9th February 2009, 12:28 | #82 | Link |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
No, plugins can not be uploaded. It's against the rules.
You will have to download them from the original source What errors do you get, Kopmjj? Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
9th February 2009, 12:38 | #84 | Link |
here my entire script...
[HTML]film="C:\Documents and Settings\king\Desktop\New Folder\mymovie.avi.avi" short="L" # L=long clip S=short clip try it! result="resultS3" # specify the wanted output here trim_begin=6 trim_end=6 play_speed=18.75 #trim frames and play speed (PAL: 16.6666 or 18.75) saturation=1.0 #saturation X=4 gamma=0.7 # X is a special parameter for reducing the autolevels effect black_level=0 white_level=255 output_black=0 output_white=255 # manual levels, when returning result4 AGC_max_sat=2 AGC_max_gain=1.0 #parameters of HDRAGC filter, improves colors and shadows blue=-4 red=2 #manual color adjustment, when returning result2. Values can be positive or negative denoising_strenght=800 #denoising level of first denoiser: MVDegrainMulti() denoising_frames= 4 #number of frames for averaging (forwards and backwards) 3 is a good start value block_size= 16 #block size of MVDegrainMulti() block_over= 4 #block overlapping of MVDegrainMulti() temp_radius=20 temp_luma=6 temp_chroma=6 #second denoiser: TemporalSoften grain_luma=10 grain_chroma=10 # this will add some digital grain to the final result, set it to zero if you do not want it. LSF_sharp_ness=250 LSF_radi_us=3 LSF_sub=1.5 #first sharpening parameters (LimitedSharpenFaster) sub=subsampling USM_sharp_ness=40 USM_radi_us=2 USM_thres_hold=0 #second sharpening parameters (UnsharpMask) USM_sharp_ness2=20 USM_radi_us2=1 USM_thres_hold2=0 #third sharpening parameters (UnsharpMask) maxstab=60 #maximum values for the stabiliser (in pixels) 20 is a good start value est_left=20 est_top=20 est_right=20 est_bottom=20 est_cont=0.8 #crop values for special Estimate clip CLeft=30 CTop=30 CRight=30 CBottom=30 #crop values after Depan and before final resizing (40,30,40,30) W=720 H=576 #final size from the returned clip bord_left=0 bord_top=0 bord_right=0 bord_bot=0 SetMemoryMax(1024) LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DePan.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DePanEstimate.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\RemoveGrain.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\HDRAGC.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mvtools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\mt_masktools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MaskTools.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\WarpSharp.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\LimitedSupport_09Jan06B.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\MT.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\autolevels.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\AddGrainC.dll") Import("C:\Program Files\AviSynth 2.5\Plugins\LimitedSharpenFaster.avs") source1= Avisource(film).assumefps(play_speed).trim(trim_begin,0).converttoYV12() end= source1.framecount() end2= end-trim_end frames=end+trim_begin skip= end2/5 skip0=skip+3 skipend= 3 skipend1= skip0+3 skip2= skipend1+skip skipend2= skip2+3 skip3= skipend2+skip skipend3= skip3+3 skip4= skipend3+skip skipend4= skip4+3 skip5= end2-3 L= trim(source1,0,end2) LS= trim(source1,0,end2).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"\ +string(trim_end),x=100,y=60,size=32)""") sourceT1= trim(source1,0,skipend).