9th January 2008, 06:52 | #582 | Link |
Pig on the wing
Hi Fizick,
a small bug regarding the source clip in MVTools functions, see this thread: http://forum.doom9.org/showthread.ph...99#post1084799. Somehow it seems that they don't assume "last" as the source. On my system, if I don't specify "last" in MVDegrain2, I usually get an unrecognized exception error when loading the script.
11th January 2008, 03:51 | #585 | Link | |
Avisynth Developer
Your MV filters typically declare an argument definition like "c[mvbw]c[mvfw]c...". This declares the filter requires at least 1 clip and optionally support upto 3, which is not really the case, the filter actually needs 3 clips. The [...]'s make an argument optional and give it a name. Unfortunatly there is no syntax for named mandatory arguments. To get correct implicit last processing you will have to give up the clip argument naming and use the form "ccc..." |
11th January 2008, 16:39 | #586 | Link |
AviSynth plugger
Terranigma, probably not before I merge this contribution
http://forum.doom9.org/showthread.ph...03#post1084103 and consider IanB's "ccc..." suggestion
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
11th January 2008, 16:49 | #587 | Link |
*Space Reserved*
Oh ok, thanks for the answer. I think I found something with tritical's latest colormatrix; on one source I have, the whole video is green. I guess I should let tritical know about this, and ask for him to let me upload the video to somewhere, like a private server, so that he may check it.
14th January 2008, 11:23 | #588 | Link |
Posts: n/a
I want to learn how to great mask using MvMask. I tried alot, but it is some how complicated for me,
script: DGDecode_mpeg2source("C:\Documents and Settings\vesi\Desktop\Test\test.d2v") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mvtools.dll") tfm(order=1).tdecimate(hybrid=3) crop( 4, 60, -10, -56) Spline36Resize(624,272) # Spline36 (Neutral) FFT3DFILTER(sigma=2.1,bw=32,bh=32,ow=16,oh=16,bt=3, sharpen=0.8) O. Now I don't know should i use MvMask before resizing and denoising or after? |
14th January 2008, 13:24 | #589 | Link |
@ Vesi: what result or what operation are you trying to achieve? MVMask on its own doesn't do anything useful to the source. It just produces a mask, which then can be used to do different things.
14th January 2008, 17:51 | #590 | Link | |
FFT3DFILTER(sigma=2.1,bw=32,bh=32,ow=16,oh=16,bt=3, sharpen=0.8) and it will have most affect on non detailed areas like Walls and clear blue sky but leave detailed areas like grass alone. or maybe an edge finder that masks out all non edges then you could sharpen just the edges to get some edge pop. While you are at it how about an example of color masker so you can change all blue sky in some scene to sunset orange |
14th January 2008, 20:55 | #591 | Link |
Posts: n/a
Didee; as i'm totaly noob to scripting, i have seen some rips to have some kind of mask, and i found in MvTools MvMask, and i thought i can do this with my normal script... with good sources or bad to use denoisers like fft3d, removegrain and degrainmedian and shrpner seesaw or lsf and creat a mask. i am sure i am wrong 90% but i have read the mvtools documentation, and that was honistly for me some advance work that i couldn't make it alone, and i asked here that how to do this for different type of source and why to creat mask on the rip?
if this post is out of topic, should i open a thread? |
16th January 2008, 09:39 | #593 | Link |
This problem was for the most part solved a long time ago and many great papers have been written on this topic. Noise is mostly random where as detail is not. Even a non random pixel chess pattern mixed in that might be seen as detail spatially will not temporally. Detail will track across frames without much basic change so your cloud example is not as hard to deal with as you think.
16th January 2008, 09:57 | #594 | Link |
Think what you want to think. For me the problem is not solved and will not be solved until semantic recognation of images are implemented. Till then all great papers just describe a suboptimal solution where some work better (MV Tools) but most not. This is also the reason why you must do finetuning for every Filter available and the word 'best' is forbidden here.
16th January 2008, 10:05 | #595 | Link |
It's easy to get excited when reading some papers. But usually there's a rude awakening following up. It's called "practice".
From your various hooray's and icandobetter's over the last days, we've heard only your speech, but didn't see any practice.
17th January 2008, 13:00 | #596 | Link | |
17th January 2008, 13:29 | #597 | Link | |
note: as for "practice" my latest 300 encode is the best yet and it will get better and better because I have a lot to learn still. |
17th January 2008, 13:59 | #598 | Link | |
But you're missing the point. There was a query for suggestions. I made a suggestion. I showed screenshots, offered a test encode, and, most importantly, showed the script that does the processing, and gave explanations about the how and why. Now, you say you can get better results by more simple means. Sounds exciting, but there are no screenshots or samples to give an idea of how "better" does look like. Not to speak of a script that other people could try out, too. So far you showed exactly nothing. If I'd tell you I could turn lead into gold, you would not believe my bragging. You would ask for proof. There's no sarcasm in that.
