7th July 2004, 04:34 | #23 | Link |
PgcEdit daemon
Beta testers wanted!
If you are interested in doing some beta testing to help me debug and improve PgcEdit, you may download the v0.3.0beta here.
Thanks in advance. [EDIT:] Beta removed: v0.3.0 (final) released. Last edited by r0lZ; 17th July 2004 at 23:33. |
8th July 2004, 17:28 | #24 | Link | |
Using PgcEdit to denote streams attributes?
The readme that comes with your tool states
10th July 2004, 00:18 | #26 | Link |
Let me first say thank you for this awesome program r0lZ!
When you select line that has goto command, destination line flashes. Is it posibile to create such hilighting when selecting link or jump lines? Or even maybe a follow command on right-click? For example if you have line that has LinkPGCN PGC 3, when you select it PGC 3 in the same domain flashes, and when you right-click it and select "follow" then it opens PGC 3 in main frame. |
10th July 2004, 05:13 | #27 | Link | |
PgcEdit daemon
It's already done, in the v 0.3.0 beta. Click on the link 4 posts above to download it. See also the post of sweetness, above. He must be credited for the idea, too. |
15th July 2004, 16:05 | #28 | Link |
Hi r0lZ!
Thank you for this tool. It's great but I have problem. In previous version (0.2.1) I had no problem with "Move Up" and "Move Down" but in version 0.3.0beta it doesn't work. Is it me or...? I have one request. Is it possible to play some parts of VOB by clicking (or double clicking) on VTS or parts that have + sign to view video? This will make it easy way to bypass some unwanted parts of DVD. FFS
Za CRO,YU,SLO,MAK i BIH titlove i drugo posjetite Livada |
15th July 2004, 16:07 | #29 | Link |
I was working something with pgcedit 0.3.0 beta, and i must say it saved me at least 2 hours typing in ifoedit
i needed to edit pgc command for 7 titles (they had most of the lines same), so i modified it in scratchbook and then just copy-paste in each of that 7 titles. There is a small bug in this beta that allows you to paste command over the caption lines ("pre commands", "post commands" etc). And few thing that might be usefull: - undo for scratchbook - quicksave on scratchbook, so it could be loaded on pgcedit startup - open single ifo |
15th July 2004, 18:12 | #30 | Link | ||
PgcEdit daemon
@ ffroms:
Of course, you may still use the functions to move up/down commands inside the pre, post or cell commands group. Quote:
If you know a VOB player able to display only a specific VOB/Cell ID, please let me know: I may try to integrate it to PgcEdit. Or if any programmer out there is able to write such a tool, it will be appreciated! |
15th July 2004, 18:32 | #31 | Link | ||||
PgcEdit daemon
@M!ro
Of course, your suggestion makes sense if I implement your second suggestion: Quote:
If you really need to edit a single IFO, you must use the good old IfoEdit. Sorry |
15th July 2004, 19:01 | #32 | Link | |
If you make quicksave/quickload for scratchbook it would act like undo function And that would be wonderfull! |
15th July 2004, 20:37 | #33 | Link |
Thanks r0lZ for explanation. I usually check manually for any goto lines and correct them so I never thought of that. I've notice same problem as M!ro with copy/paste so I didn't use it. I prefer to use previous version for "move up" and "move down". I use them to move all post commands to pre commands.
Anyway, I'm looking forward for next release. FFromS
15th July 2004, 22:21 | #35 | Link |
PgcEdit daemon
@ffroms
The paste doesn't crash in beta IF you take care to select only command lines, without pre, post, cells or scratchbook labels. BTW, have you tried the "Kill PGC Playback" macro? This function was not working verry well before v0.3.0beta, but is fully operational now. It does exactly what you want: copy the post commands at the end the pre section, renumber the gotos in the copied commands, and take care of the break pre-commands, if any. |
16th July 2004, 15:56 | #36 | Link |
What!?! How did I not see that? I'll try that ASAP. Maybe I saw that but didn't try it. Thank you again.
FFS P.S. Maybe a little manual would be good just to know what some functions do
16th July 2004, 23:06 | #37 | Link | |
PgcEdit daemon
Maybe some people here are able to write some guides, with wonderful illustrations and tricks I haven't discovered myself... |
17th July 2004, 14:50 | #38 | Link |
add a new VTS_PGC 2 ?
first of all thanks for the great tool!
my question is: if its possible with pgcedit to add a new VTS_PGC(2) into VTS_PGCITI tible where already exist VTS_PGC(1) and if is really possible how can I do this? Thnaks in advance cccp |
17th July 2004, 15:51 | #39 | Link |
PgcEdit daemon
Yes, it is possible.
Select the original PGC in the left pane, then use the "Utilities/New PGC" menu. A new dummy PGC will be created in the same domain. IMPORTANT: I wrote this function to add a dummy PGC in the menu domain, not in the title domain. However, it is possible. But take in mind that the new PGC is a so called DUMMY PGC, ie it has no cells nor programs associated with it. This, in the title domain, is really illegal in terms of DVD standards (although my Sony Player accept that without problems). You must understand that and use this feature with caution! Last edited by r0lZ; 17th July 2004 at 15:56. |