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)\ +" steps: "+string(skip),x=100,y=60,size=32)""") sourceT2= trim(source1,skip0,skipend1).scriptclip("""subtitle("frame "+string(trim_begin+skip0+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps: "\ +string(skip),x=100,y=60,size=32)""") sourceT3= trim(source1,skip2,skipend2).scriptclip("""subtitle("frame "+string(trim_begin+skip2+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps:\ "+string(skip),x=100,y=60,size=32)""") sourceT4= trim(source1,skip3,skipend3).scriptclip("""subtitle("frame "+string(trim_begin+skip3+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT5= trim(source1,skip4,skipend4).scriptclip("""subtitle("frame "+string(trim_begin+skip4+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT6= trim(source1,skip5,end2).scriptclip("""subtitle("frame "+string(trim_begin+skip5+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") SS= sourceT1+sourceT2+sourceT3+sourceT4+sourceT5+sourceT6 sourceT10= trim(source1,0,skipend) sourceT20= trim(source1,skip0,skipend1) sourceT30= trim(source1,skip2,skipend2) sourceT40= trim(source1,skip3,skipend3) sourceT50= trim(source1,skip4,skipend4) sourceT60= trim(source1,skip5,end2) S= sourceT10+sourceT20+sourceT30+sourceT40+sourceT50+sourceT60 stab_reference= eval(short).crop(est_left,est_top,-est_right,-est_bottom)\ .tweak(cont=est_cont).binarize(threshold=80).greyscale().invert() mdata=DePanEstimate(stab_reference,trust=1.0,dxmax=maxstab,dymax=maxstab) stab=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,mirror=15) stab2= stab.crop(CLeft,CTop,-CRight,-CBottom).tweak(sat=saturation) stab3=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,info=true) WS= width(stab) HS= height(stab) stab4= stab3.addborders(10,10,10,10,$B1B1B1).Lanczos4Resize(WS,HS) vectors= stab2.MVAnalyseMulti(refframes=denoising_frames, pel=2, blksize=block_size, overlap=block_over, idx=1) denoised= stab2.MVDegrainMulti(vectors, thSAD=denoising_strenght, SadMode=1, idx=1).tweak(sat=saturation) leveled= denoised.HDRAGC(coef_gain=2.0,max_gain=AGC_max_gain,min_gain=0.5,max_sat=AGC_max_sat,shadows=true) sharp1=limitedSharpenFaster(leveled,smode=1,strength=LSF_sharp_ness,overshoot=50,\ radius=LSF_radi_us, ss_X=LSF_sub, SS_Y=LSF_sub, dest_x=W,dest_y=H) sharp2= unsharpmask(sharp1,USM_sharp_ness,USM_radi_us,USM_thres_hold) sharpX= unsharpmask(sharp2,USM_sharp_ness2,USM_radi_us2,USM_thres_hold2) sharp3= sharpX.TemporalSoften(temp_radius,temp_luma,temp_chroma,15,2).addgrainC(grain_luma,grain_chroma,0.2,0.2,5) #backward_vectors = sharp3.MVAnalyse(isb = true,truemotion=true,idx=2) #forward_vectors = sharp3.MVAnalyse(isb = false,truemotion=true,idx=2) #frameclip=MVFlowFps(sharp3,backward_vectors, forward_vectors, num=25, den=1, ml=100, idx=2) result1= sharp3.addborders(X,0,0,0,$FFFFFF).levels(0,gamma,255,0,255).autolevels().coloryuv(autowhite=true)\ .crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result2= sharp3.levels(black_level,gamma,white_level,0,255).coloryuv(autowhite=true)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result3= sharp3.coloryuv(off_U=blue,off_V=red).levels(0,gamma,255,0,255).addborders(X,0,0,0,$FFFFFF)\ .autolevels().crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result4= sharp3.coloryuv(off_U=blue,off_V=red).levels(black_level,gamma,white_level,0,255)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result5= overlay(eval(short),stab_reference,x=est_left,y=est_top).addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,HS) W2= W+bord_left+bord_right H2= H+bord_top+bord_bot short2=short+"S" source2=Lanczos4Resize(eval(short2),W2,H2) source3=Lanczos4Resize(eval(short2),W,H) resultS1= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result1,"autolevels, autowhite",size=28,align=2)) resultS2= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",size=28,align=2)) resultS3= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result3,"autolevels + manual color correction",size=28,align=2)) resultS4= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result4,"manual colors and levels correction",size=28,align=2)) resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",\ size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result3,"autolevels + manual color correction",\ size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result4,"manual colors and levels correction",\ size=28,align=2).histogram(mode="levels")) result6= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2)\ ,subtitle(stab4,"test stabiliser: dx=horizontal, dy=vertical",size=32,align=5)) Eval(result)[/PHP][/HTML] |
9th February 2009, 12:50 | #85 | Link | |
Or better, download the newest Depan() version. But I see Fizicks website is nor working for now?? Fred.
