Old 7th March 2019, 01:39   #4561  |  Link
manolito
manolito's Avatar
https://forum.doom9.org/showthread.p...39#post1865439
Sorry I spoke too soon, the joy only lasted for 3 weeks...
Last night I tried to convert a longer movie (2 and a half hours), and I got the crashes again. And it was reproduceable.
My AVS script:
DSS2("D:\Black Mass.mkv", fps=50.000, preroll=15)
Crop(0,0, -Width % 4,-Height % 4)
ColorMatrix(source=0,dest=2)
RequestLinear(rlim=50, clim=50)
ConvertToYV12()
Spline36Resize(704,396)
FDecimate(25)
# Start Remove Logo
Import("I:\Logo\Area.avs") #Defines the X and Y coordinates of the logo area
ConvertToYV12(interlaced=false)
Logo = crop(X1,Y1,X2-X1,Y2-Y1)
Above = Y1 > 0 ? crop(0,0,width(),Y1) : NOP()
Below = Y2 < height() ? crop(0,Y2,width(),height()-Y2) : NOP()
Left = X1 > 0 ? crop(0,Y1,X1,Y2-Y1) : NOP()
Right = X2 < width() ? crop(X2,Y1,width()-X2,Y2-Y1) : NOP()
ConvertToRGB32(Logo,interlaced=false)
LoadVirtualdubPlugin("E:\Programme\Virtualdub\Plugins\logoaway.vdf","VD_LogoAway")
VD_LogoAway( 3, 327685, 9895963, 0, 0, 5, 0, 66051, 131584, 10, "", "", "")
IsClip(Left) ? StackHorizontal(Left, last) : NOP()
IsClip(Right) ? StackHorizontal(last, Right) : NOP()
IsClip(Above) ? StackVertical(Above, last) : NOP()
IsClip(Below) ? StackVertical(last, Below) : NOP()
last
# End Remove Logo
FineSharp()
avstp_set_threads(1)
Prefetch(4)
Trim(4248,161424)
This script is really not very complex. almosely's changes slowed it down quite a bit (adding Requestlinear after ColorMatrix and selecting MT_SERIALIZED for both ColorMatrix and RequestLinear), so the speed gain of MT was only about 1fps. Reducing the prefetch value to 2 did not make a difference, still I got crashes. Only disablng MT altogether made the script stable.
For my needs I do not see any advantage of using AVS+ over classic AVS 2.61. I reverted back to AVS classic, probably for good this time. (Unless someone comes up with a genius idea to use MT without crashes and still get a better speed).
Cheers
manolito
manolito is offline
Old 7th March 2019, 02:13   #4562  |  Link
VS_Fan
Originally Posted by manolito View Post
... For my needs I do not see any advantage of using AVS+ over classic AVS 2.61. I reverted back to AVS classic, probably for good this time. (Unless someone comes up with a genius idea to use MT without crashes and still get a better speed).
I remember some years ago having problems with frame decimation in a Multi-Threaded environment (old AVS-MT) and trying innumerable different configurations for ‘RequestLinear’ to no avail.
What I successfully ended doing was:
  • Separating only the source, decimation with any other ‘MT_SERIALIZED’ filters in one Single-Threaded AVS script, No need of of using 'requestlinear';
  • Then I either: ‘mounted’ that first script with AVFS; or simply read it directly with “AVIFileSource” into a second MultiThreaded AVS script where I put every other processing filters, susceptible of speed gains because of multi-threading
I don’t think this is genius idea, but I sincerely hope it helps
VS_Fan is offline
Old 8th March 2019, 13:18   #4563  |  Link
an3k
an3k's Avatar
I have a Plugin (DGHDRtoSDR) that is not yet listed in the mtmodes.avsi and I would like to test (and add) it. I've searched but not found the info thus I asked here.
1) What is the "single-thread" mtmode in which every plugin perfectly runs at (since it's "non-MT-behavior")? Is it NICE_FILTER or SERIALIZED?
2) What is the most performant mtmode we would love to have all plugins running at? MULTI_INSTANCE?
Thanks
an3k is offline
Old 8th March 2019, 16:49   #4564  |  Link
TheFluff
Excessively jovial fellow
It's might be simpler than that. As far as I can tell FDecimate isn't in mtmodes.avsi, but since it's a m-in-n decimation filter it's almost certainly very stateful and not at all threadsafe. Setting it to MT_SERIALIZED might very well fix the crashing.
That said, the filter chain in that script is so full of ancient serialized junk so far down into the chain that the only thing of note that runs parallelized at all is FineSharp (I don't think vdub filters are MT_NICE? who knows though), so it's no wonder it's not any faster. As a reminder, inserting a MT_SERIALIZED filter into a filter chain will effectively cause every filter upstream of it all the way up to the source filter to run serialized too, at least as far as performance goes.
