Old 4th January 2009, 22:52   #401  |  Link
Chefkoch_ico
Well yes and no -- but lets not treat this like the sky is falling The only time it has problems is on sources that have mixed interlaced and progressive, which is very rare. I've done many, many discs that are VC-1 -- and they are fine. It wasn't until this week that I ran into the first disc that had this problem ("Band of Brothers").
I keep hearing this expressed as though VC-1 can't be backed up -- which is inaccurate.
On that you are right. At least you have done more tests than any of us :-) . It was my impression that it is more problematic (in my case 2 out of 5, 40%, of all discs I tested).
The real problem is, I need to check every VC1 video for distortions. Or when running over night and it crashes, the whole night is lost (for encoding :-) ).
Anyway, could it be done, that all VID_* AVS files be created immediatly after start of the backup and not immediatly before encoding for each stream starts? Please.
@laserfan:
not that it really matters, but search for all of my posts in the last days and you will see. I even created a batch file that could be called from BD-RB which does the whole indexing and so on.
Bye
Chefkoch_ico is offline   Reply With Quote
Old 4th January 2009, 22:54   #402  |  Link
Sharc
Interesting. It doesn't work for me either. Same blockiness as previously reported.
Hmmm... I can decode it with MPC-HC (home cinema) when I disable its internal Transform Filters VC1(FFmpeg) and disable H264/AVC(FFmpeg) and enable the Transform Filters VC1(DXVA) and enable H264/AVC(DXVA). The picture is decoded correctly but the audio is out of sync. Here another testclip:
http://www.mediafire.com/download.php?rt4djjjjwam
Scratching my head ....
Old 4th January 2009, 23:14   #403  |  Link
jdobbs
Originally Posted by [SLiM]D12 View Post
I just re-ran it and it appears to be multiplexing when it's doing this. I just restarted the encode, and it's resumed. It's multiplexing now, so i'll see what it does before it errors out, and i'll re-post
Are you using the latest version (v0.17.13)?
Website: www.jdobbs.net
Old 4th January 2009, 23:19   #404  |  Link
[SLiM]D12
0.17.12 right now. If it fails, i'll upgrade and try again. I have 158 streams to build and it's at 147 so far, so i'll post again when complete.
[SLiM]
[SLiM]D12 is offline   Reply With Quote
Old 4th January 2009, 23:20   #405  |  Link
Sharc
I wouldn't expect it to be a real problem for movie-only backups because all I have seen are purely progressive. The mixed progressive/interlaced VC-1 clips however seem to be quite common in Extras where videos (e.g. interviews) are mixed with clips of the movie.
From the BluRay discs I have seen so far about half are VC-1, and half are AVC. I have so far not seen any mpeg2 Blu-rays here (Region B).
Something else perhaps just to mention: I have read in another thread that Region Restrictions should better not be removed when ripping a BD with anyDVD as it may prevent or jeopardize playback on standalones.
Old 4th January 2009, 23:26   #406  |  Link
jwgallardo
Freezing in second pass
Hello, I just started my first project but the program got stuck initiating the second pass. I haven't stopped it yet but I almost sure it is frozen. The last write was done at 5:53am. The process started at 7:40PM. The movie is Shining. My computer is a Laptop Lenovo T61 with Core2 Duo T7500 @ 2.2 GHz and 2MB RAM. Windows Vista Business. I remember having a similar issue when encoding with DVD-RB for Mobile that I reported long time ago. It seems it was related to Windows Vista. Any ideas???
jwgallardo is offline   Reply With Quote
Old 4th January 2009, 23:29   #407  |  Link
laserfan
Aging Video Hobbyist
Ok, thanks. I must have a system problem then--I've not been able to get clean encodes of entire movies (movie-only).
laserfan is offline   Reply With Quote
Old 4th January 2009, 23:31   #408  |  Link
[SLiM]D12
Actually jdobbs, it got past the multiplexing part, it's copying files over now to my output folder. It failed copying this file:
E:\CERTIFICATE\app.discroot.crt.
