23rd September 2010, 14:12 | #1242 | Link |
I downloaded the x264 version to encode raw .yuv to lossless .264 using the following cmd:
D:\sequences\CIF>x264 --partitions "all" --qp 0 --keyint 2 --input-res 352x288 -o frmanls.264 foreman_cif.yuv yuv [info]: 352x288p 0:0 @ 25/1 fps (cfr) x264 [info]: using cpu capabilities: MMX2 Cache64 x264 [info]: profile High 4:4:4 Predictive, level 1.3, bit depth 8 x264 [info]: frame I:150 Avg QP: 0.00 size: 71310 x264 [info]: frame P:150 Avg QP: 0.00 size: 54972 x264 [info]: mb I I16..4: 3.7% 11.8% 84.5% x264 [info]: mb P I16..4: 0.1% 9.9% 4.6% P16..4: 51.8% 18.6% 9.5% 3.4% 2.1% skip: 0.0% x264 [info]: 8x8 transform intra:18.9% inter:66.1% x264 [info]: coded y,uvDC,uvAC intra: 100.0% 100.0% 100.0% inter: 99.7% 100.0% 100.0% x264 [info]: i16 v,h,dc,p: 14% 76% 8% 2% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 55% 13% 1% 2% 2% 2% 1% 2% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 37% 7% 3% 11% 5% 6% 4% 4% x264 [info]: i8c dc,h,v,p: 7% 40% 52% 1% x264 [info]: Weighted P-Frames: Y:0.0% x264 [info]: kb/s:12628.21 encoded 300 frames, 27.08 fps, 12628.21 kb/s Then I use the jm17.2 to decode the frmanls.264 to raw .yuv, but I found the reconstructed .yuv is corrupted. There is red blocks and corrupted bottom borders. Is it a bug in x264 or a bug in jm17.2? Edit1: I download the official x264 and find the same problem.
The Next Generation Internet Video Codec project.[/url]. Last edited by schweinsz; 23rd September 2010 at 14:32. |
23rd September 2010, 14:45 | #1243 | Link | |
23rd September 2010, 15:04 | #1244 | Link |
I suspect your opinion. I ever explored the jm code and found many code related to lossless with the following style:
if(currMB->is_lossless) { if ((currMB->c_ipred_mode == VERT_PRED_8)||(currMB->c_ipred_mode == HOR_PRED_8)) Inv_Residual_trans_Chroma(currMB, uv) ; else { for(j=0;j<p_Vid->mb_cr_size_y;j++) for(i=0;i<p_Vid->mb_cr_size_x;i++) currSlice->mb_rres [uv+1][j][i]=currSlice->cof[uv+1][j][i]; } }
The Next Generation Internet Video Codec project.[/url]. |
23rd September 2010, 15:38 | #1245 | Link |
If I recall correctly it supports the old (I forget what it was called) lossless standard but not the new one (High 4:4:4 Predictive Profile Lossless).
23rd September 2010, 18:07 | #1246 | Link |
Software Developer
Indeed, x264 uses the "High 4:4:4 Predictive Profile" in lossless mode. That profile isn't supported by some decoder, quite possible that JM reference is among them.
The H.264 decoder from 'libavcodec' (which includes ffdshow, MPlayer, VLC and friends) as well as 'CoreAVC' do support it though...
24th September 2010, 04:22 | #1247 | Link | |
24th September 2010, 23:18 | #1249 | Link |
Rallymax
libavcodec/libx264.c defaults and x264_validate_parameters()
Hi team,
I did an update of the libav* codebase to get some new features - which in turn required a higher version of x264 so I updated that too. Not a problem I rebuilt libav* and libx264. The x264_validate_parameters() is failing. I've seen this before and last time I simply commented the libx264.c x4->param changes out and used the x264 defaults instead. I also commented out the x264_validate_parameters#76 score code because I was more worried about getting the thing to run. But.... I know that's not the right thing to do since it's there, most likely, for a very good reason. What should I be doing to to the x4->params.* in libavcodec/libx264.c to get this to not fail? I actually need the parameters to make it a legal BluRay stream. When I commented out the code (above) that changed the parmeters and left it as defaults it processed fine and made a playable stream but Adobe Encore wouldn't recognize it as a legal stream and wanted to re-encode it and thus defeated the whole purpose of making a program using the BEST ENCODER IN THE WORLD!!! to ditch the AWEFUL encoder bundled from Adobe. Did the NAL HRD patch get folded in since Feb '10? If not does that patch still work? thanks, Rallymax Here is the output of the out-of-box libavformat/output-example.c using the libav*.DLLs and libx264-105.DLL... Code:
$ ./output-example xxx.h264 Output #0, h264, to 'xxx.h264': Stream #0.0: Video: libx264, yuv420p, 352x288, q=2-31, 400 kb/s, 90k tbn, 25 tbc [libx264 @ 003e1100] broken ffmpeg default settings detected [libx264 @ 003e1100] use an encoding preset (vpre) could not open codec Last edited by rallymax; 24th September 2010 at 23:29. Reason: Found more info... |
24th September 2010, 23:28 | #1250 | Link | ||
Software Developer
(FFmpeg is known to set rather "bizarre" default settings for x264, so x264 will detect "broken" FFmpeg default settings to protect the user. Don't know if FFmpeg ever fixed their x264 default settings) The commit message shows an example on how to configure x264 for BluRay compatibility...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th September 2010 at 23:46. |
24th September 2010, 23:38 | #1251 | Link | ||
Rallymax
static av_cold int X264_init(AVCodecContext *avctx) { X264Context *x4 = avctx->priv_data; x4->sei_size = 0; x264_param_default(&x4->params); <--------------- x4->params.pf_log = X264_log; x4->params.p_log_private = avctx; thanks. |
24th September 2010, 23:41 | #1252 | Link | |
Software Developer
Not my work though
As far as I understand, you use libx264 indirectly, through libavcodec. Why not call libx264 directly ???
