29th May 2007, 08:37 | #202 | Link |
sorry for my ignorance but
how does this translate to real world
2 hour 1080i/p HD movie MPEG2 to XH264 does it still get 120FPS or 200FPS im sure that's on SD right with a quadcore/octcore system does it still take 2 days or more ? right now i am sitting on a X24400 Noobish attempts doing some encoding a first pass on some anime: @ 6.20FPS CLI: --pass 1 --stats .stats --bitrate 2000 --sar 1:1 -A all --aud --level 4.1 --ref 3 --mixed-refs --bframes 3 --direct auto --analyse none --me dia --subme 1 --threads 2 --no-ssim --no-psnr --progress avis [info]: 1920x1088 @ 23.98 fps (150945 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 3DNow! basically for PS3 the second pass going to take 21 hours last time i tried. ( i had an error and i lost everything just minutes before it was about to finish) has anyone done before and after of 1-2 hour film an have before and after times ? dualcore/quadcore/octcore Last edited by ATT; 29th May 2007 at 08:40. |
29th May 2007, 15:53 | #203 | Link |
Hows this...I'll let ya know! The system has been "down" while I've been working on my custom linux distro on it for the past week or so. I've got a nice long 1080p movie that I'm planning on testing it on overnight tonight. While it doesn't run 200fps, it does run what one would expect it to run being that the size of the image is different. For example, I've been running the tests on a cropped dvd image thats 848x352. Lets assume for math purposes that it ran exactly 200fps. Lets also assume for a moment that I was maxing out the CPU's which I'm not currently able to do. For a 1080p image you wouldn't expect 200fps since the 1920x1080 image is ~7 times larger then the 848x352 is. However, you would expect it to be around 200/7 which is ~28.5. When I was running some very quick tests on it (5000 frames max), I was seeing frame rates in the low 20's. While its not perfect scaling, it was adequate enough for my tastes considering that most current systems doing full 1080p run below 5fps if even that. I do remember at one point saying "wow I'm encoding 1080p in insane quality in real time" so I must assume that since it was a 24000/1001 frame rate that I was getting around 24-25fps for that block.
I'm recompiling x264 tonight to work on this and I'll run some tests once thats all done and I've gotten a few other small things tweaked. So as I said before, I'll let ya know! |
30th May 2007, 17:28 | #204 | Link | |
Professional Lemming
If you want to use GOP level encoding be aware that the main problem is not scaling performance but to get I frame positions right (as you already do) and also get the bit distribution right. Both x264farm and ELDER (my pet) come very close in that respect bis besser, T0B1A5
projects page: ELDER, SmoothD, etc. |
18th August 2007, 15:02 | #205 | Link |
In case anyone is still wanting to play around with this I have created a new diff based on the current svn. There were some things moved from common.h to osdep.h so I have fixed that as well as altered version.sh to generate a version that has "_THREADPOOL04" at the end (eg mine is now 0.56.669_THREADPOOL04). I just ran a two pass on some 1080p stuff and it gave me a gooooooood boost in speed.
Just to note, there is nothing different functionality-wize between this and the tp03 patch, I just fixed it to work with the current svn (r670). http://www.benswebs.com/x264_thread_pool.04a.r670.diff EDIT: oops uploaded it to the wrong place, link works now Last edited by morph166955; 18th August 2007 at 15:14. |
23rd September 2007, 17:32 | #206 | Link |
Thread pool patch was updated to r678 and moved to http://www.benswebs.com/public/x264/....04b.r678.diff
Post #1 updated to have new link also |
24th September 2007, 10:22 | #207 | Link |
Emperor building empire
Ta... and tx for all the fish !!!
It's always nice to see some movement in the world of multi-core threading optimization... especially in light of AMD plans to release a triple core in early 2008 and the need for a multi-core killer app ...
" Most of the software in the market cannot take advantage of multi-core chips, so why buy machines that boast to have them and pay the extra price ? " ( Sramana Mitra). Pascal |
24th September 2007, 12:43 | #208 | Link | |
The fitting CPU for the best sport in the world But on-topic: There are apps around AI that definitely benefit from more cores. Think "decision helpers", "memory expanders" and "information filters" that adjust to your preferences. Video encoding is already as parallel as it need to be.
projects page: ELDER, SmoothD, etc. Last edited by 708145; 24th September 2007 at 16:22. Reason: added "are" |
24th September 2007, 15:57 | #209 | Link | |
24th September 2007, 16:10 | #210 | Link |
Mr. Sandman
she is an idiot. she did a very superficial analysis and draw even some false conclusions.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 24th September 2007 at 16:18. |
28th September 2007, 03:41 | #211 | Link |
quick question, I see that Cef's page lists this patch (and others), but does Cef's build actually have this patch? (or any of the ones in patch directory?)
Geforce GTX 260 Windows 7, 64bit, Core i7 MPC-HC, Foobar2000 |
29th September 2007, 06:54 | #215 | Link |
Cef, separate issue, but will you be adding the --me-prepass patch in future builds? its a great option! Its good now, in another post it was talked that it will be modified to reduce its performance impact (which is not excessive at the moment).
29th September 2007, 07:48 | #217 | Link |
I know maybe if the performance impact with the modifications is reduced enough it can be enabled by default, and then have an option of --nome-prepass or something?
Also, isn't imh supposed to replace umh? and also 'subme 8' replacing 'subme 7'? |
27th August 2009, 09:04 | #219 | Link |
H.264 freak
I have query regarding QP in case of multithreading enabled.
As in the case of single thread, each next frame QP is calculated based upon previous frame stats. IPPPP.... case e.g. 0th Frame (QP =26) 1st frame (QP modifies based on 0th frame stats), 2st frame (QP modifies based on 1th frame stats) and so on...... But in the case of more than one thread, how QP is assigned for next frame as present frame or previous frame is being encoded. 0th Frame (QP =26) 1st frame (QP = ?), 2st frame (QP = ?) and so on...... Thanks in advance. |
27th August 2009, 10:40 | #220 | Link |
x264 developer
1pass CRF/CQP: completely ignore previous frames' stats.
1pass ABR/2pass: QP adapts by stats from whichever frames have finished encoding. Any sane number of threads makes little difference, as the adaption time scale is much longer than the threading latency. VBV: latency is important, so QP adapts by stats from whichever portions of each frame have finished encoding. Last edited by akupenguin; 27th August 2009 at 10:43. |
