Old 1st June 2015, 19:08   #30661  |  Link
i have issue on windows 10 and i will report issue with the RTM version which will be available soon.
Old 1st June 2015, 19:42   #30662  |  Link
RainyDog
You are using Catmull-Rom for downscaling, right? With other algorithms, linear light might not look correct, its only really recommended for CR.
I've always used Spline3 for downscaling as I prefer the slightly sharper look to CR.
So I shouldn't be downscaling in linear light if using Spline?
RainyDog is offline   Reply With Quote
Old 1st June 2015, 19:58   #30663  |  Link
aufkrawall
imho one shouldn't use it at all. There's a reason why usually gamma corrected is considered as the desired result (or better said: gamma correction gives the desired result in the end).
I just played some desktop capture videos and fonts look totally awful with linear light downscaling.
Old 1st June 2015, 20:43   #30664  |  Link
6233638
I really don't think that looking at computer graphics is a good test for downscaling.
You should be using photographs or movies.
Something that was filmed instead of rendered.
With that, linear light downscaling should be better - at least if your display is properly calibrated.
http://forum.doom9.org/showpost.php?...ostcount=25427 (note: this is a macro image of a fly)
View the comparison images here at 100% in your browser and switch tabs.
The image scaled in linear light should look very close to the source, only lower resolution.
The image without linear light scaling is quite a bit darker than the source image, and finer details are lost.
Catmull-Rom with the anti-ringing filter enabled is the only option which does not result in ugly ringing or aliasing artifacts when linear light scaling is enabled.
I don't recommend enabling the linear light scaling option with anything else.
An old example comparing Catmull-Rom and Lanczos.
Old 1st June 2015, 21:38   #30665  |  Link
aufkrawall
I did with that grass picture:
http://upload.wikimedia.org/wikipedi...chip_trail.jpg
What is the point of this nearest neighbor upscaling?
It introduces tons of aliasing.
It would be better if the source's resolution would be high enough to have a realistic result in a common native resolution.
Old 1st June 2015, 21:48   #30666  |  Link
cyberscott
The first log makes sense, but the 2nd doesn't. The 2nd log indicates that it wasn't from the build 2 I intended you to test. Either I uploaded the wrong file, or you tested with the wrong file. To be safe, I've uploaded the 2nd build again:
http://madshi.net/madVR8810test4.rar
Could you please test this build again? Thanks!
It is very possible I messed the 2nd one up, was short on time and tried to do it quick.
I ran test 4 and same behavior with the queues. Here is the log.
http://s000.tinyupload.com/?file_id=...22210065716807
cyberscott is offline   Reply With Quote
Old 1st June 2015, 22:31   #30667  |  Link
6233638
To keep the image the same size so that you can tab through all of them in your browser and make an accurate comparison.
Though fine details are better preserved by using linear light scaling, it is the overall brightness/appearance of the image which is important.
Linear light scaling preserves the "silvery" appearance of the eyes, while scaling without that option shifts the tone more towards brown.
If you wear glasses, you may even want to take them off when comparing the three if you find the aliasing distracting. Resolution should not be a factor in this comparison.
And please ensure that the images are not being scaled at all, they must be displayed at 100% size.
Old 2nd June 2015, 03:24   #30668  |  Link
baii
In general, is there a consent on using higher needi3 neurons vs using SuperRes/ more pass SuperRes?
I have some 480p DVD that is like 0.5% of the content I watch, but I really like those~. My eye test seem to favor more neuron(32->64) compare than more pass, or even activating SR, but then there is the pixel shift which make the comparison kind of weird/hard ?
baii is offline   Reply With Quote
Old 2nd June 2015, 07:54   #30669  |  Link
in my test more passes with SR is very harmful to the picture unlike nnedi3 with more neurons so hard to compare.
Old 2nd June 2015, 08:26   #30670  |  Link
Anima123
The effect of SuperRes with madVR is not exactly the same as the one with MPDN for some reason, I don't know why.