24th September 2010, 23:52 | #1253 | Link |
Rallymax
I'm using libavformat to make the m2ts container so that it's muxed with AC3 too.
[edit] oh, I also use libswscale and the RGB -> YUV planar conversion functions so it's just easier to call the libavformat front end based off of the output-example and have it then call the x264 library for me.[/edit] Unfortunately libavformat's mpegts muxer is implemented for true MPEG-TS (vs the slight modification of the timestamp header for .MTS). In many hours of Googling I'm yet to find out what the increment value is of the 4byte timecode on the front of the 188byte mpegts packet. I'm of the impression that it's something to do with the real time divided by the current vbr value. I've hacked that into libavformat/mpegtsenc.c to add ".mts" but will need to fix the increment rate eventually so that, I think, BluRay players can scrub fwd/rev properly. This MPEG-TS & Timecode hack for Bluray is Wikipedia info on the issue. You wouldn't happen to have an info on that would you? Last edited by rallymax; 24th September 2010 at 23:54. |
24th September 2010, 23:56 | #1254 | Link | |
Software Developer
(BTW: If you are hacking FFmpeg anyway, why not kick out everything they overwrite in 'x4->params' after the x264_param_default() call, except for the things you really need?)
24th September 2010, 23:59 | #1255 | Link | |
Rallymax
yes, I'm going to blow away all the libx264.c changes to the defaults and just plug in the ones needed to make BluRay based on the x264 arguments given on the google doc page for legal bluray. I think we're on the same page. |
25th September 2010, 01:03 | #1256 | Link | |
Rallymax
Now to pop in the BluRay values... Code:
$ ./output-example.exe xxx.h264 Output #0, h264, to 'xxx.h264': Stream #0.0: Video: libx264, yuv420p, 352x288, q=2-31, 400 kb/s, 90k tbn, 25 tbc [libx264 @ 00544500] using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 [libx264 @ 00544500] profile High, level 1.3 [libx264 @ 00544500] non-strictly-monotonic PTS Last message repeated 49 times [libx264 @ 00544500] invalid DTS: PTS is less than DTS [libx264 @ 00544500] non-strictly-monotonic PTS [libx264 @ 00544500] invalid DTS: PTS is less than DTS [libx264 @ 00544500] non-strictly-monotonic PTS [libx264 @ 00544500] invalid DTS: PTS is less than DTS [libx264 @ 00544500] non-strictly-monotonic PTS Last message repeated 121 times [libx264 @ 00544500] frame I:1 Avg QP:23.49 size: 2556 [libx264 @ 00544500] frame P:31 Avg QP:22.84 size: 903 [libx264 @ 00544500] frame B:93 Avg QP:29.04 size: 558 [libx264 @ 00544500] consecutive B-frames: 0.0% 0.0% 0.0% 100.0% [libx264 @ 00544500] mb I I16..4: 78.3% 15.7% 6.1% [libx264 @ 00544500] mb P I16..4: 77.2% 4.7% 0.3% P16..4: 17.1% 0.4% 0.2% 0.0% 0.0% skip: 0.0% [libx264 @ 00544500] mb B I16..4: 0.0% 0.0% 0.0% B16..8: 14.3% 0.2% 0.0% direct:25.0% skip:60.5% L0:57.1% L1:38.6% BI: 4.2% [libx264 @ 00544500] 8x8 transform intra:6.1% inter:41.6% [libx264 @ 00544500] coded y,uvDC,uvAC intra: 3.3% 27.8% 4.9% inter: 0.2% 42.2% 6.3% [libx264 @ 00544500] i16 v,h,dc,p: 0% 0% 0% 100% [libx264 @ 00544500] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 0% 29% 3% 66% 0% 0% 0% 1% 0% [libx264 @ 00544500] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 0% 9% 20% 69% 0% 0% 0% 1% 1% [libx264 @ 00544500] i8c dc,h,v,p: 0% 3% 7% 89% [libx264 @ 00544500] Weighted P-Frames: Y:0.0% [libx264 @ 00544500] ref P L0: 91.5% 0.7% 6.5% 1.2% [libx264 @ 00544500] ref B L0: 66.4% 26.5% 7.1% [libx264 @ 00544500] ref B L1: 97.9% 2.1% [libx264 @ 00544500] kb/s:-0.00 |
25th September 2010, 01:04 | #1257 | Link | |
x264 developer
Of course, it's better to just do it right, and you'll have to modify the code if only because not all necessary options are exposed (e.g. NAL HRD). |
3rd October 2010, 18:39 | #1259 | Link | |
x264 developer
Also, there was no license change, only a license addition. It's still GPL. |
coding, development, x264 dev |
