13th July 2007, 14:41 | #202 | Link | |
sorry sorry, manusse
the cause of the extra dirty pixel at the bottom line after 5 times of TESTING, and found that it is cause by MANUIPATE sup with SC TIMES i tried 1)i manunipate and mux (bcuz u intro me this function) -DIRTY 2)i tried again making sup manuipate and mux -DIRTY 3)i make sup with SC but never manuipate and mux -CLEAN 4)i make sup with SC and manuipate again -DIRTY 5)i make sup with SC and manupate in DVDsubedit -Clean so conclusion tells me just make SUP with SC and don't use that function ^^ ----------------------------------- Can I remind the developers about wants this to be fixed? @WARP LINE = ON, If lines are too long on a LANG which doesn't have SPACING SC has a missing character on the LEFT example: korean, japanese, chinese try this line @WRAP = ON, Chinese simplified, MISSING 库 141 00:07:18,470 --> 00:07:22,760 库林桑特和阿米特治是艾亚利斯的智慧和灵魂! Last edited by Anime; 13th July 2007 at 14:53. |
13th July 2007, 21:17 | #203 | Link | |
SubtitleCreator's Co-Dev
I like the results of your investigations. At least it gives us some clues about where the problems can come from. At present, Paddington and myself don't have time to code but I am sure I will find some in september. Maybe Paddington will also. And at that time we will surely have a look and fix this bug. So be prepared to help us testing the fixed version, in a few months. We will need testers'help. About the missing character, I could reproduce it. When we have some time, we'll have a look at it. Cheers Manusse |
14th July 2007, 16:17 | #205 | Link |
Hi all
I've some problem with converting srt to vobsub by SC. - When I save as the srt to vobsub with option video format PAL (from Menu Format),my PC play movies perfectly. But When i play movies (with that idx/sub) on my divx standard alone player, the player cannot play the movies and crash (I have to turn the power off). - However, when I save as the srt to vobsub with option video format NTSC, the divx player play movie with sub perfectly , but the subtitle is displayed out-of-sync with the movie when i play movies on PC Can someone help me to make the sub work perfectly on both PC and divx player? Thanks so much. P/S : My divx player have local brand ^^.Sorry my bad English |
14th July 2007, 17:25 | #206 | Link |
-I don't know why you have a problem with your PAL subtitle. Did you try to open it with subresynch. If it works, it must be a problem with your SAP. -For the NTSC timings bug, have a look at this post. Cheers Manusse |
16th July 2007, 16:23 | #207 | Link |
I get this when AA = OFF i <k> the most bottom line </k> not i don't want AA=ON, is that i find it very ugly while watching AA=ON on my TV+DVD player or monitor+software player and one of the reason i sugested, having able to do different color per sup pic like commercial dvd not using <K> is that <K> cannot apply fade.... using...... dvdsubedit 1) it is more flexible like converting it to vobsub will definetaly get the color, but <k> i'm not very sure.... if vobsub gonna takes it into account... Last edited by Anime; 16th July 2007 at 16:28. |
18th July 2007, 15:59 | #208 | Link |
I installed Subtitle Workshop on a pretty new system with Windows XP x64. And although the movies do play fine in ZoomPlayer most of them won't start inside Subtitle Workshop - the video preview window remains black and no audio is playing as well.
Any idea what could be the problem and how to get rid of it? Thanks you very much! |
30th July 2007, 18:01 | #211 | Link |
unrecognized user
About the posibility of transforming hd sup files in idx, very nice feature that doesn't seem to work as it should though. The subs saved are very hard to ocr because somewhere in the downsizing process or color reducing the fonts become jagged (as if coroded by some process ), which makes them different from one another. Tried changing transparency, and colors but can't get any good results.