[SLiM]
Old 4th January 2009, 23:48   #409  |  Link
Capsbackup
@jdobbs
my run time error 9, from 2 previous posts:
Just had a failed attempt, "Run-time error '9': subscript out of range. Happens as PHASE ONE completes, PHASE TWO - Rebuild Started. Press OK and BD-RB just closes. So I make a back-up folder and put the contents of the 1st attempt into that folder and restart BD-RB and press back-up again, and it continues after the resume message. However, after Rebuild appears to just finish the last M2TS, the same Run-time error pops up. Checking the two folders, the newly created and previously created but moved to a back up folder, BD-RB appears to have created the BDMV and CERTIFICATE folders for both attempts. Both have all the same files inside and report the same (3.71GB). Maybe I should try and burn this to disc just to see if it will play. if I can provide more info, let me know.
and:
Having "Run-time error '9': subscript out of range" on backup attempt of Pirates of the Caribbean Curse of the Black Pearl disc 2 bonus, with BD-RB 0.17.0.13. What does this error message mean and/or what could be the cause? I had this error 1 time before, but was not sure if anyone else has or a reason was found. Happens as "PHASE ONE completes, PHASE TWO - Rebuild Started", and press OK and BD-RB just closes.
What else can I provide?
Edit-here is the log:
[19:05:10] BD Rebuilder v0.17.13 (beta)
- Input BD size: 14.82 GB
- Approximate total content: [05:53:12.287]
- Target BD size: 4.27 GB
[19:05:14] PHASE ONE, Encoding
- [19:05:19] Reencoding: VID_00093 (1 of 121)
- [19:05:38] Reencoding: VID_00276 (2 of 121)
- [19:06:08] Reencoding: VID_00119 (3 of 121)
- [19:06:34] Reencoding: VID_00028 (4 of 121)
- [19:07:05] Reencoding: VID_00126 (5 of 121)
- [19:07:45] Reencoding: VID_00038 (6 of 121)
- [19:08:16] Reencoding: VID_00145 (7 of 121)
- [19:08:49] Reencoding: VID_00135 (8 of 121)
- [19:09:18] Reencoding: VID_00129 (9 of 121)
- [19:09:49] Reencoding: VID_00115 (10 of 121)
- [19:10:29] Reencoding: VID_00030 (11 of 121)
- [19:11:07] Reencoding: VID_00029 (12 of 121)
- [19:11:48] Reencoding: VID_00107 (13 of 121)
- [19:12:40] Reencoding: VID_00026 (14 of 121)
- [19:13:17] Reencoding: VID_00113 (15 of 121)
- [19:14:16] Reencoding: VID_00024 (16 of 121)
- [19:14:57] Reencoding: VID_00082 (17 of 121)
- [19:15:34] Reencoding: VID_00040 (18 of 121)
- [19:16:06] Reencoding: VID_00074 (19 of 121)
- [19:16:54] Reencoding: VID_00023 (20 of 121)
- [19:17:26] Reencoding: VID_00083 (21 of 121)
- [19:18:25] Reencoding: VID_00032 (22 of 121)
- [19:19:21] Reencoding: VID_00045 (23 of 121)
- [19:20:18] Reencoding: VID_00102 (24 of 121)
- [19:21:33] Reencoding: VID_00037 (25 of 121)
- [19:22:33] Reencoding: VID_00049 (26 of 121)
- [19:23:32] Reencoding: VID_00075 (27 of 121)
- [19:24:30] Reencoding: VID_00041 (28 of 121)
- [19:25:18] Reencoding: VID_00048 (29 of 121)
- [19:26:27] Reencoding: VID_00047 (30 of 121)
- [19:27:29] Reencoding: VID_00044 (31 of 121)
