26th May 2004, 00:51 | #41 | Link | |
26th May 2004, 03:34 | #42 | Link |
Retired, but still around
Found a small new pet for you to care for. 1.0.2 - Load the project file. I get a memory error. Hopefully it will replicate for you.
How to Optimize Bitrate for CCE multipass |
26th May 2004, 05:28 | #45 | Link | |
all it shows is 21/24 --- the 4:3 stream OR DGindex is somehow cropping to 4:3 since DGindex says 16:9 in stats window but shows 4:3 in preview and indexes the 4:3. my cards HDTV app viewer shows the 16:9 fine but I can't get DGindex to see it. (I will have to try a bunch of PIDS since HDTVtompeg does not see it either) I will send you a clip tomorrow. (right now I'm gonna search for some apps to detect PIDS) |
26th May 2004, 07:21 | #47 | Link | |
I then deleted the DGindex .ini file and started from scratch it worked fine then. (note this was version 1.0.1) then i encoded and VDub aborted on the last frame on both passes ever have one of those nights were nothing went right? grrr..... anyway I cut at a GOP next and it didn't abort on last frame on the next try so it appears to be related to that. i will DL 1.0.3 and test as soon as i can. thx Last edited by Zep; 26th May 2004 at 07:24. |
26th May 2004, 07:27 | #48 | Link |
HDConvertToX author
Hi Neuron2
I have a little problem with (all version, even dgmpgdec103) DVD2AVI. I capture via DreamBox (sat receiver) and i always have several .ts files because every GB the recording application create a new file. So i have (example) TNG-ep1.ts TNG-ep1.ts.001 TNG-ep1.ts.002 ... and so on. With ProjectX i haven't problem to demux all file in contatenate way, so at end i have 1 TNG-ep1.mpv and several TNG-ep1.mpa. With DvD2AVI i could make an index of first file (TNG-ep1.ts) but, either in auto load or in sigle "drop" i cannot indexes TNG-ep1.ts.001 or TNG-ep1.ts.002. I had put online an initial fragment of second segment ( http://www.64k.it/andres/DreamBox.ts.001 ) (5mb) Could please analize it ? Thanks BHH EDIT: spell typo |
26th May 2004, 08:59 | #49 | Link | |
my guess is you need to rename the files from ep1.ts.001 to ep1.001.ts (download a batch file renamer app to make it easy) so that DGindex knows what the files are. this is one area i prefer the mac file system. the extension is not the primary tag, the meta data is, so you do not need extensions in OSX and they are used as a fall back if meta data is not used (rare) it means ep1.ts.001 and ep1.001.ts are both seen as .ts files. i wish XP would use meta data too. Ahhh well... windows has stuff that is better than macs also so it all balances out and why i use both about 50/50 these days. |
26th May 2004, 12:25 | #51 | Link |
As the Zep meister said, we use the file extension to know when to use transport stream parsing. An alternative would be to force the user to set a menu option. What is the consensus out there?
Project X knows he always has transport files, so the issue does not arise for him. |
26th May 2004, 19:23 | #54 | Link | |
Can you autodetect? If not I say setting a menu option to as an example for me that ALL files are .tp would be great. for buzzqw he would set .ts A menu with all supported types/extensions would also show everyone that vauble info at a glance. (sure it is in the docs but right in the app would be great too and solve this problem ) Last edited by Zep; 26th May 2004 at 19:26. |
27th May 2004, 16:13 | #55 | Link |
Version 1.0.4 adds MPEG audio demux for transport streams
Version 1.0.4 adds MPEG audio demuxing for transport streams.
BTW, I am now interested in getting audio delay detection as good as I can. So, if anyone has any quirks to report in this regard, I'd appreciate your streams for analysis. BTW2, I found some transport streams never send any video PTS. In such cases, or if the calculated delay is greater than 5 seconds, I suppress the delay calculation from the filename. If you don't see a DELAY figure in your filename, that means I was unable to calculate a reliable one. BTW3, I found a stream that carried a PAT but no PMT! In such cases, I cannot determine what audio type to decode with on the specified PID, so I just try MPEG audio. This may change to allow manual specification in such cases, but I don't think this is a widespread issue. http://neuron2.net/fixd2v/dgmpgdec104.zip @CruNcher I've solved the problems with PVA audio, so you should be seeing support for that soon. Last edited by Guest; 27th May 2004 at 16:17. |
27th May 2004, 17:00 | #56 | Link | ||
Re: Version 1.0.4 adds MPEG audio demux for transport streams
much needed So far sync is off 90% of the time for me. the AC3 delay value is always way off. and the decode to wav same problem. it is fine when the cards app plays the .ts but for encoding via d2v the audio is always early for me. around 500ms to 800ms 90% of the time (but it has been as high as 1500ms) I never get audio that plays late. Quote:
wow nice gonna DL this sucker right now |
28th May 2004, 04:45 | #58 | Link |
Thanks for your great work neuron2. Here is another test stream:
http://demod.dvico.com/hdtv/Australia_1.tp |
28th May 2004, 05:25 | #59 | Link | |
but everyone i sent you thus far except the ABC stream has that problem i will send a clip now thx UPDATE: sending 23 meg clip that was about 700ms early on audio. (well at least that is what i had to offset in VDub to get it in sync. it does play in sync with the app that came with myHD card though so something along the chain to encoding is off on my PC) Last edited by Zep; 28th May 2004 at 05:33. |
28th May 2004, 06:01 | #60 | Link |
Umm, Zep.
When you send me a clip for AV testing there has to be some synced content so I can tell when the sync is right. What am I going to do with a voice-over? You know, like someone talking where you can see the lips moving. Thanks. Also, please name streams you refer to. I get a lot of stuff and I can't remember everything you sent me. I mean I still have them in my streams directory, but which came from you??? Last edited by Guest; 28th May 2004 at 06:13. |
