Old 19th July 2016, 20:12   #2121  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Originally Posted by Myrsloik View Post
I can't reproduce it so I'm not sure what it could be. Maybe you're using an older fmtconv?
It's probably not an out of memory error either since VS only uses 1GB of ram as cache at most by default.
Cache is one thing, but there's also memory, allocated by filters. Intermediate buffers and such. When these buffers need to be large for large frames - you can easily run out of continuous memory chunks to allocate them.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 21st July 2016, 02:25   #2122  |  Link
cwk
Howdy folks,
I'm having some difficulty getting qtgmc to work with r32. Here is my script:
import vapoursynth as vs
import sys
sys.path.append("/usr/local/lib/python2.7/site-packages")
import mvsfunc
import adjust
import havsfunc as hf
import functools
core = vs.get_core()
core.std.LoadPlugin("/usr/local/lib/libffms2.so")
core.std.LoadPlugin("/usr/local/lib/libmvtools.so")
core.std.LoadPlugin("/usr/local/lib/libnnedi3.so")
core.std.LoadPlugin("/usr/local/lib/libfmtconv.so")
core.std.LoadPlugin("/usr/local/lib/libtemporalsoften.so")
#core.std.LoadPlugin("/usr/local/lib/vapoursynth/libremovegrain.so")
video = core.ffms2.Source('lossless.avi')
deint = hf.QTGMC(video, Preset='Medium', TFF=True)
deint.set_output()
and here is the error I'm receiving:
vspipe --y4m 1.vpy - | ffmpeg -i - -c:v huffyuv qtgmc.avi
ffmpeg version N-81036-g2b14204 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.3)
configuration: --enable-gpl --enable-version3 --enable-shared --enable-nonfree --enable-postproc --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid
libavutil 55. 28.100 / 55. 28.100
libavcodec 57. 50.100 / 57. 50.100
libavformat 57. 42.100 / 57. 42.100
libavdevice 57. 0.102 / 57. 0.102
libavfilter 6. 47.100 / 6. 47.100
libswscale 4. 1.100 / 4. 1.100
libswresample 2. 1.100 / 2. 1.100
libpostproc 54. 0.100 / 54. 0.100
Script evaluation failed:
Python exception: No attribute with the name scd exists. Did you mistype a plugin namespace?
Traceback (most recent call last):
File "vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:24032)
File "1.vpy", line 19, in <module>
File "/usr/local/lib/python2.7/site-packages/havsfunc.py", line 980, in QTGMC
if TR0 > 0: ts1 = TemporalSoften(bobbed, 1, 255 << shift, CMts << shift, 28 << shift, 2) # 0.00 0.33 0.33 0.33 0.00
File "/usr/local/lib/python2.7/site-packages/havsfunc.py", line 4330, in TemporalSoften
clip = set_scenechange(clip, scenechange)
File "/usr/local/lib/python2.7/site-packages/havsfunc.py", line 4362, in set_scenechange
sc = core.scd.Detect(sc, thresh)
File "vapoursynth.pyx", line 1105, in vapoursynth.Core.__getattr__ (src/cython/vapoursynth.c:18358)
AttributeError: No attribute with the name scd exists. Did you mistype a plugin namespace?
Any ideas why I can't find that module?
cwk is offline   Reply With Quote
Old 21st July 2016, 04:55   #2123  |  Link
VS_Fan
Originally Posted by cwk View Post
Howdy folks,
sc = core.scd.Detect(sc, thresh) ...
You're missing the SceneChange plugin.
VS_Fan is offline   Reply With Quote
Old 21st July 2016, 15:56   #2124  |  Link
cwk
Thank you for the reply vs_fan.
I have downloaded the package, and see c code, but no configure or make file for compiling on Linux.
Those of you using Linux, how did you compile this plugin? My early attempts with gcc are failing.
Old 21st July 2016, 18:39   #2125  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Try this:
gcc -fPIC -O2 -msse2 -std=c99 -shared -I/usr/lib/vapoursynth -o libscenechange.so scenechange.c
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 22nd July 2016, 17:25   #2126  |  Link
cwk
Thanks jackoneill. That got me going. I had to do the same for the temporalsoften.c file that came with chikuzen's scene change package.
Old 23rd July 2016, 06:48   #2127  |  Link
Selur
Selur's Avatar
I'm using 64bit version for fmtconv r20 from https://github.com/EleonoreMizo/fmtconv/releases
Is there a newer version to try?
-> redownloaded the version, rebooted system cleared python cache and now it works
Just wondering:
Is there a IVTC filter for Vapoursynth with works with all color spaces?
(IT and VIVTC seem to only work with YUV420P8 from what I could gather.)
I was hoping to get rid of all the ConvertTo...-calls which I sometimes have to add to my AvisynthScripts to be able to use all filters.
Old 24th July 2016, 15:19   #2128  |  Link
feisty2
I'm Siri
feisty2's Avatar
requested by @Mystery Keeper here
floating point TemporalSoften, don't wanna start another thread so I'll just post it here
src:https://github.com/IFeelBloated/TemporalSoften
bin:https://github.com/IFeelBloated/Temp...eleases/tag/r1
namespace changed to "tsoft"
luma/chroma_threshold, scenechange are all floating point parameters now and they range from 0.0 to 255.0 still for compatibility reasons.
edit:
uhmm, and the useless parameter "mode" got its ass kicked
feisty2 is offline   Reply With Quote
Old 24th July 2016, 21:35   #2129  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Just wondering:
Nope, vivtc only does its decision in one colorspace. Use the clip2 argumebt to apply thr matches to the unconverted clip. It's slightly more awkward but there's just so little telecined material in higher bitdepths...
Myrsloik is offline   Reply With Quote
Old 27th July 2016, 04:58   #2130  |  Link
aegisofrime
Hi all,
I'm wondering, is anyone actively developing a native Vapoursynth version of DGDecNV?
I somehow had a native version of DGDecNV (I think it was released by Donald Graft himself), but then I just upgraded to the GTX 1070. The older version of DGNV doesn't work at all with the Pascal cards, so I had to update my version to DGNV to the latest ones.
Now, the problem is that the older version of DGDecNV won't open an index file created by a newer version, and I can't import the AVS dll of DGDecNV because it's an Avisynth 2.5 plugin. So at this point it feels like I'm screwed. What are my options now?
aegisofrime is offline   Reply With Quote
Old 27th July 2016, 05:17   #2131  |  Link
Selur
Selur's Avatar
Afaik. Donald Graft is the only one with the source code, so he is probably the only one with the means to implement a native Vapoursynth version of DGDecNV.
IIrc DG won't write a native version for Vapoursynth unless Vapoursynth changes, see: http://rationalqm.us/board/viewtopic.php?f=8&t=441
your options are probably:
a. hope the Vapoursynth developers change their code (Avisynth 2.5 filter support and/or handling the frame rate normalization)
b. hope that DG changes his code (dropping Avisynth 2.5 support or alternatively share a 2.5 and 2.6 filter and/or so the frame rate normalization)
c. you could try if it works to create an avisynth script where you use DGDecNV and then open that script as source using vsavsreader, but reading the end of http://forum.doom9.org/showthread.php?t=165957 that might also not work
d. forget DGDecNV in Vapoursynth for the time being
-> my guess is that if c. doesn't work you are stuck with d.
thanks, totally overlooked that parameter
Cu Selur
Old 27th July 2016, 10:59   #2132  |  Link
Mystery Keeper
Beyond Kawaii
edit:
	CMts = 255.0 if chromamotion else 0.0
	ts1 = core.tsoft.TemporalSoften(bob, 1, 255.0, CMts, 28.0)
	ts2 = core.tsoft.TemporalSoften(bob, 2, 255.0, CMts, 28.0)
Segfaults every time in temporalsoften_x64_avx2.dll
from __future__ import print_function
core = vs.get_core(threads=8)
core.set_max_cache_size(8000)
#core.std.LoadPlugin(r'D:\Programming\vapoursynth-sandbox\build\release-64bit-gcc\vapoursynth-sandbox.dll')
import sys
sys.path.append('D:\\vapoursynth-plugins\\py\\')
import platform
architecture = platform.architecture()
if architecture[0] == '64bit':
	vapoursynth_plugins_path = 'D:\\vapoursynth-plugins\\64bit\\'
else:
	vapoursynth_plugins_path = 'D:\\vapoursynth-plugins\\32bit\\'
print('Plugins folder: ', vapoursynth_plugins_path, end='\n', file=sys.stderr)
import os
for filename in os.listdir(vapoursynth_plugins_path):
	if filename[-4:] != '.dll':
		continue
	try:
		core.std.LoadPlugin(vapoursynth_plugins_path + filename)
	except Exception as e:
		print('Error: ', e, end='\n', file=sys.stderr)
clip = core.ffms2.Source(r'F:\Video\Mystery Keeper\Sound Horizon - 石畳の緋き悪魔.mkv')
clip = core.resize.Spline16(clip, format=vs.YUV444PS)
clip = core.tsoft.TemporalSoften(clip, 1, 255.0, 255.0, 28.0)
clip.set_output()
Same. The script does evaluate in VSEdit. But segfaults on preview.
...desu!
Old 27th July 2016, 12:47   #2133  |  Link
feisty2
I'm Siri
feisty2's Avatar
guess I messed "scenechange" up
investigating...
Old 27th July 2016, 20:08   #2134  |  Link
kolak
Could someone translate this into vs please:
changeFPS(60000, 1001)
assumeTFF()
separateFields()
selectEvery(4, 0, 3)
weave()
if it's actually possible. Thx!
Old 27th July 2016, 21:35   #2135  |  Link
~SimpleX~
assumeTFF()
separateFields()
weave()
import havsfunc as haf
import mvsfunc as mvs
src = ...
last = src
last = haf.ChangeFPS(last, 60000, 1001)
last = mvs.AssumeTFF(last)  # Actually, not all filters support this, unfortunately
last = core.std.SeparateFields(last)
last = core.std.SelectEvery(last, 4, [0, 3])
last = haf.Weave(last, tff=True)  # this one doesn't
last.set_output()
This should do it. You need mvsfunc and havsfunc for this to work.
~SimpleX~ is offline   Reply With Quote
Old 27th July 2016, 22:14   #2136  |  Link
kolak
I assume this won't support 8bit+ bit depths?
Old 28th July 2016, 07:42   #2137  |  Link
feisty2
I'm Siri
feisty2's Avatar
import sys
import platform
else:
import os
		continue
	try:
clip.set_output()
https://github.com/IFeelBloated/Temp...eleases/tag/r2
should work now, I wasn't cautious enough with all that pointer arithmetic stuff...
and added sanity check
Old 28th July 2016, 08:43   #2138  |  Link
Mystery Keeper
Beyond Kawaii
It works! Thank you!
...desu!
Old 28th July 2016, 09:41   #2139  |  Link
feisty2
I'm Siri
feisty2's Avatar
just out of curiosity, no offense, you obviously should be a much better programmer than me cuz you wrote vsedit, and making a floating point version of temporalsoften should be easy like a blink to you, right?
Old 28th July 2016, 09:48   #2140  |  Link
Mystery Keeper
Beyond Kawaii
If I knew how it was supposed to work - yes. If I would dedicate time to read and understand the original filter - sure, I could have rewritten it for float input. Or even simply upgrade the existing one. But I've got much on my plate. Not even working on vsedit as much as I'd like to.
...desu!
speed, vaporware, vapoursynth
