7th October 2009, 11:50 | #182 | Link |
Yes, changing opt to 0, 1 or 2 solves the problem. It seems that the auto detection of SSE instructions availability is incorrect. Is this a trivial bug or would it be difficult to fix it?
I need the filter to work on as many computer types as possible with the same script. Would using "opt = 0" be a good temporal solution or would it be to slow? What about forgetting about anything below P4 and using "opt = 2"? Would it be a better choice? |
7th October 2009, 17:26 | #183 | Link |
AviSynth plugger
vlada, the bug with autodetecting of SSSE3 must be fixed.
Please provide your result (first screen screen) of CPUZ http://www.cpuid.com/cpuz.php Can anybody confirm P4 bug?
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 7th October 2009 at 18:38. |
7th October 2009, 19:05 | #184 | Link |
Fizick, do you use env->GetCPUFlags() function to detect SSSE3? If so, there is a bug in avisynth 2.5.8 (and maybe earlier 2.5.x releases, I don't know off hand when ssse3 check was added) in detection of SSSE3/SSE4.1/SSE4.2. The bit checking from return of cpuid is off by one bit. It will sometimes result in false positives. IanB fixed it in late June, but no official 2.5 branch releases have been made incorporating it. The latest 2.6 branch release should be ok. I ended up adding code to my filter to do the check so that it would work with older versions.
7th October 2009, 21:18 | #185 | Link |
AviSynth plugger
I know about error in env->GetCPUFlags(), and I use my home-made addition to it in Yadif
But probably it has own bug vlada, try new v1.7
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 7th October 2009 at 22:40. |
22nd November 2009, 23:17 | #187 | Link |
as soon as I load yadif, either explicitly with
LoadCplugin("yadif.dll") Code:
Yadif() btw: I run Win7pro 64bit - maybe that's the problem? The 64bit? Avisynth version is 2.58 and yadif version is 1.7. Last edited by zyrill; 22nd November 2009 at 23:22. |
16th July 2010, 05:58 | #188 | Link |
I am trying to use Yadif in realtime playback using ffdshow and notice that with both the internal Yadif and external plugin using the fastest mode (I set it to yadif()) I get bits of detail dropped out of things like fine lines. It makes fine lines look like they have been drawn with a pencil rather than a pen if you know what I mean?
I tried a couple of different modes but they made things look uglier or were just too slow for my E6600 OC'd to keep up with on a 1280x720 upscale setting using ffdshow resizer. At present I have not really found a satisfactory way to upscale and deinterlace DVD's in realtime. The closest I have found is the internal median deinterlace as it seems to interfere the least with progressive frames. I guess I need a more powerful CPU/GPU combo. |
7th December 2010, 16:58 | #189 | Link |
I see SSE2 and SSSE3 optimisation updates have just been committed in ffmpeg, any chance of them being utilised in the avisynth version?
http://git.ffmpeg.org/?p=ffmpeg;a=co...cffe120cf213d0 I don't know what relevance these other changes have: http://git.ffmpeg.org/?p=ffmpeg;a=co...459743fac4ccf5 http://git.ffmpeg.org/?p=ffmpeg;a=co...c972ae6478b5e0 http://git.ffmpeg.org/?p=ffmpeg;a=co...661be0fd43d958 Of course, the avisynth version of FFdshow revision 2352 YADIF would be nice too (multithreading) I think a multithreaded YADIF with the updated SSE2/SSSE3 optimsations etc would be nice when working with 1080i video! Last edited by burfadel; 7th December 2010 at 17:28. |
7th December 2010, 22:01 | #190 | Link | |
Avisynth Developer
Unfortunately the image you posted has been cropped and resized after skewing, which makes reversing the skew to see the error text very difficult. Anyway part of the error text is :- "Script error: there is no function named Yadif" "avs, line 3)" the rest is to badly scrambled to read. Use VirtualDub when debugging script errors, it correctly works with all width output and has an Avisynth Error handler that will display the error text in a message box. |
9th December 2010, 21:35 | #191 | Link |
AviSynth plugger
burfadel, ffmeg SSE2 and SSSE3 optimisation is same as already used in ffdshow and (besides multithreading) in Avisynth yadif.
I am not sure, that ffmeg yadif has same bug (regression) as older ffdshow http://sourceforge.net/tracker/?func...41&atid=867362 what is the macro for xmm in ffmpeg? PSHUF(MM"3", MM"2")
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
10th December 2010, 03:10 | #192 | Link |
I did see it was very similar, but not quite exact, which is why I thought there were some refinements... maybe its just like you said, they used an older implementation, with the differences being the things that were refined and used in FFDshow
18th May 2011, 20:14 | #193 | Link | |
Edit: Resolved. Read my next post.
Hallo, the picture shows two consecutive frames created with yadif 1.7, avisynth 2.6 (25Jan2011). The chrominance channel is off by one frame in normal modes and alternates (chrom +1, -1) in double-frame modes. Depending on TFF/BFF the chrominance channel is off by -1 or +1 but never +0. Source video is HuffYUV/YV12 (FFmpeg variant/FFDShow). Any ideas what's wrong? Quote:
18th May 2011, 20:44 | #194 | Link |
The capture is 704x480? But you seem to be a PAL user, hence I would suppose the)capture to be 7xx*576. See those combing artifacts all over the place? Those should not be there in the first place.
So, most probably your raw capture is already faulty. Try replacing "Yadif(..)" with a simple "bob()". If the result shows a problem, then the capture is bad. Please describe your setup. How did you capture the video, and what video standard is actually used by the Xbox?
18th May 2011, 21:00 | #195 | Link |
Looks like its not Yadif related at all, other deinterlacers create the same temporal chrominance offset as well. Its something else. Never mind, sorry.
The video is PAL60. Everything's fine there (720x480+PAL chrom). Edit: It was a color conversion fault. Adding pixel_type="YUY2" (for AviSource) fixed the problem. Last edited by NoX1911; 19th May 2011 at 01:27. |
24th August 2011, 10:51 | #196 | Link | ||
You have to place the path for your 64 bit plugins of course.
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
27th April 2012, 12:16 | #197 | Link |
I noticed that Yadif won't load using the latest beta 2.6 avisynth (32 bit). I was wondering if it's something others have experienced...