- [19:28:46] Reencoding: VID_00025 (32 of 121)
- [19:30:00] Reencoding: VID_00036 (33 of 121)
- [19:31:07] Reencoding: VID_00039 (34 of 121)
- [19:32:09] Reencoding: VID_00057 (35 of 121)
- [19:33:26] Reencoding: VID_00136 (36 of 121)
- [19:34:24] Reencoding: VID_00031 (37 of 121)
- [19:35:44] Reencoding: VID_00132 (38 of 121)
- [19:36:42] Reencoding: VID_00055 (39 of 121)
- [19:38:15] Reencoding: VID_00050 (40 of 121)
- [19:39:49] Reencoding: VID_00058 (41 of 121)
- [19:41:43] Reencoding: VID_00046 (42 of 121)
- [19:43:32] Reencoding: VID_00099 (43 of 121)
- [19:44:55] Reencoding: VID_00127 (44 of 121)
- [19:45:51] Reencoding: VID_00101 (45 of 121)
- [19:47:03] Reencoding: VID_00134 (46 of 121)
- [19:48:14] Reencoding: VID_00053 (47 of 121)
- [19:50:12] Reencoding: VID_00051 (48 of 121)
- [19:51:49] Reencoding: VID_00064 (49 of 121)
- [19:53:44] Reencoding: VID_00066 (50 of 121)
- [19:55:48] Reencoding: VID_00139 (51 of 121)
- [19:56:51] Reencoding: VID_00043 (52 of 121)
- [19:58:43] Reencoding: VID_00056 (53 of 121)
- [20:00:51] Reencoding: VID_00100 (54 of 121)
- [20:02:17] Reencoding: VID_00130 (55 of 121)
- [20:03:44] Reencoding: VID_00079 (56 of 121)
- [20:05:19] Reencoding: VID_00062 (57 of 121)
- [20:07:29] Reencoding: VID_00065 (58 of 121)
- [20:09:49] Reencoding: VID_00063 (59 of 121)
- [20:11:59] Reencoding: VID_00033 (60 of 121)
- [20:14:01] Reencoding: VID_00027 (61 of 121)
- [20:15:50] Reencoding: VID_00131 (62 of 121)
- [20:17:14] Reencoding: VID_00180 (63 of 121)
- [20:18:26] Reencoding: VID_00181 (64 of 121)
- [20:19:38] Reencoding: VID_00182 (65 of 121)
- [20:20:49] Reencoding: VID_00183 (66 of 121)
- [20:22:01] Reencoding: VID_00184 (67 of 121)
- [20:23:13] Reencoding: VID_00185 (68 of 121)
- [20:24:24] Reencoding: VID_00186 (69 of 121)
- [20:25:37] Reencoding: VID_00054 (70 of 121)
- [20:28:10] Reencoding: VID_00059 (71 of 121)
- [20:30:45] Reencoding: VID_00133 (72 of 121)
- [20:32:28] Reencoding: VID_00035 (73 of 121)
- [20:34:26] Reencoding: VID_00095 (74 of 121)
- [20:36:16] Reencoding: VID_00034 (75 of 121)
- [20:38:43] Reencoding: VID_00052 (76 of 121)
- [20:41:56] Reencoding: VID_00009 (77 of 121)
- [20:45:17] Reencoding: VID_00060 (78 of 121)
- [20:48:33] Reencoding: VID_00096 (79 of 121)
- [20:50:55] Reencoding: VID_00021 (80 of 121)
- [20:54:07] Reencoding: VID_00094 (81 of 121)
- [20:56:26] Reencoding: VID_00061 (82 of 121)
- [21:00:18] Reencoding: VID_00022 (83 of 121)
- [21:04:04] Reencoding: VID_00002 (84 of 121)
- [21:08:18] Reencoding: VID_00109 (85 of 121)
- [21:10:55] Reencoding: VID_00018 (86 of 121)
- [21:15:24] Reencoding: VID_00014 (87 of 121)
- [21:20:31] Reencoding: VID_00087 (88 of 121)
- [21:25:10] Reencoding: VID_00103 (89 of 121)
- [21:28:27] Reencoding: VID_00086 (90 of 121)
- [21:33:10] Reencoding: VID_00282 (91 of 121)
- [21:36:44] Reencoding: VID_00016 (92 of 121)
- [21:41:55] Reencoding: VID_00111 (93 of 121)
- [21:45:08] Reencoding: VID_00104 (94 of 121)
- [21:48:39] Reencoding: VID_00077 (95 of 121)
