31st May 2003, 13:59 | #383 | Link |
retired developer
Great!
About speed, it would be great to optimize for AMD too, with 3DNOW and 3DNOW2. My Athlon XP can only use MMX and SSE .
Detritus Software |
31st May 2003, 16:18 | #384 | Link | |
31st May 2003, 19:24 | #385 | Link | |
RV10 Nerd
3rd June 2003, 16:27 | #387 | Link |
status update: still waiting for a 'good' build before anything can be posted. No known bugs in the RV9 encoder, but it is a large system, and sometimes unrelated build busters are checked in elsewhere in the system Development for other 9.2 features than the codec is still going strong.
In order to enable the extra high quality modes in this 1st version, one can 1) edit job file (insert codecProperties) 2) edit audience files (insert codecProperties) 3) use reg key over-rides (useful for GUI Producer with replaced encoder DLL) 4) When the GUI front-ends are updated, they will likely include these options directly (and autommatically insert the right xml code in the job or audience file) Details later. For the final 9.2 release these options will probably also be exposed as a top level command line parameter.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion. |
5th June 2003, 02:31 | #388 | Link |
hello. It's been a whole since I posted here. the new ehq mode looks pretty cool. Question though, how is that jitter thing going? I alhpa tested some DLLs for you a while back, and like I said before, it was greatly improved but not perfect. just wondering how that renderer is coming? (I ask because the nly two things holding me back from using rv9 is the jitter problem in the renderer and the excessive, uncontrollable post-processing.)
5th June 2003, 22:40 | #389 | Link | |
retired developer
Detritus Software |
9th June 2003, 17:24 | #391 | Link |
no, but another Milestone should be posted shortly, hopefully today or tomorrow
9th June 2003, 19:25 | #392 | Link |
You can now get a build of Helix Producer that has RV9-EHQ:
http://forum.doom9.org/showthread.php?s=&threadid=55193
16th June 2003, 10:07 | #393 | Link |
Karl said: "...very often I have to find out information about a RealMedia file. Specifically, I need to know the video resolution, the video bitrate, the VBR buffer, and/or the audio bitrate. Soon, also the number of channels of audio..."
I am not sure if people are familiar with tools like GSpot (doesn't support RM-files..), but yesterday I found similiar very handy software that supports ALSO RM-files! It's called AVIcodec and you can find this freeware from here: http://avicodec.duby.info/ With this message I hope I didn't hijack anyones thread or step on anyones feet. I just wanted to share this great utility I found and I am sure there are also others who have been looking for this kind of tool. (Personally, I found DC's tool too complicated and there is information I dont need) |
16th June 2003, 13:56 | #394 | Link |
RV9 Fan
Not bad at all but for rmvb files the analyse tool delivers much more information. The shell extenstion provides more basic information than AVIcodec. Nice tool though.
Ruud
"In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move." |
23rd June 2003, 17:02 | #395 | Link |
Karl:
This probably isn't the right place for reporting problems with RealOne, but since you already answered a couple of other questions regarding similar problems I am going to try anyway. The problem I am experiencing is stuttering video. If I play a rm file (no matter which codec) the video freezes in a couple of seconds. A couple of seconds later the video resumes playback. A couple of seconds later the video freezes again... All the files I tried are loaded from my local hard drive, so this isn't a bandwidth issue. I've tried old files, new files, the test files from real.com and nothing works, so it looks like it is a player problem and not a movie file problem. Things I looked at so far: - Sound keeps playing even if the video freezes. - RealOne does use a overlay. If I move the window during playback the video area lags a bit behind the player window frame, a clear sign that an overlay is being used. - MPC also experiences the same problem, with both render types. - Both RM and MPG files are affected. AVI files are not. - If I look at the 'Playback Statistics' the 'Current fps' drops to 0 during the freeze. 'Frames Dropped' increases. 'Frames Displayed' also drops to 0% momentarily. - Changing the 'Video Card Compatibility' setting does affect this problem slightly. Setting it to 'Most reliable' does increase time between freezes and the length of each freeze. The problem does not go away though. - Changing the 'Sound Card Compatibility' settings does noet affect this problem. - Downgrading to Real 8 does not solve the problem. I didn't have these problems before. Only after upgrading my system they started to appear. I use Windows XP. Athlon XP 2200+, nForce 2, geForce 2MX. Latest official drivers. |
23rd June 2003, 18:51 | #396 | Link |
@rakaz:
I am sorry, but this problem sounds nothing like anything I have seen before. Could I ask you to check if the CPU usage spikes when the video freezes? If there is a spike, is it possible to use the Task Manager to see which process causes the spike? Do frames drop, or does the video continue where it left off, and then out of sync with audio? If you go to Tools -> Playback statistics, then click on the Streams tab, and select the Video stream in the drop-down box, are any frames reported as dropped? Finally, you mentioned it happens for MPEG. Does it happen for MPEG in any other media player than Real? Thanks! Also, if you are interested in trying a pre-release version of the video renderer to see if this fixes your problem, pls send me a PM with your e-mail.
23rd June 2003, 19:53 | #397 | Link | |||||
- The video suddenly begins playing again at a keyframe and I've just lost all frames during the freeze. - The video suddenly begins playing at a i-frame and you notice some artifacts on the screen until the next keyframe. - The video suddenly begins playing out of sync and for a second or so you can see the video is trying to get back into sync (high fps). At the moment it is back in sync it starts playing normal again. This might be important: Not all of the frames that should have been displayed during the freeze will shown. Only the last couple of seconds of the frames that should have been shown are actually shown at a high fps. So most of the frames are lost. Quote:
a) the video plays correctly: Current: is 20fps, Frames Lost: 0, Frames Dropped: 0 b) the video freezes, audio keeps playing Current: is going down to 0.0fps, Frames Lost: 0, Frames Dropped: 0 c) the video starts playing again Current: is 0.0fps, Frames Lost: 0, Frames Dropped: 0 d) not more than half a second after the video starts playing Current: is going up to 20fps, Frames Lost: 0, Frames Dropped: 263 So yes, frames are dropped. Quote:
24th June 2003, 22:35 | #398 | Link |
retired developer
@Karl
Hi Karl! What's up! I have (again! ) some questions about new features of Producer 9.2. What is the new multi-channel codec? Is it based on cook? What is it's bitrate range? Thanks for your time and keep the good work!!!
Detritus Software |
25th June 2003, 03:37 | #399 | Link |
Lots of things going on, very busy, but thanks for checking in!
I will be writing a post about RA Multi-Channel shortly, its ins and outs, the different codec flavors, and how to encode RA Multi-Channel content, once I have verified how such bitstreams can be played back by the Helix Community (and readers of this forum). It will either be splay, the Helix DNA Client cmd line decoder, and/or with DLL replacements for RealOne V2. Does anyone here have more than two speakers connected to their computer ? I don't, only for my home theater setup, but now I may just have to upgrade my computer speakers In the video world, I will be experimenting with an animation mode (variable framerate encoding) for RV9. Whether or not this will actually improve anything, is not at all certain. It is not that easy to tell the difference between noise and just a small part of the animation is being updated.
25th June 2003, 22:24 | #400 | Link | |
RV10 Nerd
Edit: changed some verbage. Last edited by 31 Flavas; 25th June 2003 at 23:03. |
