12th November 2017, 15:50 | #4563 | Link |
Async Compute might be able to improve performance with GCN GPUs, there is a pull request for a new Vulkan renderer of mpv which supports it.
However, there is no proof yet for actual performance benefits over DX11. I suspect it will be faster at some point than DX11 with GCN, question is just if it really will make a difference for advanced video shaders. If I remember correctly, mpv Windows dev Rossi told me that there is an interop possible for D3D11VA -> Vulkan. So really no need for DX12, it's a completely redundant API. |
12th November 2017, 18:44 | #4568 | Link |
I wouldn't expect any miracles from processing shaders asynchronously when 99% of the time MPDN is just rendering shaders at (hopefully) full speed, with little opportunity to do anything else in the meantime.
Unless you're telling me the GPU can process two shaders faster concurrently than it can process them sequentially, but that seems really weird. |
12th November 2017, 19:05 | #4570 | Link | |
Games can profit by it the most (when they can utilize enough threads), but also other applications with constant high load like video encoding or ray-/pathtracing profit by it. |
12th November 2017, 20:12 | #4571 | Link |
you can't compare a CPU multi threading with a GPU multithreading. a GPU has thousand of cores you can blindly assume they can multi thread fine.
the most profit from vulkan DX12 is the CPU which is a no issue here. async compute is not made to utilized shaders better it is made to use shaders, rasterizer and other GPU part at the same time. while for video playback we are mostly using the shaders (correct me if i'm wrong here Shiandow). if the shaders get better utilisation because the rasterizer are not standing in there way you can argue it is increasing shader utilisation but i don't see this happening for such a program. |
12th November 2017, 21:06 | #4573 | Link | |
New Vulkan revision is not even mainlined yet, I guess more optimizations will come later. |
12th November 2017, 21:21 | #4574 | Link | |
In practice the GPU probably process small clusters of pixels in an orderly fashion, but the exact cluster shape and order depends on the GPU. |
27th November 2017, 14:03 | #4576 | Link |
I would actually recommend enabling the status bar as it wouldn't be in front of the video that way.
The alternative would be to make some small modifications to the extensions code. Nothing too difficult really, but it takes some work to set things up so you can recompile the extensions. |
5th December 2017, 10:03 | #4577 | Link | |
Today i Installes it in my new computer and this problem still exit. i can't play any video. My previous computer uses AMD GPU (RX 460) and the new one use RX 560. Is this bug only happen to new mid tier AMD GPU??? Code:
TITLE: MediaPlayerDotNet Error ------------------------------ =================================== Specified argument was out of the range of valid values. (MediaPlayerDotNet) ------------------------------ Error Type = System.ArgumentOutOfRangeException Error Message = Specified argument was out of the range of valid values. Error Source = MediaPlayerDotNet Error Site = Mpdn.IScaler C(Mpdn.IScaler) Error occurred = at a.C.C(IScaler ) at a.C.B(IScaler ) at Mpdn.D3D9VideoRenderer.VideoRenderer.ag() at Mpdn.D3D9VideoRenderer.VideoRenderer.aG() at Mpdn.D3D9VideoRenderer.VideoRenderer.e(Boolean ) at