5th March 2010, 23:13 | #3461 | Link | |
6th March 2010, 16:12 | #3463 | Link |
BrainDead
Error encoding from DTS to AAC 5.1
I been trying to convert my backup copy of Dark Knight in MKV to MP4 and in the process encoding the DTS track to AAC 5.1 192kbps but every time I get the same error, and only the video track is muxed. Here is the partial part of the log where Nero AAC Encoder shows an error.
------------------------------------------------------------ Environment ------------------------------------------------------------ StaxRip version: 1.1.5.1 OS Name : Windows 7 Ultimate OS Version : 6.1.7600.0 OS Type : 64-bit OS Culture : English (United States) ------------------------------------------------------------ .NET ------------------------------------------------------------ v2.0.50727 : 2.0.50727.4927 v3.0 : 3.0.30729.4926 v3.5 : 3.5.30729.4926 Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 2h 32mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Stream size : 1.61 GiB (27%) Title : DTS - 1536 kbit/sec Language : English ------------------------------------------------------------ Audio encoding using BeSweet ------------------------------------------------------------ "C:\Program Files (x86)\StaxRip\Applications\BeSweet\BeSweet.exe" -core( -input "M:\VIDEOS\HD\!MOVIES\The Dark Knight - 720p temp files\The Dark Knight - 720p DTS - 1536 kbit_sec - en-English.wav" -output "M:\VIDEOS\HD\!MOVIES\The Dark Knight - 720p temp files\The Dark Knight - 720p DTS - 1536 kbit_sec - en-English_AudioOutput.m4a" ) -ota( -d 0 -g max ) -bsn( -vbr 0.3 -6chnew ) ************************************************************* * * * Nero AAC Encoder * * Copyright 2009 Nero AG * * All Rights Reserved Worldwide * * * * Package build date: Dec 29 2009 * * Package version: 1.5.3.0 * * * * See -help for a complete list of available parameters. * * * ************************************************************* [00:00:00:000] Initializing... [00:00:00:000] -- Initializing... [00:00:00:032] | [00:00:00:032] Finalizing... [00:00:00:032] Conversion Completed ! Visit DSPguru's Homepage at : http://DSPguru.doom9.net/ Start: 9:52:19 AM End: 9:52:20 AM Duration: 00:00:00 ------------------------------------------------------------ Audio Encoding Complete ------------------------------------------------------------ Last edited by jsquare; 6th March 2010 at 16:28. |
7th March 2010, 08:25 | #3464 | Link |
The Lazy One
Location: The TurokZone. Next Door are the heavens, hells, and on the backside the void
where is multitask and stax? anywho found a real bad error from staxrip. it cannot encode a audio source being... a .wav or a .flac. personally i find this outragious but hey im just error reporting here...
Decided this quote only lol. "Always try to understand the perspective of not only yourself but others as well" Am a fanboy of StaxRip |
7th March 2010, 08:50 | #3465 | Link | |
Practising Schemer
Never had an issue with Wav in staxrip myself, but never tried flac. Will give flac a go, how have you enabled flac support/decoder on your pc? |
7th March 2010, 14:52 | #3466 | Link |
could someone please help me with getting the MT avisynth to work with staxrip i am using 1.1.5.1 and i can't unstand how to do and i have been trying to found out for the past 2 days and still nothing
these are the filters that i use source: mpeg-2 field: fielddeinsterlace (blend=false) crop: crop borders resize: sharp |
7th March 2010, 16:33 | #3467 | Link |
@cegy
which MT AviSynth did you install? ? -> tsp's ? -> SEt's ? -> Jeremy Duncan's ? -> JoshyD MT support page download -> SetMTMode.srp right click empty space in filters box import SetMTMode.srp Using AviSynth filters in StaxRip
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
7th March 2010, 19:31 | #3469 | Link |
@cegy
did you load the filter profile first then open your .mpg in StaxRip?
8th March 2010, 02:43 | #3471 | Link |
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo Last edited by MuLTiTaSK; 8th March 2010 at 02:45. |
8th March 2010, 05:49 | #3472 | Link | |
The Lazy One
[update] Retest done and same results. it ends up 8-66kb broken audio. whats going on?
Decided this quote only lol. "Always try to understand the perspective of not only yourself but others as well" Am a fanboy of StaxRip Last edited by turok; 8th March 2010 at 05:52. Reason: retest done |
8th March 2010, 10:38 | #3473 | Link | |
thank you for that but it seems abit faster but its not what i thought i would get as its only around 230fps but if i use avi synth 2.60 alpha 2 i get a good 220-280fps, i know that my cpu should give me a good 300+ fps my cpu specs are: core i7 920 @ 4ghz (4 cores) is there something i am missing ? p.s i have tryed tsp and sets mt avi synth and its still the same or slower Last edited by cegy; 8th March 2010 at 10:46. |
8th March 2010, 15:58 | #3474 | Link |
8th March 2010, 15:59 | #3475 | Link | |
how can i do that when the link is only for 64bit and not 32bit or else i would of tryed this version aswell plus i don't understand why the hell x86 aka 32bit is in the title if there isn't any links for it! Last edited by cegy; 8th March 2010 at 16:06. |
8th March 2010, 16:12 | #3476 | Link |
@cegy
you running a 64bit OS?
8th March 2010, 16:20 | #3478 | Link |
@cegy
so then just stick to the version of AviSynth that runs faster for you do some tests compare results settle be happy
8th March 2010, 16:22 | #3479 | Link |
i would do but i was told it can go faster surely you can understand a user would the main stream cpu would like to use the full power of it i guess its back to 2.60 alpha 2 then p but for trying unless you know how to speed it up with 2.60 ?
9th March 2010, 00:43 | #3480 | Link |
I'll pausing StaxRip now until next winter, maybe I'll make some small fixes and updates, I simply want to sit much less in front of a PC! I'll try to maintain email support but since there are many requests I can't help with everything. Happy encoding everybody until I'm back.
https://sourceforge.net/projects/sta...ta.7z/download 1.1.5.2 beta
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 9th March 2010 at 00:51. |
gui, h.264, h.265, hevc, mkv, x264, x265 |