- [21:52:48] Reencoding: VID_00015 (96 of 121)
- [21:58:12] Reencoding: VID_00110 (97 of 121)
- [22:01:24] Reencoding: VID_00005 (98 of 121)
- [22:07:17] Reencoding: VID_00017 (99 of 121)
- [22:13:34] Reencoding: VID_00010 (100 of 121)
- [22:18:00] Reencoding: VID_00112 (101 of 121)
- [22:21:23] Reencoding: VID_00071 (102 of 121)
- [22:26:48] Reencoding: VID_00003 (103 of 121)
- [22:33:16] Reencoding: VID_00020 (104 of 121)
- [22:40:47] Reencoding: VID_00004 (105 of 121)
- [22:47:24] Reencoding: VID_00013 (106 of 121)
- [22:54:35] Reencoding: VID_00006 (107 of 121)
- [23:01:31] Reencoding: VID_00070 (108 of 121)
- [23:08:58] Reencoding: VID_00008 (109 of 121)
- [23:16:44] Reencoding: VID_00068 (110 of 121)
- [23:25:07] Reencoding: VID_00042 (111 of 121)
- [23:32:58] Reencoding: VID_00019 (112 of 121)
- [23:41:41] Reencoding: VID_00007 (113 of 121)
- [23:50:09] Reencoding: VID_00084 (114 of 121)
- [23:58:30] Reencoding: VID_00073 (115 of 121)
- [00:05:53] Reencoding: VID_00072 (116 of 121)
- [00:13:56] Reencoding: VID_00069 (117 of 121)
- [00:22:59] Reencoding: VID_00011 (118 of 121)
- [00:37:11] Reencoding: VID_00012 (119 of 121)
- [00:52:28] Reencoding: VID_00067 (120 of 121)
- [01:09:47] Reencoding: VID_00081 (121 of 121)
[01:32:56]PHASE ONE complete
[01:32:56]PHASE TWO - Rebuild Started
[05:17:39] BD Rebuilder v0.17.13 (beta)
- Resuming from previously started job.
[05:17:43] PHASE ONE, Encoding
[05:17:43]PHASE ONE complete
[05:17:43]PHASE TWO - Rebuild Started
- [05:17:43] Rebuilding stream 00093 [1 of 121]
- [05:17:44] Rebuilding stream 00276 [2 of 121]
- [05:17:44] Rebuilding stream 00119 [3 of 121]
- [05:17:45] Rebuilding stream 00028 [4 of 121]
- [05:17:46] Rebuilding stream 00126 [5 of 121]
- [05:17:46] Rebuilding stream 00038 [6 of 121]
- [05:17:47] Rebuilding stream 00145 [7 of 121]
- [05:17:48] Rebuilding stream 00135 [8 of 121]
- [05:17:49] Rebuilding stream 00129 [9 of 121]
- [05:17:50] Rebuilding stream 00115 [10 of 121]
- [05:17:51] Rebuilding stream 00030 [11 of 121]
- [05:17:53] Rebuilding stream 00029 [12 of 121]
- [05:17:55] Rebuilding stream 00107 [13 of 121]
- [05:17:56] Rebuilding stream 00026 [14 of 121]
- [05:17:58] Rebuilding stream 00113 [15 of 121]
- [05:18:00] Rebuilding stream 00024 [16 of 121]
- [05:18:01] Rebuilding stream 00082 [17 of 121]
- [05:18:03] Rebuilding stream 00040 [18 of 121]
- [05:18:04] Rebuilding stream 00074 [19 of 121]
- [05:18:06] Rebuilding stream 00023 [20 of 121]
- [05:18:07] Rebuilding stream 00083 [21 of 121]
- [05:18:09] Rebuilding stream 00032 [22 of 121]
- [05:18:11] Rebuilding stream 00045 [23 of 121]
- [05:18:13] Rebuilding stream 00102 [24 of 121]
- [05:18:15] Rebuilding stream 00037 [25 of 121]
- [05:18:16] Rebuilding stream 00049 [26 of 121]
- [05:18:18] Rebuilding stream 00075 [27 of 121]
- [05:18:19] Rebuilding stream 00041 [28 of 121]
- [05:18:21] Rebuilding stream 00048 [29 of 121]
- [05:18:23] Rebuilding stream 00047 [30 of 121]
- [05:18:25] Rebuilding stream 00044 [31 of 121]
