be unstable and could have problems. You can change to development and add extra update servers in the AutoUpdateServerConfigWindows: Options -> Settings (or CTRL+S) -> tab Extra Config -> button Configure Servers. You can add new updates servers and if you change the drop down box 'Auto-update server' to development you can update, if you want, to the development and maybe unstable version 1057. For me there are 'There are 15 files that can be updated.'. |
18th November 2009, 14:41 | #2331 | Link |
Unregistered User
Thanks for the explanation. I also had many updates the first time but I noticed they all update to the same versions I already have for a few months now.
I prefer not to use unstable releases, but if I cannot find a fix soon I think I will try .57.
19th November 2009, 15:26 | #2332 | Link | |
This should be the solution, worked with me: 1. Enable vc-1 in ffdshow. You can do this by starting the ffdshow video decoder configuration: startmenu -> programs -> k-lite codec pack -> configuration -> ffdshow video decoder configuration -> codecs -> scroll down to format VC-1 -> click on disable(or other decoder) and change it to libavcodec. 2. Run the Win7DSFilterTweakers. Startmenu -> programs -> k-lite codec pack -> tools -> Win7DSFilterTweakers -> scroll down 32-bit directshow filters to 'set as default VC-1decoder' and select ffdshow. 3. Change splitter for .m2ts files. Startmenu -> programs -> k-lite codec pack -> configuration -> manage preferred source filters -> scroll to .m2ts files and choose Haali. 4. Restart megui and it should be working, else reboot pc. Enjoy! |
21st November 2009, 12:10 | #2333 | Link |
Big Bit Savings Now !
Despite the issues I'd like to play around a bit with MeGUI 1057 and newer x264 versions.
Since 1057 seems to have been withdrawn from kurtnoise's server and sourceforge's as well I kindly ask if somebody could share a 1057 link or the 1057 file. |
22nd November 2009, 02:43 | #2334 | Link | |
25th November 2009, 23:48 | #2335 | Link | |
And of course after that, Options -> Update |
26th November 2009, 05:54 | #2336 | Link |
This has reached a new level as far as "inmates running the the asylum" goes. But yeah, people,, let's own this!!!
mozzle Last edited by Guest; 27th November 2009 at 04:25. Reason: 4 |
27th November 2009, 04:23 | #2337 | Link |
personally, I'd like to see the return of Kurtnoise and/or Sharktooth and the returning of this ship to the capable hands of its ex-captains!
it is a real shame that this very good proj is going a little stale in this apparent vacuum *EDIT* having said that, I tried 1057 out for the first time last night (properly) and all was A-OK still (using my own tailored profile). I manually uprev'd x264 to its newest version - if anything, it is significantly faster now thanks to x264 recent improvements Last edited by magic144; 30th November 2009 at 22:31. |
30th November 2009, 13:46 | #2338 | Link | |
