20th March 2011, 01:00 | #982 | Link | |
Thanks for looking into the LATM issue.
20th March 2011, 01:06 | #983 | Link | |
20th March 2011, 01:19 | #985 | Link |
I found the offending commit that broke LATM decoding. I'll revert it and upload a new 0.19 zip with a fixed ffmpeg. I will also try to bring it up with the ffmpeg devs, but from past experience, responding to regressions on old commits never really worked too well..
20th March 2011, 01:34 | #986 | Link |
Ok, same URLs as before
Download: 32-bit & 64-bit Just that one commit reverted. I'll do a full update on ffmpeg tomorrow, and see if its maybe fixed (doubt it, from skimming the commit list since then), and try to get some attention on the mailing list, somehow. For some reason getting some change commited just by saying it works is easy, reporting a bug requires more then saying "it doesn't work". <.< Please confirm that the issue is indeed fixed for you as well.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 20th March 2011 at 01:46. |
20th March 2011, 02:24 | #988 | Link | |
20th March 2011, 11:19 | #989 | Link |
That old problem, eh. I still blame ffdshow for the crash, not sure why it doesn't happen with any other splitter, but it also doesn't happen with any other decoder, including the MPC-HC decoder which also uses libmpeg2.
Personally, i like the MS DTV Decoder for MPEG-2 content.
20th March 2011, 11:44 | #990 | Link |
Yeah no idea either..... Anyway, I'm trying to keep the number of Filters down to a minimum and FFDSHOW's Subs and deinterlacing (YADIF Double Frame rate) is pretty good IMHO. So for me the ideal set of filters is looking like:
- LAVSplitter - LAVAudio for all but DTS + Arcsoft HD Audio for DTS (thanks again for this config option!) - FFDSHOW for Video (ffmpeg-mt for 264/AVC as handles 50p content without stuttering, libavocdec for the rest) + "MS WMVideo Deocder DMO" for VC-1 as it handles Interlaced VC-1 well (mmm I have not tried the Arcsoft decoder.....) - madVR for the Video Renderer - Reclock for the Audio Renderer (at least until J.River add auto frame rate changing to their renderer which should be soonish) Last edited by jmone; 20th March 2011 at 12:11. |
20th March 2011, 12:55 | #992 | Link |
I don't really watch any interlaced or TC'ed content, but if i do (got some DVDs that are TC'ed), i usually prefer hardware deinterlacing/ivtc, never got any software work as smooth as that (even when that means not using madVR for that few DVDs)
20th March 2011, 13:20 | #994 | Link | |
Works just fine on my win7 x64 HTPC. Anyway, this is out of topic, I guess. Was just wondering why you guys didn't use the DScaler IVTC mod. |
20th March 2011, 13:30 | #995 | Link | |
In any case, can't use madVR for DVDs anyway. Screw you macrovision
20th March 2011, 15:50 | #997 | Link |
Now that madVR is working with the MPC-HC internal sub renderer (thanks Madshi ), I started playing around with it.
I noticed that LAVS does not work with the MPC-HC keyboard shortcut for switching streams ("S" and "Shift+S" are default, I believe). Is this something that can be added?
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
20th March 2011, 20:05 | #1000 | Link |
Hi.
I am posting this problem here too, becouse i would like to found the source of this issue - i just tested LAVF v.19 audio decoder + splitter. DTS + EVR custom renderer = stuttering I noticed there is a stuttering/droped frames in videos with DTS track if custom EVR renderer is in use (like MPC-HC/MediaPortal one). If i use simple EVR/VMR9 - no problem. It can be fixed by disabling jitter correction (in fffshow). Here is a video sample. (more info). I have this problem in nearly all videos with DTS audio.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
