Old 16th October 2010, 21:29   #9881  |  Link
Capsbackup
Originally Posted by borivoje View Post
Reinstaling FFDSHOW is not working ... I made few changes in video configuration, but nothing works ... I get the same log every time ... Is it possible that new BD Rebuilder has made some changes, because I'm 120% sure that I haven't installed anything that could've changed FFDSHOW settings since the last successful rebuild, made with 0.34.07?
Uninstall haali and delete it's folder in programs. Also, uninstall ffdshow and avisynth. Reboot. Now reinstall those three programs.
Delete the BD-RB.ini inside it's folder. Then right click on REG_MSCOMCTL and run as administrator. Then do the same for BD-RB.exe.
Capsbackup is offline   Reply With Quote
Old 16th October 2010, 23:27   #9882  |  Link
borivoje
That was it, but I still can't figure out how settings ended messed up without any installation ... Anyway, it works now ...
Many thanks Capsbackup ...
CHEERS
borivoje is offline   Reply With Quote
Old 17th October 2010, 00:41   #9883  |  Link
waynezo
Originally Posted by Race Guy View Post
The menus in that disc CAN'T be recoded.
You need to set the hidden op MIN M2TS="---" but I can't remember the number. 600 rings a bell, but I can't be sure.
Find the menus in the STREAM folder, check the sizes & go +100MB over the largest one.
You also need a BD-RE to test burn if you're doing concerts, 'cause they tend to be "quirky" in the menus. You'll avoid a LOT of disappointment!!
Success! Yes, 600 was the number. I suppose I should leave it at that setting.
Thanks Race Guy and Capsbackup.
And of course jdobbs.
Windows 7 Pro
Quad Core Intel Core i7 920
Asus P6T Deluxe V2
2 ATI Radeon HD 4770 Video Cards
6GB OCZ Gold DDR3 1600
Intel X25-M 80GB SSD HD
2 HANNS-G 28" Monitors
2 Hyundai 19" Monitors
waynezo is offline   Reply With Quote
Old 17th October 2010, 12:20   #9884  |  Link
DK
DK's Avatar
Originally Posted by KeVe1983 View Post
Yeah, but the non-US BD of IM 2 is a BD25!
I've have the EU/German Version and it's a BD25.
The US Disc is a BD50, or am i wrong?
Also Iron Man 1, the US Disc was a BD50 and the Non US a BD25.
The Quality of the US Disc is much better.
Dont understand, why they releasing 2 different Discs
Not quite.
The entire content is ~45GB; the main movie has some 24GB.
DK is offline   Reply With Quote
Old 17th October 2010, 18:54   #9885  |  Link
massiah
OK... I have been using BD-RB since last Christmas. Normally when I have any problems with freezing, I just uninstall and re-install(sometimes, a few times) and it seems to get going again.
I have done over 50 backups successfully but, I am having problems with SPARTACUS Season 1 Disc 1.
I am running a 64bit-OS with a QX9650CPU, 8GB RAM, Multiple hard drives(internal and external) and BD-RB is installed on my second hard drive.
I normally don't have any problems with it on the C: drive and have tried different scenarios with that. This encode just keeps on freezing.
Any clues?
- Windows Version: 6.1 [7601]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD Rebuilder v0.35.0.1, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[12:45:30] BD Rebuilder v0.35.01 (beta)
- Source: SPARTACUS_S1_D1
- Input BD size: 43.29 GB
- Approximate total content: [03:42:10.316]
- Target BD size: 22.90 GB
- Quality: Better (Faster), ABR
- Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640
- Resuming from previously started job.
[12:45:32] PHASE ONE, Encoding
- [12:45:32] Reencoding: VID_00004 (7 of 10)
- [12:45:32] Collecting video information
- Rate/Length: 23.976fps, 70,728 frames
- Bitrate: 10,416 Kbs
- [12:45:32] Reencoding: VID_00004, Pass 1 of 1
massiah is offline   Reply With Quote
Old 17th October 2010, 19:16   #9886  |  Link
Dirk Diggler
Any clues?