Thanks
1) MT_SERIALIZED.
2) MT_NICE_FILTER.
See here for more details. As mentioned above, using a MT_SERIALIZED filter late in a chain effectively disables MT (you'll be so bottlenecked that MT doesn't help you much).
If you're using Vapoursynth though you can get some degree of parallelism even with serialized Avisynth filters, which you can't do in Avs+ itself. In Avs+, calling GetFrame on a serialized filter will essentially run every filter upstream of that point single threaded too, so requesting a frame will make the entire thing block until the entire chain is finished processing that frame, one filter at a time in a single thread. In VS, you still get a single instance of the serialized filter (in its own pretend environment) and it will only ever be asked to process one frame at a time, but upstream of it can run in parallel.
TheFluff is offline
Old 9th March 2019, 19:32   #4565  |  Link
TheFluff
I don't know who maintains the MT modes list anymore, or if the PublishWithMe pad is still the single source of truth, but colormatrix should, uh, probably not be marked as a MT_NICE_FILTER. The publishwithme pad itself notes that it seems very broken even when MT_SERIALIZED. Newer versions are internally multithreaded, and it's always done a lot of funky stuff internally (like requesting frames from the constructor and Invoke()'ing a lot of stuff).
That said, don't use colormatrix, it's always been a piece of buggy garbage.
TheFluff is offline
Old 9th March 2019, 20:08   #4566  |  Link
DJATOM
DJATOM's Avatar
Yeah, my friend used it in his scripts and it silently kills avs2yuv without any error. The only plugin that really piss me off...
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline
Old 9th March 2019, 21:31   #4567  |  Link
manolito
manolito's Avatar
Originally Posted by TheFluff View Post
...but colormatrix should, uh, probably not be marked as a MT_NICE_FILTER.
Did you have a look at this post?
https://forum.doom9.org/showthread.p...79#post1865279
ColorMatrix is running absolutely fine in MT-Mode within AVS+ (x64), but only it it's placed within a bubble of sequential frame order. So, to ensure that, RequestLinear has to be used and to be defined as MT_SERIALIZED. It makes no sense to use RequestLinear as MT_MULTI_INSTANCE. Therefore the following sript is working totally fine for me (I tested it multiple times with ST and MT encodings of the same clip) - no differences within the x264 logfiles. I did encounter differences when not using RequestLinear as MT_SERIALIZED of course.
Applying these changes made my conversions a lot more stable, until a couple of days ago I got crashes again while converting a longer movie. Now I additionally specified MT_SERIALIZED for FDecimate, the first 2 conversions went well, let's see if it lasts...
manolito is offline
Old 11th March 2019, 02:34   #4568  |  Link
manolito
manolito's Avatar
Did some more speed benchmark tests using a long 2:40 movie (Heat by Michael Mann). I basically used the script from a couple of posts above. I did get a small speed gain by moving the FDecimate(25) call to the top of the script right after the source filter, and so far everything was stable.
I also tested the same source using z_ConvertFormat replacing ColorMatrix, RequestLinear and the built-in resizer. It worked nicely, but even in the default MT_MULTI_INSTANCE mode it was about 0.5 fps slower than the other script (ColorMatrix and RequestLinear both in MT_SERIALIZED mode). So as long as the script with ColorMatrix is stable for me I see no reason to ditch it.
For the SetMTMode.avsi I don't know if anybody is actively maintaining it. I uploaded my modified version here:
https://www.sendspace.com/file/3pdsc8
All comments were removed, also all MT_MULTI_INSTANCE calls were deleted (not necessary, MULTI_INSTANCE is the default).
Cheers
manolito
manolito is offline
Old 11th March 2019, 03:55   #4569  |  Link
poisondeathray
Quality wise, ColorMatrix produces color splotches and noise compared to higher quality methods. It's more noticable on animation , gradients ; less noticable on live action, film grain sources
poisondeathray is offline
Old 11th March 2019, 06:47   #4570  |  Link
manolito
manolito's Avatar
So far I am only aware of z_ConvertFormat as a "higher quality method" under AVS. Which other methods are you talking about?
Plus your statement about ColorMatrix producing color splotches and noise is quite new to me. So far I was only aware of Fluffy's statement that ColorMatrix was not suitable for MT under AVS due to questionable coding methods which offended his professional standards. Now you are talking about quality issues even when used in single threaded scripts.