I'd prefer the MPDN version, quality speaking. Maybe madshi have some idea to tweak the SuperRes a little bit, or there's some kind of bug when SuperRes and NEDI were included within madVR?
Anima123 is offline   Reply With Quote
Old 2nd June 2015, 10:18   #30671  |  Link
madshi
I meant P8 state, sorry.
madshi did something to fix NNEDI3 quadrupling in the past with image enhancement because there was a similar issue.
I suppose it's still related to NNEDI3 quadrupling + image enhancement.
Driver gets totally stuck in P8 state, thus it drops lots of frames if it's too slow. It's not able anymore to enter a higher P-state unless the driver is restarted.
I had fixed a bug, but that had nothing to do with power states. I have zero influence on which power states the GPU switches to.
Originally Posted by shaolin95 View Post
Thanks a lot. Its very easy with that example indeed so I got a good idea now of how they behave. With Blurays though telling the difference is another story.
Differences are hard to see in most scenes. However, there are some scenes in which differences can be visible. It's usually when there's lots of red and black.
Originally Posted by andybkma View Post
Hi madshi, found a bug with mVR 88.10 that is not occurring with 88.7. Whenever I try to play the attached link two AVC clips Zoom Player immediately crashes when I use either LAV or ffdshow as the AVC video decoder, whether software decoding, CUDA or Quicksync is selected. I duplicated the problem using PotPlayer and setting the same external AVC decoders as the video decoder. Oddly when I select PotPlayer's AVC built-in decoder the clips don't crash so perhaps that may help with figuring out what is wrong. Like I mentioned, this is new prob, the clips play fine with mVR 88.7. Please let me know what other info I can provide.
I think this will probably be fixed in the next build.
Originally Posted by QBhd View Post
I have some more info for those of us having issues with D3D11 and PotPlayer.
I use a 72 Hz refresh rate for 23.976 playback (with ReClock) and a 60 Hz refresh rate for 29.970/59.940.... PotPlayer's onscreen info (TAB) will show 23.976-->72 (actually starts a little above 72, then falls to 72 and stays there). When the video is paused (or something else pulls focus away) there is a flicker (like going out of FSE) however ctrl-J still says FSE... and now the OSD of PP will show 23.976-->70 (and the 70 keeps falling until it hits 24)... ctrl-J shows empty queues (with no dropped frames, oddly enough) and playback gets super jittery. I have been racking my brains trying to find a way for this to work, but no setting in PP, ReClock or madVR allows me to pause the video and resume without this very very odd behavior. Playback is awesome as long as nothing interrupts it, but many times a video can be paused (can't miss anything for a beer run or to take a leak!!) and having to stop and restart each time is not an option. So I keep going back to D3D9.
To me, it seems that once the stream is interrupted, the refresh that is being reported gets altered in some way to that of the video and not the target... I just tried without ReClock, and everything I described above happens except the playback seems smooth, even with the last two queues not filling up. It's all very odd
Those PotPlayer frame rate reports don't have a lot of meaning.
Does this problem only occur with PotPlayer? Or also with e.g. MPC-HC? I think there is a setting in PotPlayer which causes madVR to rerender frames all the time in paused state, causing rather high GPU consumption in paused state. I'm not very familiar with PotPlayer, though. If you disable that feature (in case you know which it is), does that make the problem go away?
Could it be that downscaling in linear light can totally shift an image in an unwanted way?
Some time ago, I did some tests with downscaling game sreenshots, and with linear light everything seemed to be getting too bright.
Linear light should produce the "correct" result, unlike gamma light. The reason is that blending pixels together in gamma light is mathematically not correct. And downscaling blends a lot of source pixels together for each target pixel. For upscaling it's a bit different. In theory linear light should produce more correct results for upscaling, too, but it adds so much ringing that the positive benefits are outweighed.
All 2-tap algos should be fine. However, 3-taps and more produce a lot of ringing when using linear light which the anti-ringing filter doesn't completely erase. Other than the ringing, using 3-taps/4-taps for linear light downscaling is ok, too. It's really only the ringing which is the key problem.
