16th February 2013, 20:20 | #261 | Link |
Many thanks, tebasuna51.
1. eac3to doesn't like -edit=0:00:00.000,12750ms -silence. Minimum start time accepted is 13s. What could be wrong? It's a 6-channel 448kbps AC3 stream. 2. One command for each edit point? Last edited by mariner; 16th February 2013 at 20:23. |
17th February 2013, 12:30 | #263 | Link | |||
Would you be kind enough to also look at a related problem posted here? http://forum.doom9.org/showthread.php?p=1615955#post1615955 Best regards. |
18th February 2013, 13:15 | #264 | Link | |
But you can use Delaycut or eac3to to avoid the problem. When you add a delay here to a ac3 track, silent phisycal frames are added to the ac3 and you don't need add timeshift in audio/video containers. If you need a delay >4935ms for a ac3 track in m2ts container, first use: eac3to track.ac3 new_track.ac3 +4960ms and you can now add the new_track to tsMuxeR without timeshift.
25th February 2013, 16:47 | #266 | Link | |
delaycut v1.4.3.7 hangs on "crc errors - silence" mode for some files
it just makes zero progress fixed file remains at zero kb even after an hour also delaycut becomes unresponsive and won't respond to abort (but it will close out with the X at upper rt) esaxple log : Quote:
if you need a sample please feel free to pm me. Last edited by djmasturbeat; 25th February 2013 at 16:50. |
4th April 2015, 19:46 | #272 | Link |
47.952fps@71.928Hz
I get 404 on that.
Even if I reduce to just athomasm, it's 404. Someone mirrored it here: https://github.com/darealshinji/delaycut
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
17th November 2016, 02:23 | #273 | Link | |
Only loading a test ac3 file we can see differences between DelayCut versions: Code:
= INPUT FILE INFO ================= v1.3.0 CORRECT v1.4.3.7 v1.4.3.8 ---------------- ---------------- ------------------ File is ac3 ac3 ac3 Bitrate (kbit/s) 192 192 448 (?) Act rate (kbit/s) 192.000 192.000 448.000 (?) File size (bytes) 480000 480000 480000 Channels mode 2/0: L+R 2/0: L+R 2/2: L+R+SL+SR (?) Sampling Frec 48000 48000 48000 Low Frec Effects LFE: Not present LFE: Not present LFE: Present (?) Duration 00:00:20.000 00:00:20.000 00:00:08.571 (?) Frame length (ms) 32.000000 32.000000 32.000000 Frames/second 31.250000 31.250000 31.250000 Num of frames 625 625 267 (?) Bytes per Frame 768.0000 768.0000 1792.0000 (?) Size % Framesize 0 0 201 (?) CRC present: YES YES YES = TARGET FILE INFO ================ ============= ============== Start Frame 0 0 0 End Frame 624 624 266 (?) Num of Frames 625 625 267 (?) Duration 00:00:20.000 00:00:19.968 (?) 00:00:08.512 (?) Then always than I want a cut output one more frame than needed, if I want 3200 ms (100 frames) output 101 frames (3032 ms). But v1.4.3.8 detect wrong Bitrate, Channels, LFE, etc. (reported here) EDIT: After some changes here is a build than work better than v1.4.3.7: delaycut_testbuild
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 10th December 2016 at 19:04. Reason: add info |
27th February 2017, 17:02 | #274 | Link |
New release v1.4.3.9 here https://github.com/darealshinji/delaycut/releases
27th February 2017, 21:48 | #275 | Link |
@tebasuna
Too bad but for v1.4.3.9 there is no qt4 build which means that it won't run under my WinXP... Question: In this post: https://forum.doom9.org/showthread.p...24#post1797824 there is a link to a beta version which also contains a qt4 build. This build runs fine, so I'd like to know if the bugs from v1.4.3.8 are fixed in this beta version? Thanks and Cheers manolito |
