15th December 2019, 09:52 | #18021 | Link |
Status
EncodingClient_crash_message.txt:
Access violation at address 00426861 in module 'EncodingClient.exe'. Write of address 0000099C Nothing is being written to a debug file right now it seems. I have two stalled EncodingServer's out of three. One EncodingServer shows it as Offline in the EncodingClient (local server to the EncodingClient), clicking connect does not reestablish the connection. Only closing the EncodingServer (closed gracefully) and manually running EncodingServer.exe allows connection to it again. The second EncodingServer just seems to be hung at 99.9%. Offline and Online the EncodingServer started it back up again. Also having jobs that die and have ERROR shown in the EncodingClient window. More often then not, I have to go into the job, into the Avisyth windows, then click Okay, OKay to have that job work again. Edit: Just tried aborting (which everything was running fine at this point) but the EncodingClicent hung and I had to End the Process in Task Manager. Window was hung and you could not drag it. Last edited by Ryushin; 15th December 2019 at 09:56. Reason: Update |
15th December 2019, 13:47 | #18022 | Link |
Debug Gone
Is the debug version not in Core V2? Still having hangs.
Is there something like a strace for windows? I found this: https://drmemory.org/strace_for_windows.html Would it be helpful to use this tool? I think you would need to call it though when you start the EncodingClient program. |
15th December 2019, 13:51 | #18023 | Link |
Another Bug.
When Shutdown Sever and Shutdown Client is checked. Ripbot freeze on shutdown. I manage to make a screenshot just before it finished and should shutdown. Just Before finish and shutdown: https://imge.to/i/vMdz7H Client Shutdown works fine. Server shutdown dosnt work: https://imge.to/i/vMdwZC Did some more testing and just starting Ripbot works fine, but when closing the application (pressing the X in the upper corner) it freeze. What happen is when I click the upper corner X, it goes to the tray. There I can right click and press Show or Close. Show will show the window, but its not responding and close do nothing!. Have to kill it in task manager. Last edited by GZZ; 15th December 2019 at 13:56. |
15th December 2019, 21:44 | #18024 | Link | |
Found another bug, but this might be in X265.
I have an episode of South park that is (16:9) (1920x1080), but its 4:3 with black boxes on the side. When I autocrop it, it add 240 and -240 to either side. In your script for x265 is also indicate a --SAR 4:3 and encoder says video is 1440x1080p which is just as it should be. Quote:
A quick fix was to remux the video in mkvtoolnix and set the SAR to 4:3 and video looks fine again. Might be worth checking in on, as Im not sure its a bug in your application. |
16th December 2019, 04:58 | #18025 | Link | |
Grumpy Old Man.
It doesn't seem to do the exact same thing twice in a row...the randomness of whatever is causing this, is the problem. Anyway, I have posted a couple more screenshots (just more of the same, tho), I've added some notes, on each shot. https://www.mediafire.com/file/ddofn..._same.rar/file And an unrelated problem, I thought I'd go back to an older version, and get some jobs done, but there was a BIG problem with Avisynth...RB kept asking for is on start up, and even tho I manually installed it, it still didn't accept it, so that's annoying Must be a conflict of versions.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
16th December 2019, 09:07 | #18026 | Link | |
Could you try to disable Windows Defender or any other antivirus/firewall software and see if it continue. Its the only thing I can think of could help. |
16th December 2019, 09:21 | #18027 | Link | |
Grumpy Old Man.
I do have ALL firewalls disabled, not sure how disable Defender.. Edit:- I managed to get Windows Defender disabled in the registry, so I re started RB, and it actually started processing both chunks, and I thought "we" were onto something, then, just over 10% in on both, it locked up !! I'm not running any other AV or Firewall app's !!
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 16th December 2019 at 10:25. |
16th December 2019, 10:57 | #18028 | Link | |
Another thing I would check is to run this command in powershell (search powershell in start menu). Test-NetConnection <host> -port <port> Use 127.0.0.1 or 192.168.1.1 as host and Port 1000 or 2000 for de DE Clients Dont know if it can keep testing on the port, but maybe something is blocking the port when it dies, so testing the port before encoding and when it stops on a chunck. |
16th December 2019, 11:42 | #18029 | Link | |
Grumpy Old Man.
I only just recently changed my LAN's IP, with the problems a couple of weeks ago, with RB, when it had a problem with a "0" in the address. Maybe I need to try yet another...can't really change the port numbers (can you ?) I will like your suggestion of testing the ports, so I guess my host/port would be 192.168.1.1:1000 and/or 2000, etc.
16th December 2019, 13:09 | #18030 | Link | |
Your script to execute for powershell would be: Test-NetConnection 192.168.1.1 -port 1000 Test-NetConnection 192.168.1.1 -port 2000 |
16th December 2019, 13:28 | #18032 | Link | |
Grumpy Old Man.
I will definitely do a port check, I got a simple app that might continuously moniter the ports.
16th December 2019, 13:34 | #18033 | Link | |
Grumpy Old Man.
I've found that I am doing a lot of babysitting myself, but clicking the offline/online buttons doesn't always do anything.
16th December 2019, 14:32 | #18035 | Link |
Grumpy Old Man.
I also have had encodes complete with 1.16.3, BUT it's a random issue.
17th December 2019, 09:21 | #18037 | Link | |
My servers ClientEncoder stopped working, it looked like it freezed as the Graph stopped updating, but the the "Commands Recieved From Client" keept going, but it was looking for port 1001 and therefor it didnt do anything as the ClientEncoder is responding on port 1000. I have no idea why it suddenly shifted port in the middle of the night, but I killed the ClientEncoder and restarted it and everything worked fine again. See Image: https://imgur.com/ZYS4l1a Is it the same that happens to you when it stop on a chunk? |
17th December 2019, 10:19 | #18038 | Link | |
Grumpy Old Man.
But from what you've said, is pretty much one of the problems I have, either a Client chunk will stall, or a Server chunk will stall, sometimes when a server has a problem, I can hear RB qutting the job, in the other room. I was chasing so many things today, I lost track, but one thing I had a bit of success with was managing to get a version of RB (just before the problem update) to work on some of my Servers (I have several different OS's on the Servers), and I thought I'd stumbled onto something about Windows Server 2019, as W10, and W8.1 were working, but not Server 2019, but then I figured out what was causing that. But yeah, I have noticed that when it errors, it's been looking for weird Port #'s. At one point I thought it was my "new" MDegrain custom filters, but then I figured out what that problem was... And then I thought it was x265, as x264 wasn't causing any problems. So all in all, another puzzling day, but at least I got a couple of encodes done. I think I'll be sticking with my "special" version of RB for now. Not sure where Atak is, it's been a few days since he posted anything, and autoupdates is acting strange, not connecting to anything just showing a LOT of URL's.