Here's the sup file I'm trying: http://d01.megashares.com/?d01=62a247f Also, should it read sup files from bluray (demuxed with xport)? (doesn't seem to work here..)
zzz Last edited by Daodan; 30th July 2007 at 18:09. |
7th August 2007, 14:26 | #212 | Link |
Hi Daodan,
I am (unfortunately) back from vacations. The HD-SUP import function works only with HD-SUP files, not with BD-SUP (blu-ray) yet. This is on my plans for the future but there are many bugs to be solved first, I think. When SC opens an HD-SUP, the internal process followed is the following: 1°) Convert the sup from 1920x1080 to SD definition (at present 720 x 576 but in next version 720 x 480 will also be available). The color is not changed 2°) Determine the brightest and the darkest colors of the subtitle. 3°) Replace each color by one of darkest/brightest/(0.5*(brightest+darkest) That's the process applied. I think part of the problem you see could be avoided by using an anti-aliasing filter before reducing the image size. Maybe I will add some settings in future versions to do this. Cheers Manusse |
7th August 2007, 15:32 | #213 | Link | |
is there a new version?
how come i did not see any HD function on v2.2.2 beta? edited: sorry in changlog... really hope there is a new compile version... ^^ to solve blinking and missing charcter ------------------------ and is it possible next version "auto wrap" lines even if the line is too long and exist line break? i find that if there is already line break or | in sentence auto wrap won't works any more, it will shrink the font to so-so small.... ---------------------- if anyone have any idea to solve the blinks, currently? Quote:
11th August 2007, 01:48 | #214 | Link |
i got a error ifo has more than one PGC unspported,
I using 2.2.2 beta, i have attach SC_TEMp txt files in attachment The fault doesn't comes from voblanker, as if i do it manually nothing went wrong. Manual:
so whats wrong? ^^ with SC parsing files? Last edited by Anime; 11th August 2007 at 01:51. |
11th August 2007, 14:02 | #215 | Link |
As the message says, it's presently unsupported by the wizard. However you can do it by hand. See here for explanations:
http://sourceforge.net/forum/forum.p...orum_id=410032 If you don't need to keep the menus it's not important as VobBlanker is used only for menu restoration. Cheers Manusse Last edited by manusse; 12th August 2007 at 21:46. Reason: Precision |
16th August 2007, 22:07 | #217 | Link |
hi,
a couple of questions: 1) is it possible to change and remember the default fonts? every time I start the program, it loads the last srt file, but forgets about the fonts and shows Arial Narrow/Bold/22pt. Since I never use that one, I have to recall which one I did use last, and change it accordingly. Same thing about the other formatting settings. 2) If my system setting for "Language for non-Unicode programs" (Control Panel->Regional and Language Options) is e.g. Russian, then the only font script I can use is Cyrillic, regardless of the "Character Encoding" setting. If I want to create subtitles in "Western" or any other script, I need to change my regional option, which requires Windows restart. Of course, this means that I cannot use Cyrillic or any other script until the next restart, which is very annoying. thanks! |
16th August 2007, 22:34 | #218 | Link |
Hi kto,
About point 1) Did you use the last version (2.2)? The profile should work better now and they will normally fix the font problem you mention. The last used profile will be remembered. However, there is no link between the srt file and the profile but if you always use the same fonts it will be ok. Choose Format->Change Font and choose the font you want to use. When you are satisfied, choose Profiles -> Save Current Profile. Then choose a name and save it. Then (and I need to fix this remaining small bug, I thought I had !!!!!) choose Profiles -> Apply Profile -> the name of your newly created profile. And that's it. Now it will be automatically selected each time you will restart SubtitleCreator. Another way of remembering the font is to use the font button (F) at the bottom of SC and choose a font for your subtitles. This one will be embedded in the srt file but it's only valid for one line (Note that this is not a "standart" srt tag, but is specific to SC). Also it seems this button disappeared from the English interface!!! But it's still there in the French interface... One more bug to fix in a next release. About point 2), I'll let Paddington answer you. Cheers Manusse |
18th August 2007, 02:03 | #219 | Link |
manusse,
thanks for the tip. I've also noticed that "position subtitles: width" setting is not saved in the profile automatically, one has to update it in the profile manager. btw, is there a list of supported srt tags somewhere? (like <b> <i> <f> <s M /> etc.) regarding 2), it would be ideal if the program supported Unicode, of course. but at least some kind of fix to the problem mentioned above would be great. cheers |
19th August 2007, 13:05 | #220 | Link | |
"Anchovis, anchovis, you're so delicious, I like you more than all the other fishes" - Dawn Summers |