9th February 2009, 13:31 | #86 | Link |
Hi videofred!
Thanks for this incredible script! I have a lot of 8mm film left from my dad that I would like to manage in my PC. After losing a bit of time in trying to make your script working (well, I could make it work with the patch suggested before for MVtools2 and not your original), now I'm facing a different kind of problem that is probably OT here: the quality of my source. The 8mm footage that I have spans form a long period (1965-1987... wow...22 years...) but they are in a poor condition. I made a first try in converting them paying a guy that, IMO, made a very bad job. With that conversion in my hands I could give a little better look to the film thorugh your script but, hey... still is very poor. Now I would like to make a new "conversion" Analog-->digital but I'm very confused on all the procedures and machines involved in the process. Is there a guide or something like that where I could look to? The restoration that you showed in your site is incredible but your source material is in waaaaay better condition than mine. |
9th February 2009, 13:46 | #87 | Link | ||
To use my original script, you need the special modified MVTools with the 'multi' support. It can be found here on the forum. Quote:
You can always send me a PM... Fred.
9th February 2009, 18:14 | #88 | Link |
AviSynth plugger
videoFred,
may it is better to add some word about "8mm film" to the title of this thead? to decrease mess with usual video.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
9th February 2009, 18:24 | #89 | Link |
Fizick: title is fixed
PS: what's wrong with your webspace?? Fred.
19th February 2009, 22:14 | #90 | Link |
How to Remove splitscreen and text
hello,
I finaly have the script working but can't figur out how to get just the final video without the split screen and text can someone please help me. thnx for the great script fred, Michael |
19th February 2009, 22:21 | #91 | Link | |
Potentate
Look at the end of the script: Code:
result1 = "autolevels, autowhite" result2 = "autowhite, manual levels correction" result3 = "autolevels + manual color correction" result4 = "manual colors and levels correction" |
22nd February 2009, 10:49 | #92 | Link |
Wow, that's really impressive color adjustment! I was kind of surprised no one mentioned RemoveDirtMC() which removes dirt and dust specks that are only found on one frame of the video. I noticed some specks while watching your video. The link is http://forum.doom9.org/showthread.php?t=110078 There's also a scratch removal script that is supposed to remove dark vertical lines caused by scratches in the film but I've never tried it. I'm going to go watch your video again.
22nd February 2009, 15:01 | #93 | Link |
[CODE]Look at the end of the script:
Code: result1 = "autolevels, autowhite" result2 = "autowhite, manual levels correction" result3 = "autolevels + manual color correction" result4 = "manual colors and levels correction"/CODE] Thanks for the answer, I stil have a question. I wan't the same result as the outcome of the oiginal scrip (clip on the right). When i chane the script line at end into "return (result1)" or 2,3,4 the results are not so good as the original. the clip is shaking and in the original it is realy steady. Can you please tell me what i am doing wrong or what i shoot do to get the same result. Thx, Michael |
23rd February 2009, 07:34 | #94 | Link | |
You are not doing anything wrong. If your original clip is steady, then there is no need to stabilize it. Please set "maxstab" to zero. Probably the stabilizer tries to follow a moving object in your clip. I have made an option "result6" to check this. Fred.