Originally Posted by Shiandow View Post
FWIW you can actually prove mathematically that using linear light (with a gamma > 1) will make the image brighter. For more information see Jensen's inequality.
Hmmmm... Isn't that backwards? I mean don't we have to think of linear light as a straight line, and of gamma light as a curve? Jensen's inequality should prove that *gamma light* produces incorrect results, not linear light. Or am I missing something? You seem to suggest that gamma light is a straight line and that linear light is a curve. But I think it's exactly the other way round? Images/videos are using gamma light because that's how CRTs used to work, and also because it happens to approximate the way our eyes perceptually work. But nature/physics really is linear light, not gamma light.
Originally Posted by dansrfe View Post
Is it possible to have an option to use D39 overlay in windowed mode and D311 in exclusive mode?
Possible yes. But too much work.
Originally Posted by XRyche View Post
I know this is the madVR thread but since Shiandow's debanding algorithm is being tested along side madVR's, I hope the thread will forgive me for the following.
In my tinkering with the deband algorithm's this weekend I have confirmed for myself a rather happy alternative use for Shiandow's algorithm set at 1.00 strength and .01 margin with grain. It does an excellent job of deblocking and denoising my old dvr rips at sub 480p resolution without totally killing detail (in tandem with nnedi3) and making it a fuzzy mess. Well more fuzzy than it already was.
This is just my opinion, but I think it would really be beneficial (for me and possibly even a small minority of users) if Shiandow might be able to optimize his debanding algorithm further down that path and possibly madshi could use it as a denoiser/general deblocker for madVR somewhere in the near future.
Deblocking should be handled separately from debanding, IMHO. Why? Because a deblocking algorithm can actually assume that blocks appear at typical distances (e.g. at 8x8 pixel boundaries). This information should allow a deblocking algorithm to work more efficiently than trying to make a debanding algorithm remove block compression artifacts.
That said, yes, maybe Shiandow's debanding algorithm could be used as a starting point for a new deblocking algorithm. But there's no room in my time schedule at least for that anytime soon.
Originally Posted by MSL_DK View Post
With v0.88.9 and v0.88.10 Average stats > rendering never stabilize, it jumps up and down and i've have frame drops. It applies to Jinc and jumps from 6ms to 22ms. If I choose Bicubic it settles at around 18ms after a few seconds.
In older versions rendering times were averaged "forever". That means you got nicely stable times after a while. *However*, directly after switching algos or changing zoom factors or things like that, rendering times are usually much higher than a couple of seconds later. This means that old way of long-time averaging often started too high and needed a looooong time to settle down to the correct values. The new method averages rendering times over just 1 second of playback. So naturally the rendering times can jump quite a bit. However, if the rendering times over multiple consecutive measurement periods are relatively near to each other, madVR averages them together again. So as long as the jumps are not too large from one measurement second to the next, the times should calm down over time, too, and then get much quicker to the correct end result compared to before.
Originally Posted by petran79 View Post
Finally! Nvidia GTX660 Vsync issue on Windows XP has been solved with latest Madshi and Nvidia drivers 347.88
After almost 2 years wait!
FWIW, I don't think it's the drivers. I've added a number of changes for Optimus systems, and I think those probably have helped with your specific problem, too. The drivers are probably still as buggy as ever, but madVR has added a number of driver workarounds to be more forgiving with bad drivers.
There are small differences in the SuperRes implementation. But you guys are too fast. We're still discussing debanding atm. We'll get to SuperRes soon enough.
Originally Posted by James Freeman View Post
I find Shiandows 0.80, 0.0, Grain On; vs High, identical in terms of detail loss and shape retention.
IMO, They are so close, any one of them will do perfectly.
As the old saying goes, if it's working don't touch it.
