19th April 2011, 22:37 | #1461 | Link |
You should be able to open the stats file in any text editor. Perhaps it is too large for notepad, use something better. You won't be able to see much in the mbtree file because it is a binary file.
x264 log explained || x264 deblocking how-to preset -> tune -> user set options -> fast first pass -> profile -> level Doom10 - Of course it's better, it's one more. |
5th May 2011, 03:21 | #1464 | Link |
zj262144
About r1944
why not turn off psy-rd <RD:Trellis> when set subme<6 or trellis=0 as before? I think that's the right info for users... even I want to advise deleting deadzone info when used trellis=2 at the same time... and also about merange on umh/esa/tesa maybe 4~256 is a good valid range
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14 Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated) Last edited by upyzl; 5th May 2011 at 03:38. |
5th May 2011, 05:33 | #1465 | Link | ||
5th May 2011, 10:00 | #1466 | Link |
zj262144
@MasterNobody
Thanks very much for the explanation Now I understand...
MPC-HC 1.7.8 / LAV Filters 0.64+ (tMod) / XySubFilter 3.1.0.705 / madVR 0.87.14 Direct264 Mod (src & win32 builds): code.google.com/p/direct264umod (maybe outdated) |
6th May 2011, 17:02 | #1467 | Link |
It makes them a little more than obsolete. It causes x264 to fail with an error that it can't open the option. Because --open-gop no longer has options, the very next word in the line is considered the file to open because it doesn't start with --.
I got caught with that and couldn't figure out why it couldn't open "none" when it was an option for --open-gop. I removed "none" as a test and discovered that it now worked. It would have been nice if x264 still looked for a potential option and if so, spit out a warning that it is now obsolete and reference --bluray-compat in the warning. After the failure, I started digging and a posting over on Doom10 pointed to this thread. That resulted in my changing some more stuff in my CLI (adding the --bluray-compat option and removing two others). |
7th May 2011, 02:08 | #1468 | Link |
Question about the recent changes
Below is the CLI I use for encoding video so that I can edit it with VRD:
x264 --pass 2 --profile high --level $LEVEL --bitrate $BITRATE --ref $REF \ --deblock 1:-1:-1 --me umh --subme 10 --psy-rd 1.00:0.15 --merange 24 \ --trellis 2 --deadzone-inter 21 --deadzone-intra 11 --fast-pskip \ --threads 12 --slices 4 --nr 0 --bframes 3 --b-pyramid strict \ --b-adapt 2 --b-bias 0 --direct auto --weightp 0 --keyint $KEYINT \ --min-keyint 1 --scenecut 40 --rc-lookahead 60 --ratetol 1.0 \ --qcomp 0.60 --qpmin 10 --qpmax 51 --qpstep 4 --cplxblur 20.0 \ --qblur 0.5 --vbv-maxrate $MAXBITRATE --vbv-bufsize $BUFSIZE \ --ipratio 1.40 --aud --nal-hrd vbr --open-gop $INTERLACED \ --sar $SAR --qpfile "${DIRNAME}/${NAME}_qpfile.txt" \ --input-res $RES --stats "${DIRNAME}/${NAME}.stats" \ --output "${DIRNAME}/${NAME}.264" \ "tmp.fifo.yuv" Before the recent changes, the --open-gop had none as its option. What the above did for me is create IDR frames at the locations where I frames are normally placed and at locations set in the qpfile. But now, instead of IDR frames, it is only I frames. How do I get IDR frames back? Why was the functionality of IDR frame generation removed, or was it an error in the first place and I stumbled upon it? |
7th May 2011, 02:16 | #1469 | Link |
If you use "K" it will depend on your open-gop setting - you can still force "I" or "i". Or does this not work for you?
/edit: To make sure I get you straight: 1.) Before, you had open-gop deactivated ("--open-gop none") 2.) Now you have open-gop activated ("--open-gop") and you're wondering why x264 behaves differently? Last edited by sneaker_ger; 7th May 2011 at 03:09. |
7th May 2011, 05:32 | #1470 | Link | |
Doing a little digging, a posting over on Doom10 (think it is a page back here as well) indicates that without --bluray-compat the --open-gop acts as it was --open-gop cbrHD under the old code. But, cbrHD was not an option, as they were none, normal and bluray. Because the posting didn't make sense, it was shoved aside. While the developers understand what is going on with the changes, we poor users are sorta left out in the cold. I'd like to see a dedicated thread, as described above, as that would really help us users. |
8th May 2011, 07:38 | #1474 | Link |
http://mailman.videolan.org/listinfo/x264-devel
A small warning though. When a new update batch is pushed out every couple of weeks, you'll get an email with a newsletter summarizing what changed plus and email for each change. |
8th May 2011, 11:14 | #1475 | Link | |
Thanks for the info. |
11th May 2011, 07:56 | #1476 | Link |
If i see it right, the minimal encoding arguments for 1080p23.976 / 1080p24 bluray compatibility are :
--bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --keyint 24 --slices 4 Btw. the --fullhelp about --bluray-compat should list the parameters that would be set (e.g.: http://forum.doom9.org/showthread.ph...13#post1493513 ) |
11th May 2011, 08:08 | #1477 | Link | |
11th May 2011, 08:13 | #1478 | Link |
Even knowing that your target is Blu Ray there are two possible vbv values for 1080p. This also affects the number of slices. Depending on that there are also two different keyint parameters that are valid. Just by that commandline x264 can't know which of the two you want. See the Blu Ray encoding sticky.
11th May 2011, 08:59 | #1480 | Link | |
So x264 must know witch level should be used. Idea: --bluray-compat used highest level (--level 4.1) as default, but the user can add --level 4.0 So there are any information to calculate all needed restrictions values (e.g. max bitrate, buffer size etc.) btw. is there ever a reason to use a smaller level than 4.1? All bluray players should play level 4.1, isn't it? |
coding, development, x264 dev |