Can you provide some proof of your statement? A source segment where a color conversion from Rec.709->Rec.601 reveals quality problems like color splotches and noise when using ColorMatrix?
manolito is offline
Old 11th March 2019, 07:11   #4571  |  Link
poisondeathray
Yes z.lib (z_ConvertFormat in avisynth), or AviSynthShader, probably Dither tools too. Basically anything else
709<=>601 either direction. Just compare ColorMatrix , it's easier to see on anime, cartoons . I'll post something tomorrow, there were some threads about this too.
Old 11th March 2019, 23:26   #4572  |  Link
poisondeathray
@manolito - RE: colormatrix quality issues
https://forum.videohelp.com/threads/...709-to-rec-601
(the OP only provided screenshot, and it was converted back to YV12 for the "new" source but it's quite easy to see the problems)
Observations (not just this example, but in general):
- not version dependent, I tried a few colormatrix dll's , and the "ported" to ffmpeg filter exhibits the same issue. Probably partially due to 8bit conversion
- not settings dependent in terms of colormatrix clamping values (I usually set clamp=0 anyways, but pre/post clamp doesn't help)
- more noticable with certain color combinations , certain patterns that predispose to the issue. But source noise, film grain can often cover up the problems
- can occur 601=>709 too , eg. with DVD's when upscaling to HD . There were some DVD examples in other threads, I'll try to dig them up if you're interested
- the "better" high bit depth conversions are not because of dithering only (ie. it's not solely because of "covering up"); because if you disable dithering you still get "cleaner" image without the splotches and artifacts . But you can experiment with dithering algorithms back to 8bit . fmtc in vapoursynth has several options , it's easy to compare in avspmod tabs for example, with vsimport . avs+'s default convertbits(8) will use ordered dither .
Old 12th March 2019, 02:00   #4573  |  Link
manolito
manolito's Avatar
Thanks for digging out the VideoHelp thread, I went over it quickly, but I could not reproduce the findings.
My sources are always 8-bit with 4:2:0 chroma. And the conversion from HEVC HD to AVC SD keeps the video this way. No dithering involved, and the color space also stays the same.
Also I only convert films, no anime. I went over some of my conversions which used ColorMatrix carefully, and I could not detect any color artifacts. So my only valid reason to ditch ColorMatrix and use z_ConvertFormat instead would be a better MT speed, and right now I do not get this.
Cheers
manolito
manolito is offline
Old 12th March 2019, 09:12   #4574  |  Link
pinterf
ConvertBits does not dither, you have to specify dither=0 or dither=1.
pinterf is offline
Old 12th March 2019, 20:38   #4575  |  Link
TheFluff
I guess I should point to the elephant in the room and ask why you're even converting to Rec601 at all, when metadata flagging has been the preferred solution for at least a decade. I have a sneaking suspicion the answer probably involves some kind of arcane playback contraption from the late 1990's, though.
TheFluff is offline
Old 12th March 2019, 22:44   #4576  |  Link
lansing
He wanted to playback on his CRT TV
lansing is offline
Old 13th March 2019, 01:13   #4577  |  Link
manolito
manolito's Avatar
How in the world did you know that?
My playback device is an older (around 2010) Xtreamer Sidewinder connected to my CRT TV. It does not handle H.265, but it plays H.264 just fine. This means that my captured HEVC streams need to be converted to AVC anyways, and while I'm at it I can just as well reduce the resolution to SD 704x396 and decimate the framerate from 50fps to 25fps. This looks good on my TV.
My knowledge of the Rec709 and Rec601 standards is limited, but conventional wisdom says that HD is Rec709 while SD is Rec601. My captured sources are all 1080p50 and flagged as 709, so I figured that I need to convert them to 601 when I convert them to SD.
The data sheet of my Xtreamer unfortunately tells me nothing about which color it expects. The only way to check for the correct color is to switch between playback of the original stream through the DVB-T2 receiver and the converted SD stream through the Xtreamer. And this comparison does not show any color differences, so I guess I am doing it right...
manolito is offline
Old 13th March 2019, 01:33   #4578  |  Link
Groucho2004
I'd use DitherTools for that process.
Edit - Example
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 13th March 2019, 12:16   #4579  |  Link
goorawin
Here is a script that works really well at converting 1920x1080x50p to 720x576x25i (DVD standard). You may need to change the SelectEvery, to get the field order correct. Also change the sharpen to suit the source material.
bicubicresize(1440,1152)
bicubicresize(720,1152,-.8,.6)
bicubicresize(720,576,-.8,.6)
blur(0.0,1.0)
sharpen(0.0,0.75)
assumeBff()
separatefields()
SelectEvery(4,1,2)
Weave()
Matrix(from=709, to=601)
goorawin is offline
Old 15th March 2019, 01:05   #4580  |  Link
Groucho2004
Originally Posted by goorawin View Post
Matrix(from=709, to=601)[/I]
Is that pseudo code or an actual function?
