Old 2nd May 2013, 18:51   #1041  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2605 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2605 (Nightly Builds) (Dev. MPC-BE)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 3rd May 2013, 06:59   #1042  |  Link
wanezhiling
http://pan.baidu.com/share/link?shar...&uk=3558042035
With internal splitter, always display 4:3
With lav splitter, works fine as expected.
Old 3rd May 2013, 10:37   #1043  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Fixed, thanks
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 3rd May 2013, 15:47   #1044  |  Link
insolo
how to receive the Activation code from mpc-next.ru,i used hotmail and gmail,but nothing.
insolo is offline   Reply With Quote
Old 3rd May 2013, 17:16   #1045  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2615 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2615 (Nightly Builds) (Dev. MPC-BE)
Old 4th May 2013, 00:31   #1046  |  Link
alexins
MPC-BE DEV
alexins's Avatar
there were problems with the smtp server, at the moment the problem is solved.
Old 4th May 2013, 01:46   #1047  |  Link
Zulithe
Thanks, I will continue to evaluate new builds. I do have one item of feedback though: I noticed that when holding down left-click to drag the seek bar, it won't seek videos until I release the mouse button. Any plans to alter this behavior to match MPCHC? I use MadVR and LAV.
Zulithe is offline   Reply With Quote
Old 4th May 2013, 13:57   #1048  |  Link
insolo
thanks,I receive it!
Old 5th May 2013, 18:10   #1049  |  Link
Reino
Reino's Avatar
During the last 12 seconds of a Youtube movie (link directly opened in MPC-BE), cpu utilization climbs to 100% and eventually the player freezes. I have to manually close the exe.
It appears to be a player issue, because it happens with all combinations of filters/renderers.
I've narrowed it down to rev.2443 and rev.2454, where everything is still ok with rev.2443.
My hobby website
Reino is offline   Reply With Quote
Old 5th May 2013, 19:23   #1050  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE v1.1.1.0 -dev build 2642 (Nightly Builds) (sourceforge)
MPC-BE v1.1.1.0 -dev build 2642 (Nightly Builds) (Dev. MPC-BE)
In the settings which mode is used to open links, "Internal" or "File Source"? What video is played *.flv (SD) or *.mp4 (HD)?
Old 5th May 2013, 21:34   #1051  |  Link
Reino
Reino's Avatar
Internal
FLV@360p:
__- freeze
__- correct duration
FLV@480p:
__- freeze
WebM@360/480/720p:
__- no freeze
__- wrong duration.
__Video is 29sec for instance. All FLV freeze at 16sec, than that's the reported duration for all WebM.
__- Although the duration is wrong, it does play to the end. Some videos do however start over after a random amount of time the first time, but play to the end the 2nd time.
__(Btw, when 720p isn't available, instead of falling back at WebM@480p, WebM@720p falls back at FLV@480p!)
MP4@360p:
__- no freeze
MP4@720p:
__- no freeze
__- Videos start over after a random amount of time the first time, but play to the end the 2nd time. Audio is lost the 2nd time (1st itteration) though!
File Source
All formats:
__- Everything fine. No playback issues.
My hobby website
Old 5th May 2013, 23:00   #1052  |  Link
Aleksoid1978
Internal
FLV@360p:
__- freeze
FLV@480p:
__- freeze
WebM@360/480/720p:
__- no freeze
__- wrong duration.
MP4@360p:
__- no freeze
MP4@720p:
__- no freeze
File Source
All formats:
It's happened on ALL youtube clips or some times ??
P.S. what filter/source you use ? Can made & upload a screen-shot.
I use only internal source/filters - all ok, on any format. The only thing - when the speed of the internet is not enough, then begins to slow down
Old 6th May 2013, 12:39   #1053  |  Link
Reino
Reino's Avatar
...because it happens with all combinations of filters/renderers.
I have to admit, by this I meant all sorts of decoders/renderers and these were all connected to LAV Splitter. When I enable the internal FLV and MP4 Splitter, I can actually see MPC FLV/MP4 Source (Internal) or File Source (URL) --> MPC FLV/MP4 Splitter (File Source) being loaded, but in case of LAV, and no matter the Youtube-settings, it's always File Source (URL) --> LAV Splitter and never LAV Splitter Source.
It seems to be a LAV issue, because the issues I described with the Youtube-settings at Internal only happen with LAV. No problems with the internal splitter filters at all. But then again, MPC-BE rev.2443 with Youtube-settings at Internal + LAV doesn't have these issues... so who's to blame?
My hobby website
Old 8th May 2013, 08:55   #1054  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Release Candidate of Visual Studio 2012 Update 3 now available
A fix for ATL & MFC XP targeting is included. This fix addresses the following scenario:
You create a C++ Win32 Console Application project in Visual Studio 2012 Update 2.
You select both ATL and MFC in the application wizard.
You change the Platform Toolset option to v110_xp, and you change Use of MFC and ATL to Static in the project Property Pages.
You run the application on a computer that is running Windows XP or Windows Server 2003.
You receive the following error message:
Application Name - Entry Point Not Found
The procedure entry point InitializeCriticalSectionEx could not be located in the dynamic link library KERNEL32.dll
Old 8th May 2013, 13:34   #1055  |  Link
therock003
In the filetype association options page, what does the option icons do? I want to associate some filetypes, but i want to have the default windos 8 icon showing up. I didnt check the icons box, but still i have the mpc icon on all my video files now.
therock003 is offline   Reply With Quote
Old 8th May 2013, 16:24   #1056  |  Link
v0lt
Uses icons from the mpciconlib.dll.
v0lt is offline   Reply With Quote
Old 8th May 2013, 18:22   #1057  |  Link
therock003
And Which icons are those in that file? Can i edit it and add my one, or set it to use the widnows default icons instead, but keep the association?
Old 8th May 2013, 19:19   #1058  |  Link
dukestravels07
Banned
Quite impressed with this. My GPU was usually around 50 to 60% usage. With this its about 18% max on DXVA
Does your build auto upscale dvd content or do I need to look at some settings. Thanks!
dukestravels07 is offline   Reply With Quote
Old 8th May 2013, 23:40   #1059  |  Link
Aleksoid1978
At default - when program associate file types it set self icon. As you do not check "With icon" - set default MPC-BE icon.
Old 9th May 2013, 10:42   #1060  |  Link
therock003
Do you mean that it will have the icon of the application?
