25th March 2011, 08:41 | #16702 | Link |
So far I was used to the myth that "Hardware Overlay" is the fastest renderer. Is there any reason not to use this one as default? Where has VMR-7 an advantage?
In fact, I never even tried to use VMR-7, not since the MPC family supported VMR-9 (and who does not yet use DirectX 9+?). |
25th March 2011, 08:53 | #16703 | Link |
VMR-7 (windowed) is very stable.
Overlay Mixer is buggy, if the video has a width or height not divisible by 16. It is observed on the integrated video decoder in software mode. VMR-9 (renderless) sometimes has problems. Wrong to do by default. |
25th March 2011, 12:58 | #16704 | Link | ||
_
With ffdshow, problem is still here ? By the way, no need to remove a renderer, and WMR-7 is already default one. |
25th March 2011, 14:35 | #16705 | Link |
It is a bug in the internal decoder. ffdshow works fine.
MPC-HC 2.2.1 |
27th March 2011, 02:04 | #16707 | Link |
I have a question:
Is this playback settings guide as helpful as it can be? http://files.nyaa.eu/HOW_DID_I_PLAYED_BACK.txt
Running Win7 laptop with Nvidia GT120M card, 267.xx drivers. |
27th March 2011, 03:18 | #16708 | Link | |
primus inter pares
KornX
Field Application Engineer Advanced Micro Devices |
27th March 2011, 08:52 | #16710 | Link | |
_
You mean Winamp visualisation style ?
I guess you'll prefer a dedicated audio player. I mean I don't think there will ever be a developer to transform MPC into an Audio Player reference. Quote:
Haali Media Splitter seems to be less good than LAV Filters (for me). madVR is the reference video renderer; EVR Sync is not developed anymore I think (?). I would also recommend to disable all internal filters until Nevcairiel's one are merged in MPC-HC Core. There's also new decoder from Nevcairiel (GPU accelerated for nvidia cards); Some people would also mention reclock, powerstrip, autofrequency, coreAVC,etc. http://forum.doom9.org/showthread.php?t=157897 worths reading even if it's not perfect. |
27th March 2011, 12:19 | #16711 | Link |
primus inter pares
@sneaker_ger
thx, i know... but i was hoping for a "portable version"... and I still hope sb wants to integrate it cause there seems to be some buffering...
27th March 2011, 12:34 | #16712 | Link |
@darkw1zard: Dxdiag.exe usually gives a good impression on the status of DirectX components. It's usually a combination of outdated audio and video drivers that give this type of problem. Dxdiag can indicate errors, the build date of components and most importantly, the video DDI version of the installed hardware and software. DDI level 9.0 is the bare minimum for the current renderers. Both x86 and x64 executables will have to be checked on x64 systems.
@KornX: EVR renderers can use larger buffers, but the EVR mixer, the OSD renderer and the subtitle renderer generally store images in video memory. Increasing the buffers to more than 4 will generally lower performance a lot. System memory is rather unsuitable for video, so it's avoided as much as possible. Ffdshow can buffer a few frames if you enable it in the options, but I doubt it has any positive impact at all. @neoufo51: I hope you can use this. Notes about the discriptions in the playback advice list: -Using a fresh, recent installation of MPC-HC, decoders and splitters is of course a good thing. The popular decoders and splitters have been discussed a lot in this thread. I can only advise people to consider them, and of course update the software once in a while. -Rebooting for software installation/removal is for changing core system files used during boot time (such as security updates from Windows Update), or the system-mode hardware abstraction layer (low-level hardware drivers). Regular software doesn't require rebooting, it doesn't have any advantages since Windows 2000. -EVR Sync isn't the best choice in all cases. It's actually quite a bit behind the renderer used by EVR CP and VMR-9 (renderless) (these two are only different in terms of mixers). It's worth it to try the different renderers with different rendering settings, to see what works well for you. I must note we coud use some developers to get EVR Sync updated, as I don't have enough time to work on it and there are no active developers to even check for math or typing errors. -I might be able to get other resizers integrated soon. I've already written some better multi-pass resizers. I just need to find a way to make rotation work properly with those. -The advice for the subtitle items is completely correct. It might be worth noting that some animated subtitles are too much for the heavily outdated subtitle renderer. Even on my main PC I have to disable subtitle animation with some sample files. -I disagree on the DXVA part. DXVA is perfectly fine for AVC and VC-1 to reduce the processing load on the CPU, as long as you feed it 8-bit 4:2:0 chroma down-sampled video. (Higher quality video data seems to be very difficult to decode properly by software decoders, too.) -The screenshot functions in the main trunk build are broken in combination with 10-bit, half floating point and full floating point processing. I added a dirty fix for it in my builds some time ago, but BMP saving is still broken, and there's no option to save images processed by the renderer. -I personally prefer to convert a saved PNG screenshot to a final image with external tools (I use GIMP and OptiPNG), so I can select compression options myself. I really don't advise to use JPEG compression with the common 4:2:0 chroma down-sampling for snapshots. As the images are down-scaled a lot, chroma (color difference to the reference grayscale) detail will almost always become an important factor in the perceived image quality. For regular saved images it matters a lot less, as the source is usually 4:2:0 chroma down-sampled too. The only way to save a processed image is to press "print Screen" on the keyboard during rendering, and paste the resulting image in an image editor (even Paint suffices). -Audio is certainly a lot easier. (Unless you are into multi-channel mastering, VST chain filtering, live work, et cetera, like me.) It's nice that the text also mentions the less common (but excellent) lossless audio formats.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv Last edited by JanWillem32; 27th March 2011 at 12:40. |
27th March 2011, 15:15 | #16714 | Link |
quack quack
KornX, what would be the point of the large buffer? What will it achieve?
MPC-HC should start dropping some of it's internal filters. Starting with the TS splitter, to be replaced with the LAVfilter one. Would be nice if the MPC-HC audio switcher could support VSTs. Then I could install a proper compressor to normalize the volume output a bit. Last edited by mr.duck; 27th March 2011 at 15:19. |
27th March 2011, 17:43 | #16715 | Link |
primus inter pares
expl:
ongoin IO > buffer empty, nothing to decode > framelag bigger buffer > ongoin io > still data to decode and display (like the purpose of every buffer)
27th March 2011, 21:10 | #16717 | Link |
Can you tell me what you think are the best settings? I'd like to create a text file like the one I posted for people who want the very best quality.
27th March 2011, 21:59 | #16718 | Link |
OK I am trying 10bit again after upgrading to the latest drivers for my ATI HD2400 and the latest ffdshow and mpc-hc builds.
STill cannot get it to work. I am connected to my Project via HDMI. I have aero set to disable when running MPC-HC and Fullscreen enabled yet this is what I get: |
27th March 2011, 22:15 | #16719 | Link |
MPC-HC Project Manager
Please post a new screenshot with "CTRL+J" statistics active.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
27th March 2011, 22:22 | #16720 | Link | |
_
I guess he already tries to maintain ffdshow project. He can't do fixes for all ffmpeg projects... You can use ffdshow if you don't want this issue.
But you can google what I said in my previous post. JanWillem32 gave you some hints too. But using a text file is not the best support today for beginners. You can try to make a thread on the subject here; maybe some people will help... |
