Old 30th October 2011, 11:58   #6601  |  Link
roytam1
Firefox User
Originally Posted by JEEB View Post
Actually, no -- -tryouts uses a weird mix of ffmpeg and libav as far as I can remember -- with random modifications all over because of legacy reasons ("All hail Milan!").
but from the svn log, it should count as libav-based as it updates from libav but not ffmpeg.
for difference between ffmpeg and libav, see this blog post:
http://codecs.multimedia.cx/?p=370
roytam1 is offline   Reply With Quote
Old 30th October 2011, 12:04   #6602  |  Link
BloodySword
BloodySword's Avatar
For me it doesn't matter if it is ffmpeg or libav, it should just work.
BloodySword is offline   Reply With Quote
Old 30th October 2011, 12:35   #6603  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
It's just been called 'libav' in the changelogs :P
I recommend you do
grep "FFmpeg" -R *
grep "Libav" -R *
in -tryouts' src/ffmpeg
And I know the difference of libav and ffmpeg, I've been posting bugs and having stuff fixed as well as just conversed on both sides.
Anyways, this is off-topic here so I'll stop here.
Indeed. Also, it shouldn't exactly be hard to compile ffmpeg, just grab a proper'ish msys/mingw environment, f.ex. one from here (although I still use komisar's 4.5.3 since some stuff still has problems with 4.6.x).
Then just compile the thing a la the shell script in LAV Filters' root and you'll get yourself a library (of course you might also need MS's compiler's tools in your path in case you need the dot-lib).
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 30th October 2011, 12:49   #6604  |  Link
Thunderbolt8
I cant get this file http://www.mediafire.com/?wtzcu8guck5cvur to play with LAVsplitter and WMVDecoderDMO. plays fine with ffdshow instead, though.
edit: works though when remuxing the video to .mkv. is it a problem of the dmodecoder with the m2ts structure or of other files inside?
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 30th October 2011, 14:05   #6605  |  Link
pankov
Originally Posted by jmone View Post
Any progress on SW based deinterlacing?
or a CUVID deinterlacing with software decoding?
Nev,
what happened to your tests of this? what were the results?
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS
NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V
Win 10 64bit 1803 + Zoom Player v14
pankov is offline   Reply With Quote
Old 30th October 2011, 14:26   #6606  |  Link
nevcairiel
The file plays just fine for me with the WMVideo Decoder DMO on Windows 7.
Old 30th October 2011, 14:46   #6607  |  Link
Thunderbolt8
oh well, playback doesnt start here, just stay at 0:00:00 with black screen -.-
Old 30th October 2011, 14:56   #6608  |  Link
SamuriHL
SamuriHL's Avatar
There may soon be no need for that...
Wouldn't that be nice.
Sent from my Xoom using Tapatalk
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 30th October 2011, 16:06   #6609  |  Link
cyberbeing
Broadband Junkie
P016 output seems broken (not used) in LAV Video going way back, is that a known issue?
Old 30th October 2011, 16:12   #6610  |  Link
nevcairiel
It would be used if a file were actually 16-bit. I don't offer it for 10 or 8 bit files.
Old 30th October 2011, 16:38   #6611  |  Link
cyberbeing
Broadband Junkie
Why not offer it for 10-bit files? Is there something wrong with swscale 10-bit to 16-bit conversion?
While there isn't much of a point in outputting 16-bit, it'd be better if you just set it as the lowest priority format for each sub-sampling (4:2:0/4:2:2/4:4:4) level, while disallowing it only for 8-bit. That way it could be forced if desired for testing purposes.
Old 30th October 2011, 16:53   #6612  |  Link
madshi
I see no sense in 16bit output if the files are only 10bit (or lower). swscale conversion from 10bit to 16bit will not improve anything. The officially recommended 10bit to 16bit conversion method for 16-235 content just shifts the pixel values, so there will be exactly zero change in output, at least when using madVR.
P.S: The only sense in allowing P016 output for 10bit files would be to support renderers which accept P016 but not P010.
Old 30th October 2011, 16:54   #6613  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
16bit output? no way. People would use it and would claim that quality is so much better so it even way beyond compare. Who needs that? One should make single custom build if a some point he'll need to test something like that.
Old 30th October 2011, 17:26   #6614  |  Link
nevcairiel
P016 and P010 are exactly the same memory layout (with P010 defined to have the 6 extra bits set to 0), so if anything supports P016 but not P010, it seriously fails.
I don't see the point allowing it.
Old 30th October 2011, 17:40   #6615  |  Link
cyberbeing
Broadband Junkie
I never said it would improve anything, I'm more interested in it for benchmarking things which accept P016. I'm already aware that speed and quality between P010 (10-bit padded to 16-bit) and P016 output (10-bit shifted to 16-bit) should be identical if handled properly. xy-VSFilter now supports P010 and P016 input/output, but for whatever reason P016 was slower than P010 when using CoreAVC. I wanted to cross-check with LAV Video, but I'm obviously unable to in its current form. I'm thinking xy-VSFilter may not be handling P016 optimally, but without cross-checking with another decoder I don't know if it's a CoreAVC issue...
Well if someone could PM me a build with working P016 when LAV Video 0.38 is released I'd be grateful.
Old 30th October 2011, 17:49   #6616  |  Link
clsid
Originally Posted by mkanet View Post
Thanks so much clsid and ney2x, you guys were both extremely helpful. I noticed when using the default windows shell extension; even after enabling the extensions I wanted via Codec Tweak Tool, I noticed a few flvs or mkv would not get their thumbnails.
When I used Icaros, every single file received a thumbnail. However, what worries me about Icaros is if it is a memory resident app or not. I'm hoping it simply replaces the default shell extension with a slightly more enhanced version without taking any extra resources.
The MS one respects the preferred filter settings of Windows 7. Use Win7DSFilterTweaker to set LAV as preferred and it should work. It will use the first frame of the video though, limitation of the shell extension.
Icaros is buggy, so it should be used with caution.
Old 30th October 2011, 18:10   #6617  |  Link
nevcairiel
Actually, both are shifted to 16-bit. In P010, the renderer just knows to ignore the 6 lowest bits.
PS:
Painting subtitles on a 4:2:0 image is still a bad idea, you should convert it to RGB before - 10-bit support doesn't change that.
Old 30th October 2011, 18:20   #6618  |  Link
cyberbeing
Broadband Junkie
Explain.
Why should I care that my rasterized TrueType/OpenType subtitles are painted on YUV if it's faster?
Old 30th October 2011, 18:23   #6619  |  Link
nevcairiel
The problem is not YUV, the problem is that the chroma is still subsampled. If you make the whole thing YUV 4:4:4, its also good.
Chroma subsampling means that you will probably get blurred borders and slight chroma errors on the borders.
Old 30th October 2011, 18:30   #6620  |  Link
madshi
The problem is that you need to do chroma upsampling in order to get YUV 4:4:4 or RGB, which costs CPU performance, especially if you want more than just Bilinear upsampling. IMHO the best subtitle logic would be to have the subtitle renderer render to an RGB texture with an alpha channel (totally separate from the video image) and ask the renderer to blend it over the video image. That's somewhat similar to what the MPC-HC internal subtitle renderer does. VsFilter could do a similar thing, but custom communication with the renderer would be needed for that.
