Old 7th February 2019, 20:53   #381  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Sounds like the -1446ms might have to be 1446ms.
Latest MKVToolNix is v83.0
Mosu is offline   Reply With Quote
Old 7th February 2019, 21:47   #382  |  Link
manolito
manolito's Avatar
No, that's not it. To get the correct audio sync the delay has to be 0.
Old 7th February 2019, 23:07   #383  |  Link
mkver
The second audio track (track #3) starts at 5ms, the first audio track (track #2) at 65ms. The first video keyframe has a timestamp of 1571ms, the lowest video frame has a timestamp of 1511ms (this file uses open GOP). If you extracted both track #2 and track #1 (the video) and muxed it back with mkvmerge, mkvmerge would give the lowest video frame a timestamp of 0ms and the first video keyframe a timestamp of 60ms. This is a difference of 1511ms; in order to keep AV sync, you would have to offset the audio by 1511ms, too; extracting audio to elementary streams makes it loose its initial delay (here 5ms and 65ms) which already amounts to subtracting 5ms resp. 65ms from the audio tracks. So you would have to subtract a further 1511ms - 65ms from track #3. But this is only true if you actually extracted both audio and video and remuxed the elementary tracks -- your comment seems as if you didn't extract the video at all.
Btw: Why extract the tracks to elementary tracks at all? If you have transmission errors (and therefore missing packets), you will loose A/V sync no matter whether the initial offsets were right.
mkver is offline   Reply With Quote
Old 8th February 2019, 15:24   #384  |  Link
manolito
manolito's Avatar
Thanks mkver for the detailed analysis, but this is not really my point...
The average user will not have such analysis skills (I certainly don't), and we have software like mkvextract and mkvmerge to do this automatically. This is all I am asking for.
You are correct, I did not extract the video track at all, I just extracted the audio track and remuxed it into the source MKV. And this resulted in the sync error. I just tried again and extracted both the video and audio tracks, then imported both tracks into MKVMerge to create a new MKV. And yes, this time the only way to avoid sync errors was to honor the audio delay for the muxing process. So it does make a difference if I add an audio track with a delay to an already existing MKV with a video track, or if I create a brandnew MKV with video and audio tracks. Weird, and basically I do not want to deal with this.
The reason why I need to extract the audio track(s) from the source MKV is that I use StaxRip (an older 32-bit version) to recode the HD source HEVC / AAC-LATM (or E-AC3) into an SD AVC / AAC file. And StaxRip processes the audio separately from the video, and the extracted audio always needs to be decompressed to PCM first to make frame accurate editing possible.
And if the captured source has transmission errors, you do have a point. If I have repacked a captured MTS file to MKV first and there are glitches in this file, I will loose audio sync. But by trial and error I found out that this does not happen if I use the original MTS or TS as the source for StaxRip. My source filter is DSS2Mod, and when the source has transmission errors and I use the original Transport Stream as the source then I will see the broken frames, but sync is maintained.
Using the original Transport Stream as the source has its problems, though, and I try to avoid it when I can. Editing out commercials is a major PITA when using HEVC Transport streams, seeking the desired frame by stepping through the frames always brings up corrupt frames because the next I-Frame cannot be found. After repacking the source to MKV these problems disappear completely.
Luckily transmission errors are very rare for me with the DVB-T2 format. I always use TSDoctor to check for transmission errors, and about 95% of my captures are error-free.
Cheers
manolito
Old 9th February 2019, 01:14   #385  |  Link
mkver
The software can't read your mind, but what could be done is that if a Matroska file has a video track and you select to not extract the video track, then the delay that is put into the filenames should not be calculated as if the video started with 0, but rather as if the video timestamps were unchanged (in your example, the delay that would be put in the filenames would be 5ms and 65ms). You may ask gpower2 about it; but who knows: Maybe someone else would call the behaviour just proposed weird.
(And what should happen when there is more than one video track? I don't know.)
There is BTW a second workaround for you that is only applicable when your recording contains a few seconds at the beginning that you want to discard (there needs to be a complete GOP at the beginning that you don't want to keep). When you initially remux from ts to mkv, you can let mkvmerge split by parts based on timestamps in order to discard the very beginning. The lowest timestamp of the main video track will then be zero (for each part). So the problem you encountered here doesn't happen for such files.
I don't use StaxRip, but keep in mind that StaxRip may add confusion of its own to the offsets. (I.e. does StaxRip even care about the offset in the input file (namely that the first video track doesn't start at zero?)? How does it handle the fact that the lowest video timestamp belongs to an undecodable frame (one of the B-frames shared between GOPs?)?)
Newer versions of mkvmerge discard whole PES packets when mkvmerge detects any errors (by looking at the continuity counter). This might explain your observation. The last version that didn't do this was AFAIK 19.0.
Old 9th February 2019, 16:20   #386  |  Link
manolito
manolito's Avatar
It does not have to. All I would like to see is a behavior which is consistent with the behavior of other software for the identical task.
Let's not talk about the peculiarities of captured transport streams, let's also forget about StaxRip. Let's break it down to a very common task which I need to perform frequently (and other users probably too).
I have a clip in an MKV container, MediaInfo reports a certain audio delay. I need to "beautify" the audio. So I need to extract the audio track, decompress to WAV, do all my nasty tricks in WaveLab (or any advanced WAVE editor), save the WAV and convert it to AAC. The last step is to import this audio track into the original MKV, disable the original audio track and remux it into a new MKV. Very simple...