23rd February 2009, 13:04 | #95 | Link |
Hi fred,
With original i ment the clip on the right in your script. My Original footage (on the left in the splitscreen) is shaking but whith your filters (on the right in the splitscreen) it became realy steady. When i adjust the script (see code) the result is still shaking and not so good as the clip on the right in your script. Sorry for bothering you. Michael Code:
result1= sharp3.addborders(X,0,0,0,$FFFFFF).levels(0,gamma,255,0,255).autolevels().coloryuv(autowhite=true)\ .crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result2= sharp3.levels(black_level,gamma,white_level,0,255).coloryuv(autowhite=true)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result3= sharp3.coloryuv(off_U=blue,off_V=red).levels(0,gamma,255,0,255).addborders(X,0,0,0,$FFFFFF)\ .autolevels().crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result4= sharp3.coloryuv(off_U=blue,off_V=red).levels(black_level,gamma,white_level,0,255)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result5= overlay(eval(short),stab_reference,x=est_left,y=est_top).addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,HS) W2= W+bord_left+bord_right H2= H+bord_top+bord_bot short2=short+"S" source2=Lanczos4Resize(eval(short2),W2,H2) source3=Lanczos4Resize(eval(short2),W,H) resultS1= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result1,"autolevels, autowhite",size=28,align=2)) resultS2= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",size=28,align=2)) resultS3= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result3,"autolevels + manual color correction",size=28,align=2)) resultS4= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result4,"manual colors and levels correction",size=28,align=2)) resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",\ size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result3,"autolevels + manual color correction",\ size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result4,"manual colors and levels correction",\ size=28,align=2).histogram(mode="levels")) result6= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2)\ ,subtitle(stab4,"test stabiliser: dx=horizontal, dy=vertical",size=32,align=5)) return (result1) |
23rd February 2009, 13:22 | #96 | Link |
Michael, you are not bothering me at all but please stop posting half scripts. Where is the other half?
Why have you changed my script anyhow? The only things you must change are the parameters on top of the script. What you say is impossible anyhow. If the right window on the spitscreen is OK then the output must be ok to. It is the very same clip... Fred.
23rd February 2009, 14:16 | #97 | Link |
Here's the full script
film="C:\Documents and Settings\Michael\Mijn documenten\Downloads\filmdenoise\filmtest nieuw\alldepp2_15_16_fps.avi" # source clip, you must specify the full path here short="L" # L=long clip S=short clip try it! result="resultS3" # specify the wanted output here trim_begin=6 trim_end=6 play_speed=18.75 #trim frames and play speed (PAL: 16.6666 or 18.75) saturation=1.0 #saturation X=4 gamma=0.7 # X is a special parameter for reducing the autolevels effect black_level=0 white_level=255 output_black=0 output_white=255 # manual levels, when returning result4 AGC_max_sat=2 AGC_max_gain=1.0 #parameters of HDRAGC filter, improves colors and shadows blue=-4 red=2 #manual color adjustment, when returning result2. Values can be positive or negative denoising_strenght=800 #denoising level of first denoiser: MVDegrainMulti() denoising_frames= 4 #number of frames for averaging (forwards and backwards) 3 is a good start value block_size= 16 #block size of MVDegrainMulti() block_over= 4 #block overlapping of MVDegrainMulti() temp_radius=20 temp_luma=6 temp_chroma=6 #second denoiser: TemporalSoften grain_luma=10 grain_chroma=10 # this will add some digital grain to the final result, set it to zero if you do not want it. LSF_sharp_ness=250 LSF_radi_us=3 LSF_sub=1.5 #first sharpening