Originally Posted by vivan View Post
On debanding:
"Add grain". It adds grain, yes, but it's 10x stronger than madVRs/f3kdb's and I don't really feel it being useful. In some cases it even makes an opposite effect and makes banding more visible.
Overall I still strongly prefer madVR debanding over Shiandow's (on anime sources).
Thank you for your feedback, once again!
Any more votes about debanding?
Old 2nd June 2015, 10:20   #30672  |  Link
madshi
Ok, thanks. One more try, if you don't mind:
http://madshi.net/madVR8810test5.rar
Please activate debug mode first (by double clicking "activate debug mode.bat"), then afterwards drop in the new madVR.ax. If you do it the other way round, but you're replacing the "wrong" madVR.ax file and you're testing with the official v0.88.10 again. I know, it's a bit confusing. Basically, after you dropped the replacement madVR.ax file into the madVR folder, don't double click any batch files, until you've completed testing. Thanks!
Old 2nd June 2015, 13:10   #30673  |  Link
Shiandow
Jensen's inequality doesn't really care about which one is "correct" or "linear". It just uses the fact that the function used to go from gamma light to linear light is convex. If you go the other way around then the function you use is concave, so the inequality will be the other way around. You can really only use it to show that the values will (always) be higher when you use linear light, you can't use it to show whether this is better or not.
Old 2nd June 2015, 13:38   #30674  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Hi madshi.
I have question for you. How you(what API function use) change resolution/refresh rate ?? In MPC-BE/MPC-HC use ChangeDisplaySettingsEx(). But - after buy new GTX 960 i have some trouble with 24fps mode - after use ChangeDisplaySettingsEx() my TV info that use 24p, but in MPC-BE EVR Custom i see that fps ~23.976(and it's true). If i try use madVR with auto-refresh - i give "true" 24p mode. You do not know what could be wrong ??
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 2nd June 2015, 13:59   #30675  |  Link
nevcairiel
Originally Posted by Aleksoid1978 View Post
Hi madshi.
Its the same API, but you have to cheat it.
Call ChangeDisplaySettingsEx with the new mode and CDS_UPDATEREGISTRY | CDS_NORESET once, and then a second time without a new mode and without the flags (it'll use the new mode you set in the previous call then)
Old 2nd June 2015, 14:11   #30676  |  Link
Aleksoid1978
It's not necessary. Even call ChangeDisplaySettingsEx() only with CDS_UPDATEREGISTRY or CDS_FULLSCREEN or 0 - it's work. But something wrong with new mode - TV info that 24p, but in fact - 23.976. All other mode working as it should.
Old 2nd June 2015, 15:21   #30677  |  Link
madshi
Ah, I see. The basic question that was discussed earlier in this thread was whether linear or gamma light was "correct". I had thought that you had tried to answer that question. Now I see that your reply didn't mean to judge about which is right (or even better).
nevcairiel has it right. If you use ChangeDisplaySettingsEx() the normal way, it will switch to 23.976, even if you specify 24.000. You have to call ChangeDisplaySettingsEx() twice, in a very specific way (see nevcairiel's post), to get true 24.000.
Old 2nd June 2015, 16:18   #30678  |  Link
Vegeak
Since the last 2 versions (0.88.9/0.88.10) if I set debanding as high it drops a lot of frames, I'm using 0.88.8 and it plays fine, my graphic card isn't good at all (GT 610), but I can play 720p files fine. This seems to happen since high debanding was modified, can I get a version with all the new changes but without this change specifically?
Vegeak is offline   Reply With Quote
Old 2nd June 2015, 16:21   #30679  |  Link
sneaker_ger
New versions enabled gradient analyzing for "high" debanding. Go "rendering"->"trade quality for performance" and tick "don't analyze gradient angles for debanding". Then test again. (I don't know if it really needs much performance. Maybe it's just a coincidence and real problem is something else?)
That said, debanding might change again in the very near future according to the user reports here so this might only be a temporary option.
Old 2nd June 2015, 18:01   #30680  |  Link
Vegeak
Thank you! This fixed my problem.