- [05:18:27] Rebuilding stream 00025 [32 of 121]
- [05:18:29] Rebuilding stream 00036 [33 of 121]
- [05:18:30] Rebuilding stream 00039 [34 of 121]
- [05:18:32] Rebuilding stream 00057 [35 of 121]
- [05:18:34] Rebuilding stream 00136 [36 of 121]
- [05:18:35] Rebuilding stream 00031 [37 of 121]
- [05:18:37] Rebuilding stream 00132 [38 of 121]
- [05:18:38] Rebuilding stream 00055 [39 of 121]
- [05:18:41] Rebuilding stream 00050 [40 of 121]
- [05:18:43] Rebuilding stream 00058 [41 of 121]
- [05:18:45] Rebuilding stream 00046 [42 of 121]
- [05:18:47] Rebuilding stream 00099 [43 of 121]
- [05:18:48] Rebuilding stream 00127 [44 of 121]
- [05:18:49] Rebuilding stream 00101 [45 of 121]
- [05:18:51] Rebuilding stream 00134 [46 of 121]
- [05:18:52] Rebuilding stream 00053 [47 of 121]
- [05:18:54] Rebuilding stream 00051 [48 of 121]
- [05:18:56] Rebuilding stream 00064 [49 of 121]
- [05:18:58] Rebuilding stream 00066 [50 of 121]
- [05:19:01] Rebuilding stream 00139 [51 of 121]
- [05:19:02] Rebuilding stream 00043 [52 of 121]
- [05:19:04] Rebuilding stream 00056 [53 of 121]
- [05:19:06] Rebuilding stream 00100 [54 of 121]
- [05:19:07] Rebuilding stream 00130 [55 of 121]
- [05:19:09] Rebuilding stream 00079 [56 of 121]
- [05:19:10] Rebuilding stream 00062 [57 of 121]
- [05:19:13] Rebuilding stream 00065 [58 of 121]
- [05:19:15] Rebuilding stream 00063 [59 of 121]
- [05:19:18] Rebuilding stream 00033 [60 of 121]
- [05:19:20] Rebuilding stream 00027 [61 of 121]
- [05:19:23] Rebuilding stream 00131 [62 of 121]
- [05:19:24] Rebuilding stream 00180 [63 of 121]
- [05:19:25] Rebuilding stream 00181 [64 of 121]
- [05:19:26] Rebuilding stream 00182 [65 of 121]
- [05:19:27] Rebuilding stream 00183 [66 of 121]
- [05:19:28] Rebuilding stream 00184 [67 of 121]
- [05:19:29] Rebuilding stream 00185 [68 of 121]
- [05:19:31] Rebuilding stream 00186 [69 of 121]
- [05:19:32] Rebuilding stream 00054 [70 of 121]
- [05:19:34] Rebuilding stream 00059 [71 of 121]
- [05:19:37] Rebuilding stream 00133 [72 of 121]
- [05:19:38] Rebuilding stream 00035 [73 of 121]
- [05:19:40] Rebuilding stream 00095 [74 of 121]
- [05:19:43] Rebuilding stream 00034 [75 of 121]
- [05:19:46] Rebuilding stream 00052 [76 of 121]
- [05:19:48] Rebuilding stream 00009 [77 of 121]
- [05:19:52] Rebuilding stream 00060 [78 of 121]
- [05:19:54] Rebuilding stream 00096 [79 of 121]
- [05:19:57] Rebuilding stream 00021 [80 of 121]
- [05:20:00] Rebuilding stream 00094 [81 of 121]
- [05:20:02] Rebuilding stream 00061 [82 of 121]
- [05:20:05] Rebuilding stream 00022 [83 of 121]
- [05:20:07] Rebuilding stream 00002 [84 of 121]
- [05:20:09] Rebuilding stream 00109 [85 of 121]
- [05:20:10] Rebuilding stream 00018 [86 of 121]
- [05:20:13] Rebuilding stream 00014 [87 of 121]
- [05:20:16] Rebuilding stream 00087 [88 of 121]
- [05:20:18] Rebuilding stream 00103 [89 of 121]
- [05:20:22] Rebuilding stream 00086 [90 of 121]
- [05:20:24] Rebuilding stream 00282 [91 of 121]
- [05:20:27] Rebuilding stream 00016 [92 of 121]
