8th December 2017, 17:36 | #15321 | Link | |
ByteShare
@Atak_Snajpera
I think I found an issue(s)... In the #:\Temp\RipBot264temp\Job##\Chunks\CombineAllChunks.cmd file my install (latest updates, forced a recheck to be sure) I found that it is pointing to "vjoin_.exe" When I looked in the vjoin folder I found only "vjoin.exe" I copied the vjoin and renamed it to the file it wanted. Second issue is with remuxed BluRays anytime there is a sub file (even if I didn't select one to be muxed back in) the remux process is erroring out, see log: Quote:
8th December 2017, 18:50 | #15322 | Link |
Issue #2
Please tell me step by step what to do to force this bug.
8th December 2017, 22:42 | #15323 | Link |
ByteShare
I can send you a sample file but All I do is add the file > Setup HEVC/AVISynth settings > uncheck audio and don't check any subs just let it auto pick when doing batch (remux subs). After encode finishes and tries to mux is when it errors out.
Last edited by byteshare; 8th December 2017 at 23:02. Reason: Released my wording could be confusing |
8th December 2017, 22:54 | #15324 | Link |
Yes, please...
9th December 2017, 19:56 | #15325 | Link |
Getting an error in the Avisynth Filter If I choose Mono Noise 2 - See screenshot: https://www.dropbox.com/s/czdxzc5s1v...givet.png?dl=0
Using the newest 1.20.1 version. |
10th December 2017, 02:31 | #15326 | Link |
Having an issue with audio in batch mode on version 1.21.0. When I batch add files they have no audio, either in the preview, in the encoding settings audio bar - it simply says 'No Audio', and the finished files have no audio either. if I add them manually one by one though they do have audio. I've tried earlier versions and they don't have this problem and audio works OK.
I have been using .m2ts files for this, hope someone can help! |
13th December 2017, 09:54 | #15327 | Link |
Problem with Version 1.21.1
Since a few weeks I have Problems with RipBot (with local and distributed encoding), so i decided to make tests on a PC with a clean Windows installation and only RipBot and the needed Software on it. But I still have Problems.
Here is a step by step description: - clean Windows 10 Installation with all updates - Download ripbot 1.21.0 and install Avisynth from Tools Directory - install latest Java and MediaSplitter - Update Ripbot to 1.21.1 with auto updater - add a m2ts file from a BD iso Image (I use one that i have already encoded with an earlier Version of RipBot, so I am sure the source is ok) The result is an empty "New Job" window with the message "Decoding Error" in the top right Corner. Is there any log I can check to get more information about what is wrong? |
17th December 2017, 15:29 | #15329 | Link |
4K UHD Status
Just wondering if encoding 4K/UHD is possible? I know mkv does not have support for Dolby Vision, but it does for HDR10. Does RipBot264 pass through the HDR10 information to the MKV? What about passing through Dolby Atmos?
I have a UHD friendly drive coming today and about half of my 4K discs can be ripped. I'd like to start encoding them to put on my NAS. MakeMKV lets me convert the disc into a native file and AnyDVDHD is adding support to rip the discs to a folder. Pretty excited to finally put my 4K discs up on my server. |
17th December 2017, 16:25 | #15330 | Link |
@Atak
what about these errors? Code:
FFVideoSource: No video track found Code:
FFAudioSource: No audio track found
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
17th December 2017, 17:50 | #15331 | Link |
ChapterDB
Just found out about chapterdb.org and I think it is a pretty cool idea.:
http://www.chapterdb.org Atak, do think it's possible to integrate this into RipBot264? There is an API for it. |
17th December 2017, 18:46 | #15332 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th December 2017 at 18:49. |
22nd December 2017, 11:55 | #15334 | Link |
Send me whole UHD BluRay folder structure. Trim main movie and extras to reduce file size.
25th December 2017, 13:49 | #15335 | Link |
Merry Christmas everyone!
I'll post this now otherwise I will forget, the move file option seems to have stopped working, I have the following option in my encodingclient.ini file but Ripbot is copying the file rather than moving it. [hidden settings] MoveFiletoSharedFolder=1 My last encode was done at the end of November and I'm sure that was fine - I would have noticed the long wait for the file to be copied. I've also noticed that Ripbot doesn't check for sufficient disc space, my encode just stopped/hung and then I noticed there was zero disc space. In fact it had copied about 22GB of a 34GB file, so the copy had failed and then Ripbot just tried to carry on with the encoding instead of issuing an error Edit: I should add I'm on version v1.20.1, not 1.21.0 as I thought, so I'll force an update later and see if the copy/move issue remains Last edited by Ronski; 25th December 2017 at 13:54. |
25th December 2017, 15:55 | #15336 | Link |
Batch Stumble - Never Ending "Waiting For File"
I have demuxed m2v video files from mkv containers and have loaded them into RipBot264 via the batch function. When I click "Start", RipBot264 moves into a "Waiting for file..." mode that never ends. It waits forever. I wouldn't call it a freeze, since I can abort it. When I load the files individually, RipBot264 has no problem processing them.
25th December 2017, 18:21 | #15337 | Link |
Most likely file handle is still locked (function FileOpen returns 0 each time) by some other process.
From my code it looks like this Code:
Repeat FileHandle := FileOpen(inputfile, fmOpenRead or fmShareExclusive); sleep(100); until (FileHandle>0) or (Terminated=true) or (FileExists(inputfile)=false); if FileHandle>0 then FileClose(FileHandle);
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 25th December 2017 at 18:26. |
25th December 2017, 19:41 | #15339 | Link |
try this
[settings] MoveVideoFiletoSharedFolder=1
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 25th December 2017 at 19:45. |
