18th December 2016, 19:07 | #201 | Link |
Hi there,
When I was testing if fmtconv could make transforms from 709 content to ciexyz content, I may have encountered a possible bug. I either get a segmentation fault or completely black output when converting 709 primaries to ciexyz primaries. Code:
import vapoursynth as vs core = vs.get_core() core.std.LoadPlugin(path=r'/usr/local/lib/vapoursynth/libimwri.so') clip = core.ffms2.Source(r'/home/andy/Sample.mkv') clip = core.std.Trim(clip, 2300, 2300) clip = core.fmtc.bitdepth(clip, bits=32, dmode=6) clip = core.fmtc.matrix(clip, mats='709', matd='RGB', col_fam=vs.RGB, bits=32) clip = core.fmtc.transfer(clip, transs='709', transd='linear', bits=32) clip = core.fmtc.primaries(clip, prims='709', primd='ciexyz') clip = core.fmtc.transfer(clip, transs='linear', transd='2084', cont=1000/10000, bits=32) clip = core.imwrif.Write(clip, 'EXR', 'image%04d.exr', firstnum=0) clip.set_output() |
21st February 2017, 08:44 | #202 | Link |
HLG transfer function support
Any plans to add HLG transfer function support in an upcoming release? By my reading of the documentation, I can't see anything referencing ARIB-STD-B67 (Hybrid Log Gamma, HLG) EOTF.
Would love to have it, Technicolor guys gave me an asset in HLG and I'm hoping to use fmtconv to do the conversion to HDR10 to feed into my currently limited STB client - the broadcom chipset doesn't support HLG afaik. |
21st February 2017, 09:35 | #203 | Link | |
Cary Knoop
21st February 2017, 10:44 | #204 | Link | |
Professional Code Monkey
21st February 2017, 22:57 | #205 | Link |
Ahh yes... took a look at this though and while I'm still using R32 (and probably need to upgrade to VS R36) just want to be sure that upgrading will address the fact that R32 doesn't seem to like the "transfer_s" parameter...? Right now I can't get it working due to specifying the transfer output function as a string, seeing as I don't know the enumerated value for st2084.
21st February 2017, 22:59 | #206 | Link |
It wasn't implemented back then
27th February 2017, 23:59 | #208 | Link | |
Cary Knoop
Also when I use the bits parameter in transfer() from '709' to 'linear' I get: matrix: output bitdepth not supported. |
17th March 2017, 20:21 | #210 | Link |
Also, could SMPTE ST 2085 matrix conversion and ICtCp matrix conversion be implemented? They are supported in the latest version of HEVC, and used for HDR content. SMPTE ST 2085 is used with CIEXYZ primaries, while ICtCp can be used with any primaries.
Thanks! |
17th March 2017, 23:21 | #211 | Link |
Excessively jovial fellow
The VS builtin resizer (zimg) has support for ICtCp being worked on as of right now. You should probably consider porting existing code to zimg as well; it's pretty much just flat out better than fmtconv, and it's in active development (unlike fmtconv which hasn't had any activity at all in the last year). It also has more contributors and users than fmtconv since it's a general-purpose C/C++ library and not tied to a filtering framework like VS or Avisynth. It's available in ffmpeg via libavfilter's vf_zscale, for example.
I don't think there are any features fmtconv has that the internal resizer (that is zimg) lacks, anymore. If there are, submit a feature request. http://www.vapoursynth.com/doc/functions/resize.html Last edited by TheFluff; 17th March 2017 at 23:31. |
18th March 2017, 09:18 | #212 | Link | |
How to handle interlaced content? (In fmtconv there is interlaced&interlacedd. Do the resizers automatically handle and keep the interlacing state the source is in?) Whether there are more resizers available than Bilinear/Bicubic/Point/Lanczos/Spline16/Spline36 through zimg? (fmtconv has point/box/bilinear/cubic/bicubic/lanczos/blackman/blackmanminlobe/spline16/spline36/spline64/spline/gauss/sinc ) |
18th March 2017, 14:31 | #213 | Link | |
No. None of the extra ones are all that useful anyway. |
18th March 2017, 16:28 | #214 | Link | |
18th March 2017, 16:37 | #215 | Link | |
Blackman is a bad windowed sinc; use lanczos instead. |
18th March 2017, 16:44 | #216 | Link | |
I'm Siri
a. it works with any radius (using the "taps" parameter) b. it does not require you to manually calculate the coefficient matrix, you could simply control the filtering strength using the "p" parameter. Last edited by feisty2; 18th March 2017 at 16:47. |
18th March 2017, 16:49 | #217 | Link | |
Another example is feisty2's Vine/Plum. Last edited by WolframRhodium; 18th March 2017 at 16:52. |
18th March 2017, 16:58 | #218 | Link | |
18th March 2017, 17:07 | #219 | Link |
I'm Siri
gaussresize is already highly optimized as a part of the resample function in fmtc, I could write a Gaussian filter any day of the week but I'm NOT a professional programmer, so that's gonna be a lot worse (performance-wise) than the existing gaussresize approach anyways, and I'm definitely not wasting my time just to mess with stupid things like that.
