Old 4th June 2009, 22:45   #1061  |  Link
rickhtoo
@ricktoo
what mean "would not encode the video" ?
do you got errors in avs ? what's happen when you open the avs script in virtualdub ?
another one try could be the "double ivtc" but you should do it only if your movie would be 23.976 fps
also.. post a report and a 50mb of sample file
BHH
What I mean is it doesn't encode the video after Deint Analysis. It extracts the audio track then quickly zips through the encode directly to Mkvmerge. Just creates a mkv with the audio track and no video. This happens with both AutoMKV and HDC if the deint method is incorrect. Even though it declares the movie Telecine, it will not work unless I choose Interlaced/Telecine. AutoMKV doesn't appear to have that choice which is why it doesn't work.
This is indeed NTSC, with 29.97 fps. Another interesting issue I found was if I choose anything but "Use best decoder", as in choosing DSS, it will only encode 20 minutes of the dvd. I have to let it choose the decoder to get a full encode.
Do you want a 50 mb sample of the dvd, or a failed encode?
Thanks
rickhtoo is offline   Reply With Quote
Old 5th June 2009, 02:10   #1062  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
@Adub
make sure you have installed MKVToolnix
it add to path the folder where is this dll
BHH
Oh, I have it installed. It's contained in my MeGUI directory. However, since your program references the executable contained in your "applications" directory, and you did not include the dll's, it was erroring out. A quick fix is to copy the dll's from my MeGUI installed version to the "applications" directory.
I had originally thought that you would have wanted to include the dlls with your whole package, but that is your call.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 5th June 2009, 02:17   #1063  |  Link
Adub
Adub's Avatar
Originally Posted by toology View Post
Sorry, perhaps I made a mistake. Over on the codecgude forums (they make K lite) clsid is the admin and post changelogs, helps people etc. So I assumed he is the author, I apologize if I made a mistake.
So you think if I install ffdshow + Haali that HDC will start working on Windows 7? I have used clsids tool to switch everything to ffdshow and have verified that Media Player Classic uses ffdshow to decode the vob file.
EDIT: Installed ffdshow + Haali only and I still get the 'Please check media properties' error.
Huh, okay, I was not aware that clsid was a developer for the Klite codec pack. The general consensus on this forum is not to use codec packs.
However, as to the problem that you are having, it is certainly odd. I would imagine that the problem lies with Windows 7 some how.
Wait.
You do have Avisynth installed right? What happens when you drag and drop the generated .avs file contained in the "temp" directory onto MPC or VirtualDub?
It does seem a little odd to analyze vob files with directshowsource, but looking at it from a developer standpoint, it is probably the easiest option to implement.
Site:Adubvideo
Old 5th June 2009, 07:04   #1064  |  Link
buzzqw
HDConvertToX author
Originally Posted by rickhtoo View Post
What I mean is it doesn't encode the video after Deint Analysis....
so you are using the automatic deint ? if so.. sorry, as stated previusly this feature isn't supported and recommended
dss cannot be used for dvd input, BUT if you join all vobs in a big one, then dss could work
Do you want a 50 mb sample of the dvd, or a failed encode?Thanks
50 from vob
i have update mkvextract gui. now is "agnostic" regarding path. It will simple launch mkvinfo and mkvextract.
So you need to install mkvtoolnix or add to windows path the mkvtoolnix folder of megui
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 5th June 2009, 08:39   #1065  |  Link
marklar
i have included my own version of mkvextract gui
and my own version extract subs
BHH
And what should I do to make it working?
marklar is offline   Reply With Quote
Old 5th June 2009, 08:48   #1066  |  Link
zygo
gday buzz
previous problem dvd encoded very nicely with the latest update, thanks
i see there is a new bluray profile.
what are the benifits or differances of it over the extreme quality profile (which is what i have been using so far with 1 pass 18crf)
cheers
zygo is offline   Reply With Quote
Old 5th June 2009, 08:51   #1067  |  Link
buzzqw
HDConvertToX author
@marklar
install mkvtoolnix (or read Adub post)
@zygo
official profiles are first 10, others are for fun
anyway bluray profile should be a little more compatibile with blue ray specs
BHH
Old 5th June 2009, 09:17   #1068  |  Link
marklar
I have MKVtoolnix installed and the directory is in Path, but it does nothing.
Old 5th June 2009, 10:03   #1069  |  Link
buzzqw
HDConvertToX author
download this http://www.64k.it/andres/data/hdconv...MKVExtract.exe and redownload hdconverttox.exe
and report any problem
thanks
BHH
Old 5th June 2009, 10:15   #1070  |  Link
marklar
Please, look at the attached screenshot.
EDIT: Files that should be extracted are created, but all have size 0.
Old 5th June 2009, 10:17   #1071  |  Link
buzzqw
HDConvertToX author
...i have to wait some day before attachment got approved... use imageshack
BHH
Old 5th June 2009, 10:32   #1072  |  Link
toology
@Adub: Thanks man, you helped me out! It seems the Avisynth installation was corrupted because of an explorer crash. I reinstalled it and HDC analyzed the file.
toology is offline   Reply With Quote
Old 5th June 2009, 12:02   #1073  |  Link
marklar
BHH
http://img140.imageshack.us/img140/9899/errorv.jpg
Old 5th June 2009, 12:57   #1074  |  Link
buzzqw
HDConvertToX author
... i am abel to extract vob sub..
try to upgrade to latest beta of mkvtoolnix (afaik 137 or so)
BHH
Old 5th June 2009, 13:14   #1075  |  Link
marklar
BHH
I found that the problem occurs only if I select (using checkbox) more than one subs stream. When I select only one stream, it works fine.
Old 5th June 2009, 13:19   #1076  |  Link
buzzqw
HDConvertToX author
got the same problem. if multiple subs are selected mkvextract is unable to extrat it.. one at time works
it's something to ping to mkvtoolnix thread
BHH
Old 5th June 2009, 13:31   #1077  |  Link
marklar
when I do the same manually on command line using mkvextract.exe from my mkvtoolnix folder, it works OK even with more subs streams
Old 5th June 2009, 13:45   #1078  |  Link
buzzqw
HDConvertToX author
i will check it
thanks
EDIT: got it, it's the dots in file name
BHH
Old 5th June 2009, 13:54   #1079  |  Link
buzzqw
HDConvertToX author
ok, fixed.
redownload the mkvextractgui http://www.64k.it/andres/data/hdconv...MKVExtract.exe
BHH
Old 5th June 2009, 21:18   #1080  |  Link
Chengbin
So any suggestions to my flickering subtitle problem?
Chengbin is offline   Reply With Quote
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui
