25th March 2009, 18:19 | #1 | Link |
Runaway Slave..
MJPEG to DVD with cropping, filters and CCE/HC/QuEnc MPEG2 encoder
As topic says i need an app that can convert my captured VHS tapes (MJPEG files) to DVDs, but i need to cut material, crop it, adjust sharpness and brightness.. Also i would like the app to use one of the quality leading MPEG2 encoders (mostly CCE).
What app should i use? I've captured tapes by VirtualDub, and it has all the abilities i need at the time, but i don't know if i can compress them again to MPEG2 with VDub? Hope my English is understandable.. Thx in advance..
• and i take 'em 3 at a time like steve kerr ! .. |
25th March 2009, 21:44 | #2 | Link |
Linux User
Frameserve from virtualdub to the encoder of your choice or learn some avisynth.
Frameserve with virtualdub Frameserve with avisynth |
26th March 2009, 09:59 | #3 | Link |
Runaway Slave..
Will try to handle it.. Other suggestions also appreciated..
Edit: It's working pretty fine with TMPGEnc but i can't make CCE SP2 1.00.01.02 load the file.. No error appears, just nothing happens when i try to load it.. Other files loads fine.
• and i take 'em 3 at a time like steve kerr ! .. Last edited by uciekamy; 26th March 2009 at 11:34. |
28th March 2009, 16:27 | #4 | Link |
Hi uciekamy,
converting analog captured video to DVD.... This is a vast area to cover, simply because there are hundreds of ways to do this. It all depends on the quality you want to achieve and on how much time and effort you intend to invest. I will try to cover the basics, but be prepared for some obstacles along the way. Frameserving from VirtualDub is certainly an option, but as you already noticed, some encoders will accept this input, others will not. I would recommend to learn AviSynth scripting, because it is much more powerful and it will work with every encoder. First thing you have to do is to check if you have to do something to get the correct aspect ratio. I assume you are doing PAL conversions (720 x 576). If you captured analog video at 720 x 576 and convert it to DVD without resizing, chances are that your aspect ratio is slightly off. This has something to do with the "active capture window" of your capture card. For a given card and driver combination this AR error will be constant. Forum member Arachnotron is THE expert on this. He has a website where you can download test images to determine your AR error. My own situation is like this: I have a BT878 based capture card which I use with Ivan Uskov's tweaked BT8x8 drivers. If I capture in 720 x 576 then the resulting DVD will look slightly stretched horizontally. Resizing by small ratios is never a good idea (Nyquist effect), so my solution is to capture at 696 x 576 and then adding 12 pixel borders to the left and the right side which brings the frame size back to 720 x 576. This gives me the correct AR, and luckily the 12 pixel borders are well within the overscan area of my CRT TV set. But maybe in your case aspect ratio error is small enough to ignore it. But before you do batch conversions of your many VHS tapes I would certainly recommend to check this. Next step is to edit the capured video file. Since all I want to do is editing out commercials, I do all my editing in VirtualDub. When I am done I simply save the edited file in Direct Stream Copy mode for video and audio. (Actually I do it using VCF2AVS to translate the editing points into AVS commands, but this is too complicated for now) Now you have the edited AVI file, and you want to improve quality by applying filters. A word of caution: A VHS capture will never look even remotely like a DVD source. Many beginners tend to use excessive filtering, but the result will look artefial. Human faces can look like taken from a wax cabinet if too much denoising has been applied. So do not overdo filtering. To see the effects of AviSynth filters I like to use AvsP. For VHS captures the most common filters are denoising and sharpening. You might have to adjust brightness, contrast and gamma. For chroma noise CNR2 is very nice. Much depends on your specific VCR. My VCR tends to oversharp edges which I try to fix using the "FixVHSOversharp" filter. In any case you will have to do a lot of experimentation. Better filters are mostly slower than simpler ones, so you have to find the right balance for your needs. A sample AVS script would look like this: Code:
AviSource("My_CapturedAVI.avi") # Optional Deinterlace AssumeTFF() LoadCPlugin(yadif.dll) Yadif() FixVHSOversharpL(30,12,8) FixVHSOversharp(30,14,10) ConvertToYV12(interlaced=true) # or false AddBorders(12,0,12,0) cnr2() degrainmedian() undot() asharp(1,4) Now the actual encoding: I still use the good old DVD2SVCD software simply because I am very familiar with it and it gives me a lot of control over all the parameters. But there is a learning curve. It supports CCE, Quenc, HC, TMPGEnc and Procoder. Another excellent AVI to DVD software is AVStoDVD. It supports HC and Quenc (not CCE), it is very easy to use, and it lets you use custom AVS scripts. Well, there is a lot more to consider (deinterlace or not, matrix selection for the encoder, convert audio to MPA or AC3), but this post is too long already... Let me know about your progress Cheers manolito |
29th March 2009, 18:16 | #5 | Link |
Runaway Slave..
Wow dude! Big appreciation for that post and all the interest..
It will need some time from me to deal with this scripting, but it doesn't seem very complicated so hopefully i'll handle it easly.. I will immediately let u know about the progress. At the moment i was just correcting contrast and adjusting brightness with vdub filters, also i enabled deinterlace and adjusted sharpness in a little bit because film looks blured for me. Colors look strange for me also, but i can't deal with filtering it (mostly red color is very, very strong while the others are pretty light).. What i'm supposed to do now is to give a try to avisynth filters you mentioned and check what improvement will happen.. As i said i've spent about a month for dealing with that tape, so i look pretty patient with all that capturing stuff and will point my expectations on quality, not on quickness.. Maybe tomorrow i will have some time to do some tries.. Thanks a lot once again!
• and i take 'em 3 at a time like steve kerr ! .. Last edited by uciekamy; 29th March 2009 at 18:21. |
10th April 2009, 13:48 | #6 | Link |
Runaway Slave..
See You again
Finally i've found out great functionality of Sony Vegas 9.0 (and yeah, i was pretty lazy ass with that avisynth scripting learning ;P).. It just works perfectly for me and has all the filters i need.. Movie looks just how i wanted it to.. ..but it looks great only in the preview window.. Problem is when i encode the video using standard MainConcept MPEG-2 DVD PAL options movie is very blocky (can see squares all over it). And a strange thing is that i can't setup custom template in that mpeg-2 codec (the button is grayed out and inactive, while it's active in mpeg-1 and other codecs).. I wonder if anybody could explain that or maybe is there any possibility to make vegas use any other MPEG-2 codec? (CCE would be well appreciated). PS: The encoded movie (DVD PAL standard template) properties shows: MPEG2 Video 720x576 (4:3) 25.00fps 9500Kbps and that's pretty high bitrate isn't it?
• and i take 'em 3 at a time like steve kerr ! .. Last edited by uciekamy; 10th April 2009 at 13:51. |
10th April 2009, 14:00 | #8 | Link |
Runaway Slave..
I'm affraid CCE SP2 doesn't handle frameserving (it doesn't for vdub) but i'll check that for sure with that plug.. Thanks..
/Edit: Wow.. It works.. Will check the quality of the encode when it finishes.. /Edit2: Hmmm.. Is that framserving speed always that low or am i doing anything wrong? I got CCE going about 6-8 times slower than while encoding the same file directly (without Vegas edit)..
• and i take 'em 3 at a time like steve kerr ! .. Last edited by uciekamy; 10th April 2009 at 14:16. |
10th April 2009, 21:18 | #11 | Link |
brontosaurusrex
i would either:
- use frameserver with hcenc (which is able to do lossless intermediate i belive) - do a lossless intermediate manually and then multipass encode that with cce that is if you care about quality and you are targeting specific bitrate, else i would - use hcenc quality based mode
certain other member |
encoding, filtering, mjpeg, mpeg2 |