Mpdn.D3D9VideoRenderer.VideoRenderer.A(String , FrameBufferInputFormat , Int32 , Int32 , Int32 , Int32 , InterlaceFlags , Double ) at B.M.A(String , FrameBufferInputFormat , Int32 , Int32 , YuvColorimetric , InterlaceFlags , PointF ) at B.M.A(IMedia ) at MediaPlayerDotNet.MainForm.A(IMedia , Boolean , Boolean , Boolean ) at MediaPlayerDotNet.MainForm.OpenMedia(IMedia , Boolean , Boolean , Boolean , Boolean ) at MediaPlayerDotNet.MainForm.OpenMedia(String , Boolean , Boolean , Boolean , Boolean ) at MediaPlayerDotNet.MainForm.h.A() at a.S.A() OS Version = Microsoft Windows NT 6.3.9600.0 Total Physical Memory = 15,9 GB Available Physical Memory = 10,1 GB Date Time = 05/12/2017 15:56:33 User Name = ARIF-HUMAS\Arif Application Startup Path = C:\Program Files\MPDN Application Executable Path = C:\Program Files\MPDN\MediaPlayerDotNet.exe CurrentDirectory = H:\HUT 60 SystemDirectory = C:\Windows\system32 Ran As Admin = False HasShutdownStarted = False MachineName = ARIF-HUMAS ProcessorCount = 12 LogicalDrives = C:\, D:\, E:\, F:\, G:\, H:\, I:\, J:\, K:\, L:\, M:\, N:\, O:\ EnvironmentVariables = COMPUTERNAME = ARIF-HUMAS; USERPROFILE = C:\Users\Arif; HOMEPATH = \Users\Arif; LOCALAPPDATA = C:\Users\Arif\AppData\Local; PSModulePath = C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules; PROCESSOR_ARCHITECTURE = AMD64; CommonProgramW6432 = C:\Program Files\Common Files; CommonProgramFiles(x86) = C:\Program Files (x86)\Common Files; ProgramFiles(x86) = C:\Program Files (x86); PROCESSOR_LEVEL = 23; CM2012DIR = C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\; LOGONSERVER = \\ARIF-HUMAS; PATHEXT = .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC; HOMEDRIVE = C:; SystemRoot = C:\Windows; SESSIONNAME = Console; ALLUSERSPROFILE = C:\ProgramData; PUBLIC = C:\Users\Public; FPS_BROWSER_APP_PROFILE_STRING = Internet Explorer; APPDATA = C:\Users\Arif\AppData\Roaming; Path = C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Autodesk\Backburner\;C:\Program Files\Common Files\Autodesk Shared\;C:\Users\Arif\AppData\Local\Microsoft\WindowsApps;; USERNAME = Arif; OneDrive = C:\Users\Arif\OneDrive; TEMP = C:\Users\Arif\AppData\Local\Temp; CommonProgramFiles = C:\Program Files\Common Files; OS = Windows_NT; USERDOMAIN_ROAMINGPROFILE = ARIF-HUMAS; PROCESSOR_IDENTIFIER = AMD64 Family 23 Model 1 Stepping 1, AuthenticAMD; ComSpec = C:\Windows\system32\cmd.exe; USERDOMAIN = ARIF-HUMAS; SystemDrive = C:; FPS_BROWSER_USER_PROFILE_STRING = Default; ProgramFiles = C:\Program Files; ILBDIR = C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\; NUMBER_OF_PROCESSORS = 12; ILMDIR = C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\; TMP = C:\Users\Arif\AppData\Local\Temp; ProgramData = C:\ProgramData; ProgramW6432 = C:\Program Files; ADSK_3DSMAX_x64_2012 = C:\Program Files\Autodesk\3ds Max 2012\; PROCESSOR_REVISION = 0101; windir = C:\Windows RuntimeVersion = 4.0.30319.42000 Thread Count = 62 Handle Count = 5030 VM Size = 9,6 GB Peak VM Size = 9,6 GB Working Set Size = 287,1 MB Max Working Set Size = 1,3 MB Min Working Set Size = 200 KB Modules = MediaPlayerDotNet.exe, ntdll.dll, MSCOREE.DLL, KERNEL32.dll, KERNELBASE.dll, ADVAPI32.dll, msvcrt.dll, sechost.dll, RPCRT4.dll, mscoreei.dll, SHLWAPI.dll, combase.dll, ucrtbase.dll, bcryptPrimitives.dll, GDI32.dll, gdi32full.dll, msvcp_win.dll, USER32.dll, win32u.dll, IMM32.DLL, kernel.appcore.dll, VERSION.dll, clr.dll, MSVCR120_CLR0400.dll, mscorlib.ni.dll, ole32.dll, uxtheme.dll, System.ni.dll, CRYPTSP.dll, rsaenh.dll, bcrypt.dll, CRYPTBASE.dll, System.Core.ni.dll, MediaPlayerDotNet.ni.exe, System.Drawing.ni.dll, System.Windows.Forms.ni.dll, Mpdn.Core.ni.dll, System.Configuration.ni.dll, System.Xml.ni.dll, comctl32.dll, dwmapi.dll, MSCTF.dll, OLEAUT32.dll, gdiplus.dll, DWrite.dll, WindowsCodecs.dll, CommandLine.ni.dll, clrjit.dll, shell32.dll, cfgmgr32.dll, shcore.dll, windows.storage.dll, powrprof.dll, profapi.dll, YAXLib.ni.dll, System.Xml.Linq.ni.dll, clbcatq.dll, dataexchange.dll, d3d11.dll, dcomp.dll, dxgi.dll, twinapi.appcore.dll, VideoFrameServicesNative.dll, SharpDX.Direct3D9.ni.dll, SharpDX.ni.dll, d3d9.dll, aticfx64.dll, WINMM.dll, winmmbase.dll, atiu9p64.dll, atiumd64.dll, atiumd6a.dll, SharpDX.DXGI.ni.dll, TextInputFramework.dll, CoreMessaging.dll, CoreUIComponents.dll, ntmarta.dll, wintypes.dll, usermgrcli.dll, D3D9NativeServices.dll, SETUPAPI.dll, WTSAPI32.dll, AVRT.dll, dxva2.dll, opencl.dll, DEVOBJ.dll, WINSTA.dll, SharpDX.Direct3D11.ni.dll, atiuxp64.dll, atidxx64.dll, amdocl64.dll, OPENGL32.dll, GLU32.dll, atiadlxx.DLL, PSAPI.DLL, PROPSYS.dll, USERENV.dll, WINTRUST.dll, MSASN1.dll, CRYPT32.dll, atig6txx.dll, amdocl12cl64.dll, dbghelp.dll, Dx11Font.dll, FW1FontWrapper.dll, MediaInfoDotNet.ni.dll, DirectShowLib-2005.ni.dll, MediaInfo.dll, quartz.dll, CSScriptLibrary.ni.dll, WindowsBase.ni.dll, PresentationNative_v0400.dll, jscript.dll, amsi.dll, MpOav.dll, PresentationCore.ni.dll, explorerframe.dll, rasapi32.dll, rasman.dll, rtutils.dll, WS2_32.dll, mswsock.dll, winhttp.dll, LAVSplitter.ax, libbluray.dll, avutil-lav-55.dll, avformat-lav-57.dll, avcodec-lav-57.dll, Secur32.dll, avresample-lav-3.dll, SSPICLI.DLL, IPHLPAPI.DLL, NSI.dll, dhcpcsvc6.DLL, dhcpcsvc.DLL, DNSAPI.dll, qcap.dll, sxs.dll, LAVAudio.ax, WINNSI.DLL, devenum.dll, URLMon.DLL, iertutil.dll, MMDevAPI.DLL, wdmaud.drv, ksuser.dll, rasadhlp.dll, fwpuclnt.dll, AUDIOSES.DLL, msacm32.drv, MSACM32.dll, midimap.dll, DDRAW.dll, DCIMAN32.dll, DSOUND.DLL, AudioTransformFilter.ax, XySubFilter.dll, WINSPOOL.DRV, WININET.dll, LAVVideo.ax, swscale-lav-4.dll, avfilter-lav-6.dll, CallbackFilter.ax, NullRendererFilter.ax, Microsoft.ExceptionMessageBox.ni.dll, Microsoft.VisualBasic.ni.dll, diasymreader.dll ------------------------------ Program Location: at a.C.C(IScaler ) at a.C.B(IScaler ) at Mpdn.D3D9VideoRenderer.VideoRenderer.ag() at Mpdn.D3D9VideoRenderer.VideoRenderer.aG() at Mpdn.D3D9VideoRenderer.VideoRenderer.e(Boolean ) at Mpdn.D3D9VideoRenderer.VideoRenderer.A(String , FrameBufferInputFormat , Int32 , Int32 , Int32 , Int32 , InterlaceFlags , Double ) at B.M.A(String , FrameBufferInputFormat , Int32 , Int32 , YuvColorimetric , InterlaceFlags , PointF ) at B.M.A(IMedia ) at MediaPlayerDotNet.MainForm.A(IMedia , Boolean , Boolean , Boolean ) at MediaPlayerDotNet.MainForm.OpenMedia(IMedia , Boolean , Boolean , Boolean , Boolean ) at MediaPlayerDotNet.MainForm.OpenMedia(String , Boolean , Boolean , Boolean , Boolean ) at MediaPlayerDotNet.MainForm.h.A() at a.S.A() |
5th December 2017, 10:35 | #4579 | Link |
It looks like later versions of the .Net Runtime (in particular versions >= 4.7.1) might not have that bug, but this is not yet entirely certain. It's not related to the GPU by the way, it's purely .Net / Windows that's causing it.
5th December 2017, 13:55 | #4580 | Link | |
Thank You sir |
direct3d, mpdn, nnedi3, opencl, reclock |