If I do this using gMKVExtractGUI and MKVToolnixGUI then the result will be out of sync, because the audio delay value is written into the file name of the extracted audio track. All following operations will preserve the filename with the embedded delay value. Remerging it back into the original MKV will honor the delay value, and this results in a sync error.
I will not get sync problems if I use FFmpeg or AviDemux for this task. The reason is simple, this other software does not care for audio delay values. Remuxing the "beautified" audio back into the original MKV will give out a new MKV in perfect sync.
So all I am asking for is consistent behavior. It is too bad that Pashin stopped maintaining his MKVExtractGUI2 software, IIRC the last supported MKVToolnix version was v. 20.
Cheers
manolito
Old 9th February 2019, 16:46   #387  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
Cheers
manolito
I am sorry manolito, but if your usage scenario involves reencoding the extracted audio track, then it certainly can involve renaming the file!
Extracting audio tracks with the exact delay is and will stay the default action since if this information is lost, then the user can't re-merge the original tracks without losing sync.
If someone uses the extracted track for something more complicated than that, then simply renaming the extracted track's filename will suffice.
In the next version, I will add a custom filename creation mode, in order for the user to choose how the extracted filenames are generated.
I guess you can then change the filename generation rule and your problem will be solved.
gpower2 is offline   Reply With Quote
Old 9th February 2019, 17:04   #388  |  Link
manolito
manolito's Avatar
Yes, this will certainly solve it for me...
Old 9th February 2019, 17:24   #389  |  Link
dissory
Hi gp2, had a few suggestions if you don't mind:
Is it possible to add an option to extract tracks with its title property? Especially useful for subs (forced subs, sdh etc) and audio (lossless, lossy, different channels mix etc) where there are multiple of them in the same language and currently it's not easy to differentiate them by name.
An option to extract based on number of chapters/attachments entries each file has would also be very useful!
dissory is offline   Reply With Quote
Old 10th February 2019, 09:43   #390  |  Link
Csimbi
Originally Posted by Csimbi View Post
Hi there,
I'd like to make a request for gMKVExtractGUI.
That is, to zero-pad track numbers.
Current example: _track8_
Future example: _track08_
The reason is simple: so they would show up in correct order in my file manager.
(08,09,10,11 instead of 10,11,8,9)
Thank you!
Pretty please? ;-)
Best regards: Csimbi
Csimbi is offline   Reply With Quote
Old 10th February 2019, 11:49   #391  |  Link
gpower2
gpower2's Avatar
Pretty please? ;-)
Hopefully all the above will be addressed with the new version. However, it's not going to be released soon, since my job is keeping me really busy...
Old 26th March 2019, 17:18   #392  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by gpower2 View Post
EDIT2: New version is up! I think that the issue is now fixed! Thanks for your feedback!
@turment on Telegram
Old 19th April 2019, 09:04   #393  |  Link
airium
This is a wonderful software but only one thing. I am wondering if you don't mind to add the utility to automatically create the destination folder if not existing? For people who use a fixed folder, it's a little annoying being warned about "not exist" and manually navigating and creating it. Many thanks if you could implement it for the minority.
Update: Thanks. No need to bother any more. I already had a look at the source code and manually changed it to automatically create the output dir without warning.
airium is offline   Reply With Quote
Old 17th May 2019, 17:48   #394  |  Link
an3k
an3k's Avatar
Hey gpower2, thanks for the great tool. I love it extracts chapters too! I noticed that there isn't an option for mkvextract --raw so that video streams are extracted to the raw format rather than .avi (at least for vc1 streams).
Could you add that option please? Maybe with the --fullraw if that is of use at all. Thank you very much!
an3k is offline   Reply With Quote
Old 23rd May 2019, 16:48   #395  |  Link
johnsonlam
johnsonlam's Avatar
Thank you very much! I like your program, simple and easy, it really help!
Hong Kong - International Joke Center (after 1997-6-30)
johnsonlam is offline   Reply With Quote
Old 12th June 2019, 19:59   #396  |  Link
gpower2
gpower2's Avatar
gMKVExtractGUI v2.5.0
Hey guys! I managed to find the time and refactor the inner works for the output filename generation, so that it can now be customizable!
I added a new Options form which can be accessed from a new button located at the bottom of the main form.
I also added some small features that were requested over time and made some changes in the form's controls.
Enjoy people!
Changelog
v2.5.0
  • Ask the user to create the output directory if it doesn't exist
  • Various improvements on Form Controls
  • Added new "Options" form to support custom output filename patterns
  • Check if a file with the same filename already exists before extracting and add a counter to the output filename to avoid overwritting the original file
Old 13th June 2019, 12:38   #397  |  Link
manolito
manolito's Avatar
Thank you so much, just what I needed...
Old 15th June 2019, 23:05   #398  |  Link
Csimbi
Changelog
v2.5.0
That update is fantastic!
Even better than I hoped for.
It was well worth the wait.
Thank you, much appreciated!
Old 25th July 2019, 21:27   #399  |  Link
gent
I donīt see mkv tracks
to install gMKVExtractGUI to extract mkv subs, drop the mkv and I donīt see the tracks?????
gent is offline   Reply With Quote
Old 26th July 2019, 10:45   #400  |  Link
gonca
If you mean the sub tracks, is it possible the tracks are burned in?
gonca is offline   Reply With Quote
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui
