Old 28th March 2009, 00:52   #1  |  Link
tiosolid
Good capture card for PAL analog source
Hi, I live in Brazil and im planning to buy a TV-Card for my HTPC. My main problem is that all the cards sold on ebay / amazon like the HauppaugeŽ ones are NTSC, and I need a PAL-M card.
My question here is: Is there any way to buy a good PAL TV-Card in the US (hauppauge or not)? If not, will the Hauppauge NTSC cards (like the PVR-150) work here in Brazil?
FYI: Im going to use the card with MediaPortal or even MediaCenter
tiosolid is offline   Reply With Quote
Old 29th March 2009, 15:44   #2  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
Check european products at www.amazon.co.uk
AMD Athlon X2 QL-60 (1.9GHz) - 3GB DDR2-667 - ATi Radeon HD 3200 - Windows 7 Ultimate 32-bit
Encode to Vorbis at ultra high speed using SSE3 multithreaded encoder by Lancer!
DJ Bobo is offline   Reply With Quote
Old 29th March 2009, 17:01   #3  |  Link
tiosolid
I know but here in Brazil we use PAL-M, not PAL-N like in Europe ;/
Old 29th March 2009, 17:07   #4  |  Link
DJ Bobo
Encoding Dinosaur!
DJ Bobo's Avatar
It doesn't matter, my old TV-card (a Pinnacle PCTV Studio Rave) handles all possible PAL formats, even PAL60 (I know that because you can have a PAL60 signal from the PlayStation 2 if the game supports it). I don't see why "newer" cards wouldn't (I've known of the PVR150 since my early capture days).
Old 1st April 2009, 14:28   #5  |  Link
2Bdecided
Europe is PAL-BDGIK (which are all basically the same at baseband - the only differences are at RF). PAL-N is rare, as is the different "PAL-N combination".
I wouldn't be 100% confident that everything supports everything. Try asking fellow enthusiasts in a local forum to be sure. Given the potential compatibility problems to be solved, I bet there is a local video forum in your country + language. (You can certainly find many video people discussing and complaining about it in Argentina).
Cheers,
David.
2Bdecided is offline   Reply With Quote
hauppauge, htpc
