6th June 2018, 11:48 | #51181 | Link | |
It could be: - software/copyback video decoding - black bars detection & cropping - film cadence detection - HDR per-frame peak brightness analysis (not sure about this one) Try to fiddle with those and see if the CPU load gets better.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
6th June 2018, 17:55 | #51184 | Link | |
6th June 2018, 18:50 | #51185 | Link | |
Along with a new nvidia driver, they also released a firmware update that enables support for DisplayPort 1.3 / 1.4 displays. However, on some pages linking to the firmware update utility, there's a reference to (guru3d):
http://www.guru3d.com/news-story/nvi...-displays.html Just a little warning if you edited your vBIOS to overclock or undervolt, or whatever, the utility probably will fail until you reflash it with the original vBIOS. |
6th June 2018, 20:43 | #51186 | Link |
No news from veggav with the Oppo? I was wondering if he got the two players to look the same. After talking to a VLC troll today, I wonder if his Oppo has sharpening enabled or uses it as part of its upscaling? The kind of difference he is explaining sounds similar to difference the VLC guy was showing me. Maybe it has nothing to do with color and is more about pixel sharpening?
If the Oppo is outdoing madVR, it's not impossible, but it would be nice to give madVR a shot.
6th June 2018, 20:44 | #51187 | Link | |
6th June 2018, 23:40 | #51189 | Link | |
I scale all 1080p 1:1 rips to 4k, bt.709 to 4k and present all 24hz content to 60hz using Smooth Motion. Also am using MadVR pixel-shaders for playing 1:1 UHD rips (mkv, not full menu) and converting HDR->SDR. If setup correctly, MadVR is the clear winner over the Oppo for SDR2020 playback. 1000 peak nits titles looking amazing, but 4000 peak nits titles... the black floor seems raised if only slightly. Hoping madshi implements a 'peak nits' variable for the pseudo-code that switches profiles in the next release. Granted, my display has been calibrated for both Bt.709 content as well as SDR2020 content. Question I still have: Is it safe for Windows10 users to install the Spring update? Everything works perfectly with regard to MadVR and playback -- I don't wanna monkeywrench anything. |
7th June 2018, 01:37 | #51190 | Link | |
7th June 2018, 02:34 | #51191 | Link | |
I get a frame repeat every twelve minutes as opposed to a frame drop every three minutes with 385.28 when not using the custom mode. However, once again like every other driver after this it won't add the custom mode if I change the drop down box to select manual timings, so back to 385.28 I go. Pathetic. Ayy, I got it to stick by modifying 24Hz instead and added that to the list of resolutions madVR can switch to. Hurrah, now no frame drops/repeats with 398.11. Last edited by ryrynz; 7th June 2018 at 03:15. |
7th June 2018, 02:35 | #51192 | Link |
@ryrynz;@el Filou;@madjock
First of all,Thank you very much for your replies. My cpu AMD 8450X3;video card:nVidia gtx 1050 3g(bought it two months ago) player: potplayer or mpc-hd;LAV spitter,LAV video decoder;LAV audio decoder,D3D11 dxva11 native mode;renderer:madshi I did some tests yesterday for the playback of 4K HDR movies. I found if i decreased TV set resolution to 3150*2160p,i played smoothly and fluently 4K HDR movies. My cpu usages are around 47%~55%;gpu usages are around 35%~50%;hardly dropt frames. If i decreased tv set resolution to 3050*2160p,when the playback of the 4k HDR movies. My cpu usgaes are around 27%~35%;gpu usages are around 35%~50%;not dropt frames. If i decreased tv set resolution to 3250*2160p,when the playback of them My cpu usages suddenly get around 85%~93%~100%;gpu usages are around 50%~60%;sharply dropt frames. If I decreased tv set resolution to 3350*2160p and over My cpu usages suddenly get around 85%~93%~100%;gpu usages are around 50%~60%;sharply dropt frames. I don't know what's going on.MadVR HDR passthrough doesn't work suddenly.In fact the HDR passthrough worked perfectly the day before yesterday.whatever i played yesterday,it didn't work. Last edited by suanm; 7th June 2018 at 02:43. |
7th June 2018, 04:44 | #51194 | Link |
@ryrynz
With my cell phone I've taken several photos on which there were madvr OSD status,cpu usages and gpu usages as well.Unfortunatedly,these photos can't be uploaded to the post OSD status:chroma>super->xbr ;image<ssim1D100 Last edited by suanm; 7th June 2018 at 04:47. |
7th June 2018, 06:09 | #51197 | Link | |
7th June 2018, 07:39 | #51199 | Link |
So the new Nvidia Drivers always stay on Output Dynamic Range to FULL when using the Use Default color settings. make sure when you are using HDR Mode you have Black Level set to HIGH on your TV . for me OLED LG TV . or else you will have White dots and crushed blacks. or if you want the other way is to select Use Nvidia color settings and change to LIMITED and stay on TV Black Level to LOW.
7th June 2018, 07:59 | #51200 | Link |
Not sure if this is the correct place to ask but i recently notice during anime playback, when the scene is moving there is noticeable vertical tearing just 1cm above the bottom. For movie the tearing is more subtle and mostly only during high action scene. I am using default madvr setting + mpc-hc.
Anyone know what is wrong with my setup? |