parameters (LimitedSharpenFaster) sub=subsampling USM_sharp_ness=40 USM_radi_us=2 USM_thres_hold=0 #second sharpening parameters (UnsharpMask) USM_sharp_ness2=20 USM_radi_us2=1 USM_thres_hold2=0 #third sharpening parameters (UnsharpMask) maxstab=60 #maximum values for the stabiliser (in pixels) 20 is a good start value est_left=20 est_top=20 est_right=20 est_bottom=20 est_cont=0.8 #crop values for special Estimate clip CLeft=30 CTop=30 CRight=30 CBottom=30 #crop values after Depan and before final resizing (40,30,40,30) W=720 H=576 #final size from the returned clip bord_left=0 bord_top=0 bord_right=0 bord_bot=0 #you can add black borders after resizing, final size is then size + borders!! # End variables, begin script #==================================================================================================== SetMemoryMax(1024) #set this to 1/3 of the available memory Loadplugin("Depan.dll") LoadPlugin("DepanEstimate.dll") Loadplugin("removegrain.dll") LoadPlugin("AGC.dll") LoadPlugin("MVTools.dll") Loadplugin("mt_masktools.dll") LoadPlugin("MaskTools.dll") Loadplugin("warpsharp.dll") LoadPlugIn("LimitedSupport_09Jan06B.dll") LoadPlugin("MT.dll") LoadPlugin("autolevels.dll") LoadPlugin("AddGrainC.dll") Import("LimitedSharpenFaster.avs") source1= Avisource(film).assumefps(play_speed).trim(trim_begin,0).converttoYV12() end= source1.framecount() end2= end-trim_end frames=end+trim_begin skip= end2/5 skip0=skip+3 skipend= 3 skipend1= skip0+3 skip2= skipend1+skip skipend2= skip2+3 skip3= skipend2+skip skipend3= skip3+3 skip4= skipend3+skip skipend4= skip4+3 skip5= end2-3 L= trim(source1,0,end2) LS= trim(source1,0,end2).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"\ +string(trim_end),x=100,y=60,size=32)""") sourceT1= trim(source1,0,skipend).scriptclip("""subtitle("frame "+string(trim_begin+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)\ +" steps: "+string(skip),x=100,y=60,size=32)""") sourceT2= trim(source1,skip0,skipend1).scriptclip("""subtitle("frame "+string(trim_begin+skip0+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps: "\ +string(skip),x=100,y=60,size=32)""") sourceT3= trim(source1,skip2,skipend2).scriptclip("""subtitle("frame "+string(trim_begin+skip2+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+" steps:\ "+string(skip),x=100,y=60,size=32)""") sourceT4= trim(source1,skip3,skipend3).scriptclip("""subtitle("frame "+string(trim_begin+skip3+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT5= trim(source1,skip4,skipend4).scriptclip("""subtitle("frame "+string(trim_begin+skip4+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") sourceT6= trim(source1,skip5,end2).scriptclip("""subtitle("frame "+string(trim_begin+skip5+current_frame)\ +" from "+string(frames)+" trim_begin-"+string(trim_begin)+" trim_end-"+string(trim_end)+\ " steps: "+string(skip),x=100,y=60,size=32)""") SS= sourceT1+sourceT2+sourceT3+sourceT4+sourceT5+sourceT6 sourceT10= trim(source1,0,skipend) sourceT20= trim(source1,skip0,skipend1) sourceT30= trim(source1,skip2,skipend2) sourceT40= trim(source1,skip3,skipend3) sourceT50= trim(source1,skip4,skipend4) sourceT60= trim(source1,skip5,end2) S= sourceT10+sourceT20+sourceT30+sourceT40+sourceT50+sourceT60 stab_reference= eval(short).crop(est_left,est_top,-est_right,-est_bottom)\ .tweak(cont=est_cont).binarize(threshold=80).greyscale().invert() mdata=DePanEstimate(stab_reference,trust=1.0,dxmax=maxstab,dymax=maxstab) stab=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,mirror=15) stab2= stab.crop(CLeft,CTop,-CRight,-CBottom).tweak(sat=saturation) stab3=DePanStabilize(eval(short),data=mdata,cutoff=0.5,dxmax=maxstab,dymax=maxstab,method=1,info=true) WS= width(stab) HS= height(stab) stab4= stab3.addborders(10,10,10,10,$B1B1B1).Lanczos4Resize(WS,HS) vectors= stab2.MVAnalyseMulti(refframes=denoising_frames, pel=2, blksize=block_size, overlap=block_over, idx=1) denoised= stab2.MVDegrainMulti(vectors, thSAD=denoising_strenght, SadMode=1, idx=1).tweak(sat=saturation) leveled= denoised.HDRAGC(coef_gain=2.0,max_gain=AGC_max_gain,min_gain=0.5,max_sat=AGC_max_sat,shadows=true) sharp1=limitedSharpenFaster(leveled,smode=1,strength=LSF_sharp_ness,overshoot=50,\ radius=LSF_radi_us, ss_X=LSF_sub, SS_Y=LSF_sub, dest_x=W,dest_y=H) sharp2= unsharpmask(sharp1,USM_sharp_ness,USM_radi_us,USM_thres_hold) sharpX= unsharpmask(sharp2,USM_sharp_ness2,USM_radi_us2,USM_thres_hold2) sharp3= sharpX.TemporalSoften(temp_radius,temp_luma,temp_chroma,15,2).addgrainC(grain_luma,grain_chroma,0.2,0.2,5) #backward_vectors = sharp3.MVAnalyse(isb = true,truemotion=true,idx=2) #forward_vectors = sharp3.MVAnalyse(isb = false,truemotion=true,idx=2) #frameclip=MVFlowFps(sharp3,backward_vectors, forward_vectors, num=25, den=1, ml=100, idx=2) result1= sharp3.addborders(X,0,0,0,$FFFFFF).levels(0,gamma,255,0,255).autolevels().coloryuv(autowhite=true)\ .crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result2= sharp3.levels(black_level,gamma,white_level,0,255).coloryuv(autowhite=true)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result3= sharp3.coloryuv(off_U=blue,off_V=red).levels(0,gamma,255,0,255).addborders(X,0,0,0,$FFFFFF)\ .autolevels().crop(X,0,-0,-0).addborders(bord_left, bord_top, bord_right, bord_bot) result4= sharp3.coloryuv(off_U=blue,off_V=red).levels(black_level,gamma,white_level,0,255)\ .addborders(bord_left, bord_top, bord_right, bord_bot) result5= overlay(eval(short),stab_reference,x=est_left,y=est_top).addborders(2,2,2,2,$FFFFFF).Lanczos4Resize(WS,HS) W2= W+bord_left+bord_right H2= H+bord_top+bord_bot short2=short+"S" source2=Lanczos4Resize(eval(short2),W2,H2) source3=Lanczos4Resize(eval(short2),W,H) resultS1= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result1,"autolevels, autowhite",size=28,align=2)) resultS2= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",size=28,align=2)) resultS3= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result3,"autolevels + manual color correction",size=28,align=2)) resultS4= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result4,"manual colors and levels correction",size=28,align=2)) resultS2H= stackhorizontal(subtitle(source2,"original",size=32,align=2)\ ,subtitle(result2,"autowhite, manual levels correction",\ size=28,align=2).histogram(mode="levels")) resultS3H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result3,"autolevels + manual color correction",\ size=28,align=2).histogram(mode="levels")) resultS4H= stackhorizontal(subtitle(source2,"original",size=32,align=2),\ subtitle(result4,"manual colors and levels correction",\ size=28,align=2).histogram(mode="levels")) result6= stackhorizontal(subtitle(result5,"baseclip for stabiliser -only the B/W clip is used",size=32,align=2)\ ,subtitle(stab4,"test stabiliser: dx=horizontal, dy=vertical",size=32,align=5)) return (result1) The only thing i changed is the 1 line (film) , setmode (removed) and the last line return instead of eval. When i use return1 does it use al the filters then? Thnx, Michael |
23rd February 2009, 16:06 | #98 | Link |
Michael,
All returned clips should be stabilized. There is no difference in stabilizing between return1 , return2 etc... The difference is in the levels and color corrections. 'resultS1' will return a double window with clip 'result1' on the right and the source on the left. 'result1' will return clip 'result1' only. There is no difference, in both cases you will see clip 'result1' I realy do not understand your problem, what difference do you see exactly? Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest Last edited by videoFred; 23rd February 2009 at 16:13. |
23rd February 2009, 16:40 | #99 | Link | |
Avisynth language lover
result = "result1" It comes to the same thing of course, but that way you only change the parameter section at the start, not the main body of the script. Last edited by Gavino; 23rd February 2009 at 16:48. |
23rd February 2009, 17:02 | #100 | Link |
Yes, this 'eval' was a hint from you, if I remember well Gavino
Fred.
