16th April 2010, 10:01 | #11361 | Link | |
MPC-HC Project Manager
I couldnt find much english chatter about this but based on google translate i read the following: the 10.5 driver is a seperate branch from the 10.3/10.4 trunk. Besides having a new avivo core that moves both VC1 and H264 to the "L5.1" limits and improving the transcoder many other things are changed. OpenGL/CL drivers are up by 15 revisions! Longstanding bugs in DirectX games appear to have been fixed, and performance is up in underperforming ones. Please try it out! (also with the ffdshow dxva decoder)
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
17th April 2010, 13:34 | #11365 | Link |
Hi.
Devs with ATI, can you look on this sample? There is pixelation if ATI catalyst 10.3 is in use on my 5770 (WinXP). Strange is, this doesnot happend if PDVD9 decoder (DXVA on) is in use. Can be problem in FFDshow DXVA decoder?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
18th April 2010, 01:51 | #11366 | Link |
Any word on whether the lossless H.264 with DXVA issue will be fixed?
18th April 2010, 13:13 | #11367 | Link |
ffdshow video is a problem or mpchc?
happens with 2 different releases of ffdshow: pin SubPicure DVD navigator connected to pin MPC ffdshow_rev2099_20080903_clsid_sse_icl10 because the pin SubPicure MPC is not automatically linked? one of the latest releases ffdshow_rev3356_20100411_sse_icl11
my PC with Ryzen 7950X Last edited by DMD; 18th April 2010 at 13:59. |
18th April 2010, 19:28 | #11368 | Link |
http://www.mediafire.com/?sharekey=3...e79d7d0540e1e1
What is the difference between ffdshow_rev3361_20100415_xhmikosr.exe and ffdshow_rev3361_20100415_xhmikosr_icl11_core2.exe? The second file is just for double core? |
18th April 2010, 19:31 | #11369 | Link |
Since albain is getting closer to a stable build i would like to ask everyone to help out getting a clean libavcodec for both ffdshow and mpc-hc.
the following looks like a clean solution: src/libavcodec/ffmpeg/ (this contains the clean and complete export from ffmpeg src/libavcodec/patches (this contains * ffmpeg_directshow_patch (this turns it into a dshow filter) * ffmpeg_mediafoundation_patch (this turns it into a MF filter) * ffmpeg_h264_dxva_patch (adds DXVA1, 2 and HD) * ffmpeg_mpeg2_dxva_patch (adds DXVA1, 2 and HD) * ffmpeg_VC1_dxva_patch (adds DXVA1, 2 and HD) * ffmpeg_windows_configpanel_patch (adds the settings panel) * ffmpeg_bitstreaming_patch (adds support for bitstreaming (HD-)audio) Both combined become the clean and correct codec.ax that can be used standalone, in ffdshow and in mpc-hc. This way we can report bugs upstream again and updating becomes less painfull, also this part of the code can be completely shared between both projects lowering the time taken to work on that section of code.
18th April 2010, 21:17 | #11370 | Link |
Sorry, but this is a useless suggestion. First of all, except for dxva, all of those things are done outside of the ffmpeg library. Secondly, it is totally impractical to maintain code like you suggest.
If you want to simplify things for MPC, then consider using ffdshow's libavcodec.dll instead of linking it directly into MPC/MPCVideodec. Or better yet, stop trying to replicate ffdshow functionality and just tell MPC users to use ffdshow.
MPC-HC 2.2.1 |
18th April 2010, 21:34 | #11371 | Link | |
The current implementation is messy and difficult to maintain, your post does not suggest an alternative that makes it easier.
18th April 2010, 22:45 | #11373 | Link | ||
MPC-HC 2.2.1 |
18th April 2010, 23:38 | #11375 | Link |
契約者
What I mean is some people was against MPC-HC without internal filters but I don't understand why do MPC-HC still needs them. Why not just drop and forget about them? In what way internal filters better than ffdshow? So I thought maybe some more integration will be fine for these people...
19th April 2010, 04:09 | #11376 | Link |
4:2:0 hater
@devs
I've fixed a problem with SSA subs. If a color is written as an integer instead of an hexadecimal and the value is negative, ffdshow outputs a greenish color while MPC outputs black, since a negative value doesn't make any sense here. With this patch ffdshow is consistent with VSFilter and MPC's internal subtitle renderer. Patch: http://www.mediafire.com/?4wwhlztljlm Build: http://www.mediafire.com/?lizgymxzyzh SSA script for testing: http://www.mediafire.com/?gntnyw2tkwv |
19th April 2010, 08:03 | #11377 | Link | ||
You are most experienced in this area, could you write a detailed guide to updating? We could take over from there. Quote:
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 19th April 2010 at 10:44. |
19th April 2010, 09:23 | #11378 | Link | |
IMHO the "proper" way to handle locked down environments would be to: (1) Add a folder named "external filters" to the MPC root folder. Users could just drop in any external codec files there. (2) MPC would enumerate through these files, load all of them via LoadLibrary, and call their "DllRegisterServer" routines during MPC initialization. (3) To make (2) succeed even in locked down environments, MPC would hook all registry related APIs (by using Detours) and build up a temporary virtual registry storage (in RAM only). If you do this correctly, the DllRegisterServer method of most external filters should succeed, and the registration would be in your virtual registry storage. Also you should be able to fully use the external filters this way, in the same way, as if they were installed for real. I think something like the approach above is the usual way to handle locked down environments. Instead of avoiding admin stuff, you emulate/virtualize it by hooking the APIs. Of course doing it this way is somewhat complicated. And it might fail with a few external filters (e.g. it might fail with filters that have some kind of copy protection). But I'm quite sure that it would work with by far most free external filters. This logic would also have the added benefit that even in non-locked down environments MPC HC users could use many external filters without having to install them. |
19th April 2010, 10:40 | #11379 | Link |
Your description is very close to how MPC(-HC) already works.
The only difference is that we include the codecs internally as backups for when no codec is installed on the OS, or you have not selected a specific (registered or unregistered) codec. To make MPC-HC behave like you have described all you have to do is uncheck the internal codecs, in that case they will only be used when there is no alternative. To get an unregistered codec working you select it from the external codec page. For some features to work correctly we need the codecs to be internal (mostly DXVA-1) I believe we should take a more modular approach and bring these two projects closer together. It would be nice to have a single file for the player, codecs and postprocessing but on the other hand be able to install only 1 of the 3.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 19th April 2010 at 10:53. |
19th April 2010, 11:00 | #11380 | Link |
Keiyakusha asked why MPC HC still has internal filters. Your reply was that they're needed for locked-down environments. Now you're contradacting yourself. Either the internal filters are needed for locked-down environments or they're not. If they're not needed, your reply to Keiyakusha was incorrect. If they are needed, your reply to me is incorrect. I'm confused...