- [05:20:31] Rebuilding stream 00111 [93 of 121]
- [05:20:32] Rebuilding stream 00104 [94 of 121]
- [05:20:35] Rebuilding stream 00077 [95 of 121]
- [05:20:38] Rebuilding stream 00015 [96 of 121]
- [05:20:43] Rebuilding stream 00110 [97 of 121]
- [05:20:45] Rebuilding stream 00005 [98 of 121]
- [05:20:49] Rebuilding stream 00017 [99 of 121]
- [05:20:53] Rebuilding stream 00010 [100 of 121]
- [05:20:57] Rebuilding stream 00112 [101 of 121]
- [05:22:07] Rebuilding stream 00071 [102 of 121]
- [05:22:10] Rebuilding stream 00003 [103 of 121]
- [05:22:13] Rebuilding stream 00020 [104 of 121]
- [05:22:18] Rebuilding stream 00004 [105 of 121]
- [05:22:22] Rebuilding stream 00013 [106 of 121]
- [05:22:26] Rebuilding stream 00006 [107 of 121]
- [05:22:31] Rebuilding stream 00070 [108 of 121]
- [05:22:35] Rebuilding stream 00008 [109 of 121]
- [05:22:40] Rebuilding stream 00068 [110 of 121]
- [05:22:45] Rebuilding stream 00042 [111 of 121]
- [05:22:50] Rebuilding stream 00019 [112 of 121]
- [05:22:54] Rebuilding stream 00007 [113 of 121]
- [05:22:58] Rebuilding stream 00084 [114 of 121]
- [05:23:05] Rebuilding stream 00073 [115 of 121]
- [05:23:09] Rebuilding stream 00072 [116 of 121]
- [05:23:14] Rebuilding stream 00069 [117 of 121]
- [05:23:19] Rebuilding stream 00011 [118 of 121]
- [05:23:26] Rebuilding stream 00012 [119 of 121]
- [05:23:35] Rebuilding stream 00067 [120 of 121]
- [05:23:44] Rebuilding stream 00081 [121 of 121]
Capsbackup is offline   Reply With Quote
Old 5th January 2009, 00:25   #410  |  Link
[SLiM]D12
upgraded both AnyDVD and DVD-RB and got this same error in the same spot.
[SLiM]
Old 5th January 2009, 01:51   #411  |  Link
liquidskin76
liquidskin76's Avatar
I've successfully done 'Sunshine' (UK version) to BD25 and all is ok. Using version .12 Also did 'The Fountain' (UK version) to bd25 using version .11 and all was ok.
Kept DTS audio on both and can confirm that it down converted from DTS HD Master to DTS ok. Also tried converting to AC3 and all was ok. Popup menus and extras all ok.
Hi jdobbs,
Are you able to tell us when you plan to add or activate the option to kept the original audio (be it DTS Master, TrueHD, or Uncompressed LPCM) instead of re-encoding?!
I've got my fingers crossed for the next update (.14)!!!
Many thanks for the work you are doing. My donation will be coming shortly!
liquidskin76 is offline   Reply With Quote
Old 5th January 2009, 06:05   #412  |  Link
KarstenS
Actually I am trying with Version .13 another Disney movie: Meet the Robinsons. Selected Soundtracks: AC3 and DTS German (reencoding disabled for both). Seems to work fine now. When its successfully finished, I will try again Enchanted.
Suggestion: Select at least one audio stream. The problem: When I setup german (ger; deu) as language, only german audio will be selected. But most extras and nearly all menus are with english marked audio stream. So I have to select audio streams for every file by hand, because it selects no audio stream for them at all.