Ive backed up Spartacus Season 1 with no issues. Try re-ripping it again...
Dirk Diggler is offline   Reply With Quote
Old 17th October 2010, 22:40   #9887  |  Link
CV91913
jdobbs...I have experienced the same problem on multiple backups. I noticed you asked for the full log but did not see it posted or any other response. So I will post my logs. This "Can't open file:" error has occurred on BD 25 movie only and BD 5 movie only with and without the "use x264'x internal LAVF" option set. In all cases resuming has solved the problem. It has occurred on 3 different backups since moving to 35.1 Here is the most recent case:
[08:23:27] BD Rebuilder v0.35.01 (beta)
  - Source:  BRAVEHEART
  - Input BD size: 42.81 GB
  - Approximate total content: [02:57:43.152]
  - Target BD size: 22.66 GB
  - Windows Version: 6.1 [7600]
  - MOVIE-ONLY mode enabled
  - Auto Quality: Good (Very Fast), ABR
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[08:23:27] PHASE ONE, Encoding
 - [08:23:27] Extracting A/V streams [VID_00006]
 - [08:45:49] Reencoding: VID_00006 (1 of 1)
 - [08:45:49] Collecting video information
   - Rate/Length: 23.976fps, 255,660 frames
   - Bitrate: 16,211 Kbs
 - [08:45:49] Reencoding: VID_00006, Pass 1 of 1
 - [12:36:38] Video Encode complete
 - [12:36:38] Reencoding audio tracks (if req'd)
 - [12:39:47] Multiplexing M2TS
[12:49:15]PHASE ONE complete
[12:49:15]PHASE TWO - Rebuild Started
 - [12:49:15] Rebuilding BD file Structure
 - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
 - Can't open file: C:\USERS\PUBLIC\VIDEOS\RIPS\WORKFILES\00006.M2TS
[12:49:15] - Failed to REBUILD
[13:18:57] BD Rebuilder v0.35.01 (beta)
[13:18:58] PHASE ONE, Encoding
[13:18:58]PHASE ONE complete
[13:18:58]PHASE TWO - Rebuild Started
 - [13:18:58] Rebuilding BD file Structure
[13:29:21] - Encode and Rebuild complete
 - WORKFILES folder removed.
[13:29:21]JOB: BRAVEHEART finished.
[Status]
LABEL=BRAVEHEART
VERSION=v0.35.01 (beta)
SOURCE_SIZE=45971742720
SOURCE_VIDEO_SIZE=45971742720
TARGET_SIZE=24326963200
REDUCTION=.529172090520218
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00006]
AUDIO=1000
PGS=100100
M2TS_TARGET=24326963200
RATE=16211
NSTART=27000000
NEND=506842560
NSIZE=22408882176
FLINK=0
MLINK=0
- FFDSHOW: 3326, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
CV91913 is offline   Reply With Quote
Old 18th October 2010, 02:19   #9888  |  Link
[SLiM]D12
Googled for a bit to no avail. Backed up a movie with Cinavia, i'm trying to "replace" the DTS-HD audio with the ac3 from the DVD. I'm not sure how i do this.
I used tsmuxer to re-mux the video from BD-RB for the affected M2TS file, but when the bluray is playing in my PS3, i get no audio. All i did was remove the DTS-HD in tsmuxer, replace it with the AC3 and mux to M2TS file and replace the one in the output dir of BD-RB.
Can somebody give me a hand, or point me to a link that shows me what to do?
thx in advance!
[SLiM]
[SLiM]
[SLiM]D12 is offline   Reply With Quote
Old 18th October 2010, 03:54   #9889  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Normally when I'm editing Blu-rays, I use multiAVCHD and its Blu-ray import function.
I don't know the structure of Blu-rays that well yet, but it's possible that your PS3 is seeing that your audio SHOULD BE DTS-HD, but is tweaking out when it sees that it is actually AC3. Try remuxing with MultiAVCHD instead of TS-Muxer.
Oh, and massiah, you never actually told us what your problem was. Your (partial) log doesn't explain anything.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 18th October 2010, 04:13   #9890  |  Link
massiah
I tried what DirkDiggler said and changed some settings in ffdshow. Everything reads OK for the settings but still no go.
Freezes again.
Adub...my partial log stops right where it ends. Probably because it freezes my PC and I have to restart.
Dunno... I am lost.
Looking to build a new PC anyways... SR2 Classified with dual Xeon chips and 24GBRAM in the next few months.
Start my build from scratch... again
Thanks anyways, guys
Old 18th October 2010, 05:11   #9891  |  Link
jdobbs
thx in advance!
[SLiM]
Not sure I understand exactly what you did, but if you replaced a .DTS with a .AC3, you can't do that without some manipulation. There are references to the type of audio (DTS/AC3) in the CLPI and MPLS files.
First run the job through BD-RB telling it to reencode the DTS to AC3. After it completes, replace the AC3 file in the working folder with the one from the DVD -- then start BD-RB again and tell it to resume. It will rebuild using the new AC3 and you'll be done. Make sure, though, that the bitrates etc match (the DVD is probably 5.1 448Kbs).
Website: www.jdobbs.net
Old 18th October 2010, 13:36   #9892  |  Link
[SLiM]D12
the bitrate is 384 kbs, there's no way to use that in BD-RB is there?
[SLiM]
Old 18th October 2010, 14:35   #9893  |  Link
jdobbs
[Status]
LABEL=BRAVEHEART
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=-1
QUICK=0
ENCODE_STEP=0
COMPLETED=1
REBUILD_COMPLETE=1
[00006]
AUDIO=1000
PGS=100100
RATE=16211
NSTART=27000000
NEND=506842560
NSIZE=22408882176
FLINK=0
MLINK=0
- FFDSHOW: 3326, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
What antivirus software are you using? I saw some issues a long time ago (in DVD Rebuilder) in which the antivirus was delaying closing of files -- causing failure to open unless there was a delay thrown in. Disable your antivirus and see if the problem still exists.
Old 18th October 2010, 15:38   #9894  |  Link
CV91913
I am running McAfee. Although I have turned off all scheduled scans, it is running. I will turn it off and see if that helps. Thanks.
Old 18th October 2010, 15:50   #9895  |  Link
jdobbs
Hmm... I run McAfee also, but I have realtime scanning disabled.
Old 18th October 2010, 15:52   #9896  |  Link
jdobbs
Just use 448Kbs to replace it. It should be fine.
Old 18th October 2010, 16:20   #9897  |  Link
CV91913
I have an ongoing issue that has shown up as far back as 34.6 and I have now seen it with 35.1. There are no logs as everything completes without error. The problems is that when creating a BD25, movie only, where the input files are small enough that reencoding is not required, the resulting BD structure will not play on any of my computers using Roxio CinePlayer. If I play from the BDMV, CinePlayer crashes and if I try to play the .m2ts file directly it brings up an error dialog about using fddshow. It does not matter if I choose yes or no, it won't play. If I burn it to BD it will play on a standalone BluRay player but not in a PC. If I use the BD25 as an input and build a BD5 everything is fine. If a dink around with the original and add soundtracks to cause it to do a BD25 reencode, all is well. This issue is hit and miss. The last two backups it has occurred on were "A Time to Kill" and Pirates Carrib Black Pearl." I just did "Total Recall" yesterday and it played. This bug report thread may not be the right place but I don't know where else to put it.
Old 18th October 2010, 16:49   #9898  |  Link
Ch3vr0n
Did you try a real player like Arcsoft TMT 3 or even PowerDVD ?
Ch3vr0n is offline   Reply With Quote
Old 18th October 2010, 16:56   #9899  |  Link
Capsbackup
@CV91913;
Roxio CinePlayer is not a very reliable test software player. All software players have quirks on BD backups. The standalone is the true test.
If jdobbs goal was to make backups for software players, bug reports would be so long that he could not possibly satisfy anyone!
Old 18th October 2010, 17:37   #9900  |  Link
CV91913
Roxio may be crap but it played the original BluRay disk just fine and it played the rip just fine. I just thought there might be something going on with the extraction. Sorry for bothering you.
