3rd June 2013, 11:13 | #1541 | Link |
Pig on the wing
Have you tried triple quotes: JDL_ApplyRangeOld(6428, 6466, """QTGMC(Preset="placebo").selecteven()""") ?
3rd June 2013, 11:43 | #1542 | Link |
You cannot embed a string with "single double-quotes" in a string with "single double-quotes"; to circumvent this limitation, there are also strings with """triple double-quotes""".
JDL_ApplyRangeOld(6428, 6466, """QTGMC(Preset="placebo").selecteven()""") __ Apart from that: A preset named "placebo" uses this name for a specific purpose ... to make you feel bad using it, because it is rather a waste of time than "the optimum". Last edited by LigH; 3rd June 2013 at 11:46. |
3rd June 2013, 14:45 | #1544 | Link |
Everything is documented, in the internet as well as in your local installation.
10th June 2013, 16:07 | #1546 | Link | |
I haven't used this mode, but your best bet is probably the "Noise Bypass / Denoising" section in the documentation. The following seems to be key for your objective:
Francois |
25th June 2013, 14:19 | #1548 | Link |
The original post seriously needs example scripts so it can help newer people like me..
I'm trying to use QTGMC with AVSProxy for AVIDemux. I took all the right steps to install my plugins for the deinterlacer, but I'm stuck on the scripting part of it, what am I doing wrong? AviSource(C:\Users\Owen\Desktop\deinterlacetest.avi) QTGMC(Preset="slower") |
25th June 2013, 19:36 | #1550 | Link | |
Anyway, as LigH also suggested, add quotation marks: AviSource("C:\Users\Owen\Desktop\deinterlacetest.avi") QTGMC(Preset="slower") And maybe it's OK, but I never do anything at all from the desktop. |
25th June 2013, 21:44 | #1551 | Link |
I never said my problem had anything to do with QTGMC? I've been around the block before with using temgaussmc, and I got an error to the point of 'unexpected something something'' which I knew meant something was wrong with my script. I don't think I ever said anything was wrong with the QTGMC filter. Anyways, the quotations around my file address worked! Thanks LigH.
The original post and provided documentation with the file gave no real examples of how to set the first line, I was literally left looking for half an hour before I wound up asking. I was lucky enough even to remember that I had to write the whole path, because I remember talking with an avidemux admin about it long ago. The result seems to have worked, but now I get a flickering artifact on the encoded video. One of the very first frames of the video is constantly flickered against the video itself. I can't seem to find a solution or workaround in the documentation either. I don't use vdub to write scripts, I just notepad documents in which I give an .avs to their names. Last edited by Trademark; 25th June 2013 at 21:46. |
25th June 2013, 22:33 | #1552 | Link | |||||
Yes you did. You implied QTGMC was at fault when it wasn't. Your problem was writing the AviSource line correctly, something very basic to AviSynth and nothing to do with QTGMC.
http://avisynth.nl/index.php/First_script Quote:
26th June 2013, 07:43 | #1553 | Link |
For more convenience than Notepad, there is also the old VirtualDubMod with integrated AVS editor (Ctrl+E), or the more modern AvsPmod suite.
Still ... "RTFM", know the basics before advancing. |
26th June 2013, 13:09 | #1554 | Link |
Actually it seems as though avidemux is causing issues with the AVI files I created from the TS files to use with avisynth in the first place-- the audio and video do weird things.
I'll relearn how to load up TS files through directshow. This issue has nothing to do with QTGMC so I'll ask it elsewhere. |
1st July 2013, 17:38 | #1555 | Link | |
Formerly davidh*****
Does anyone know why, when I try to QTGMC a clip with audio (provided by nicac3source) I get this error:
David |
1st July 2013, 23:11 | #1556 | Link |
Avisynth Developer
It means you are using a plugin compiled as API version 5 but it is not a full API version 5 plugin.
Typically a 2.6 plugin compiled with an old or modified avisynth.h If you use early release 2.6 plugins you must make sure they are compatible with the build of Avisynth 2.6 you are using. |
11th July 2013, 14:32 | #1558 | Link |
Ok, I have gotten my .ts files loaded thanks to other members of the forum. Now then, it seems as though I'm in need of some additional filters on my script with qtgmc, or perhaps might need something entirely else to get maximum quality out of the type of video I'm processing. Below are 4 pictures, each of yadif and qtgmc preset slower.
qtgmc 1 yadif 1 qtgmc 2 yadif 2 qtgmc 3 yadif 3 qtgmc 4 yadif 4 With only 'qtgmc(preset=slower), I notice more ghosting/ringing effects on qtgmc compared to yadif, and some of the jaggies around diagonal edges aren't as smoothed as I would liked them to have been. Basically it's not quite the jump in quality I'm looking for. Also, I've tried searching the thread for 'slow motion' but couldn't find any answers as to why qtgmc slows the resulted video down, even though I made it output in the same 30fps as my previous files. Any thanks would be appreciated. |
11th July 2013, 22:38 | #1559 | Link | |
Anyway, as already requested, please post a short sample. And also your full script. |
11th July 2013, 23:44 | #1560 | Link |
http://www.mediafire.com/?ixpab7ksiz33ukn
Here is a 1 minute sample of the video still interlaced. I had to re-encode it using x264 again with avidemux to get it under 200mb. Original .ts was using h264 as well. Here is my script: LWLibavVideoSource("C:\Users\Owen\Desktop\test1.TS") QTGMC(Preset="slower") SelectEven() |