KarstenS is offline   Reply With Quote
Old 5th January 2009, 11:08   #413  |  Link
spida_singh
Originally Posted by liquidskin76 View Post
Hi jdobbs,
I can confirm the same results with Ice Age 2, BD25 UK, DTS was down converted from dtshdma, total time was about 6 hours, very pleased with your work, again, +1 here for keeping original audio tracks, as I intend to create images using img burn for use with tmt within media portal, over my asus hdav13, many thanks for your software
spida_singh is offline   Reply With Quote
Old 5th January 2009, 13:35   #414  |  Link
Chefkoch_ico
Hi!
I was doing "I am legend" full copy to BD25. Worked fine. But there is an issue with audio streams.
When I started the movie I wondered where there is german audio, turns out if I select spanish, I hear german audio.
In BD-RB, there were the laguages like this:
[X] AC3, Eng
[X] TRUE_HD, Eng
[ ] AC3, Japanese
[ ] AC3, French
[ ] AC3, Italian
[X] AC3, German
[ ] AC3, Spanish
I found out, in the original m2ts the audio streams have the PIDs 4352 to 4358. German is there PID 4357.
In the m2ts created via BD-Rebuilder (btw. v0.17.13) the Audio PIDs are from 4352 to 4354 and german PID is 4354.
Bye
Old 5th January 2009, 13:47   #415  |  Link
jdobbs
And the error was "Runtime error 9?"
Old 5th January 2009, 13:50   #416  |  Link
piratburner
Hi jdobbs,
When this beautiful SW also have same functionality as TsMuxer/tsRemux You have my cent as well
piratburner is offline   Reply With Quote
Old 5th January 2009, 13:59   #417  |  Link
[SLiM]D12
Yup, error 9.
[SLiM]
Old 5th January 2009, 16:01   #418  |  Link
Capsbackup
Just completed backing up INDIANA_JONES_4_D2, which is disc 2 bonus features. I chose BD-5, full movie. Completed successfully but it turned out 6.38GB.
[09:39:02] BD Rebuilder v0.17.13 (beta)
- Input BD size: 21.15 GB
- Approximate total content: [02:41:34.217]
[09:39:02] PHASE ONE, Encoding
- [09:39:12] Reencoding: VID_00049 (1 of 18)
- [09:40:43] Reencoding: VID_00053 (2 of 18)
- [09:45:21] Reencoding: VID_00052 (3 of 18)
- [09:51:29] Reencoding: VID_00011 (4 of 18)
- [10:18:01] Reencoding: VID_00012 (5 of 18)
- [10:48:39] Reencoding: VID_00014 (6 of 18)
- [11:23:23] Reencoding: VID_00006 (7 of 18)
- [12:04:52] Reencoding: VID_00013 (8 of 18)
- [12:57:53] Reencoding: VID_00005 (9 of 18)
- [13:56:28] Reencoding: VID_00002 (10 of 18)
- [14:53:18] Reencoding: VID_00008 (11 of 18)
- [16:09:42] Reencoding: VID_00007 (12 of 18)
- [17:22:06] Reencoding: VID_00001 (13 of 18)
- [18:45:18] Reencoding: VID_00009 (14 of 18)
- [20:23:00] Reencoding: VID_00004 (15 of 18)
- [22:13:54] Reencoding: VID_00000 (16 of 18)
- [00:10:07] Reencoding: VID_00010 (17 of 18)
- [02:51:38] Reencoding: VID_00003 (18 of 18)
[06:28:52]PHASE ONE complete
[06:28:52]PHASE TWO - Rebuild Started
[06:29:30] - Encode and Rebuild complete
[06:29:30]JOB: INDIANA_JONES_4_D2 completed.
This is the second time this has happened to me, where I select BD-5 and it turns out over sized, but will fit on a BD-9.
Old 5th January 2009, 17:08   #419  |  Link
jdobbs
Can you send me your INI and INF files? dvd-rb@dvd-rb.com
I've never had an oversize, and I've tested that disc -- I'd like to see what you have set differently.
Old 5th January 2009, 18:05   #420  |  Link
pbeumer2001
I had a runtime 76 error. Theencoding was done and rebuilder wanted to convert the audio. Aften.exe crashed and rebuilder closed. Is the any way to try it again without reencoding the whole movie again?
pbeumer2001 is offline   Reply With Quote
