23rd October 2011, 16:54 | #6421 | Link |
hmm might be jans renderer acting strange with intels driver (though intels decoding performance is always the best with NV12 except if the input is natively 4:2:2 then it depends on the decoder as you saw from mainconcepts mpeg-2 vs lav video vs ffdshow test)
But this is a side thing the main issue is this freeze problem with this *.mov and lav splitter, where sound continues and video freezes without any warning (issue) before just rapidly instantly on 1 to the next frame it freezes (changing to MPC-HC Mp4/MOV splitter and it doesn't freeze) seeking is also not possible behind this point of freeze it just seeks the audio Though im not sure how to supply this without fixing it and a 1.24 GB sample upload would take some time if i find some space to host it :P
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd October 2011 at 17:09. |
23rd October 2011, 16:54 | #6422 | Link | |
That is strange, i just tested your latest build you posted and i got only static... I will post some samples.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
23rd October 2011, 16:58 | #6423 | Link |
I think i found the problem. If i now open WAV with DTS in graphstudio, it create LAV splitter to audio renderer connection, LAV audio decoder is not added.
23rd October 2011, 17:19 | #6424 | Link | |
Sadly detecting DTS-in-WAV in the splitter is not so easy at this time.
23rd October 2011, 17:21 | #6425 | Link |
funny trying to cut it with any ffmpeg based tools either crashes the host application or shows the same issues with seeking problems :P
VLC parses the freeze without issues though glitches for a moment encountering it that glitch is absolutely non visible with MPC-HCs splitter also seeking works with VLC (behind the problem) nev a debug version of lav splitter would be great maybe we can see something in the output i also prepare a video of showing what different parser do here
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd October 2011 at 17:29. |
23rd October 2011, 17:24 | #6426 | Link | |
23rd October 2011, 17:28 | #6427 | Link |
You can use some filter management tool to increase LAV Audios merit to something insanely high, maybe it helps.
23rd October 2011, 17:33 | #6428 | Link | |
Builds available here: http://ffmpeg.zeranoe.com/builds/ If i had to guess, that file just has multiple edit lists, which is not supported by ffmpeg.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd October 2011 at 17:37. |
23rd October 2011, 17:40 | #6429 | Link |
Converting 24bit int to 32bit float
@nevcairiel:
I have a rather strange kind of issue. I am using lavfilter (splitter, audio decoder) with MC17. My setup is rather special in that I use a convolution VST plugin (Convolver to run Audiolense FIR filters). Output is per ASIO to a Prism Orpheus. My issue is that I get (slightly) different results from outputting 32bit float (per setting this as only output format) from your decoder into the MC audio engine (64bit float) instead of the native 16bit/24bit int (flac files, bdmv's lossless tracks). So basically the difference (using 32bit float output from Lav audio decoder results in a "brighter", more aggressive, more forward and "focused" presentation. 24 bit int output into the audio engine is "smoother"). I don't want to sound like I have found another snake oil audiophile trick but results are reproducible and confirmed by my better half. I witnessed the same thing in the old days where I was ripping anything to flac in mkv's and using madflac (24bit/16bit int) or ffdshow (with 32bit float output). This definitely may have to do with my convolution which happens with 32 float processing. So in the end there has to be an int->float conversion somewhere - instead of JRiver MC audio engine doing it (using 24bit int from lav decoder) doing this conversion at lav audio level gives different results. Talking to the developer of Audiolense those time correction FIR filter are quite sensitive to any kind of jitter/distortion occurring between the decoder and the VST plugin. Question is: Does Lavfilter/ffmpeg do a reference job with int-> float conversion (when the int decoder output is converted to float for lossless tracks, I always thought this conversion to be practically lossless?!)? Is there any chance Lavfilter introduces jitter/any kind of distortion with this conversion? Is this better handled within the JRiver MC audio engine and the output of Lavfilter kept at its native decoder format? Any answer other than: "When your think to hear a difference use the one option you like better" is welcome ;-) Thank you! |
23rd October 2011, 17:52 | #6430 | Link | |
Too bad, it didnt help
23rd October 2011, 18:01 | #6431 | Link | |
I just have to say that I'm re-amazed every time when I see how responsive you and nevcairiel are w/ regarding to bug reports, development discussions/choices, and functionality explanations. That is w/o mentioning that you guys develop top notch projects for us to enjoy content watching. THANK YOU GUYS! |
23rd October 2011, 18:03 | #6432 | Link | |
I do now know what you mean with "reference job". Its a plain and simple conversion, just convert to float, and rescale to the 1.0 - -1.0 scale. No fancy features. The whole thing is mostly meant to disable formats that are not supported by your hardware and/or filters. In the end, thats what it comes down to, isn't it.
23rd October 2011, 18:32 | #6433 | Link |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd October 2011 at 18:56. |
23rd October 2011, 19:04 | #6434 | Link |
If the problem also occurs with all ffmpeg tools, its certainly a problem in ffmpeg itself, and you should figure out how to extract a sample that shows the freeze.
23rd October 2011, 19:16 | #6435 | Link | |
im open for ideas
i try with vlc/vlmc first hoping it wont fix it ok tried some stuff but nothing works this is also crazy Quote:
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd October 2011 at 21:42. |
23rd October 2011, 21:40 | #6436 | Link | |
Here is that post - http://forum.doom9.org/showthread.ph...22#post1529322 The file now plays perfectly with the new build so take that for whatever its worth and the audio sync is perfect. FWIW, I think the MP4 file that I was trying to view is the problem because all of my other Mp4 files worked perfectly with 36 & 37. Hope this helps and thanks for the work. |
23rd October 2011, 22:15 | #6437 | Link |
I got it it was easier then i thought the issue is propagating nicely into .mp4 as well (uploading) though some ffmpeg apps don't show issues anymore (Avidemux (or is it actually using libav parser?) ) but lavsplitter still freezes also ffplay does also videolan keept it's glitching @ that freeze frame and redos the title show (as it would seamlessly reopen the file)
http://www.mediafire.com/?yx92afb8mrn7r3r PS: remuxing with Avidemux 2.5.5 fixes this freeze Movie name : avidemux.mp4 Writing application : Lavf53.4.0
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd October 2011 at 23:10. |
23rd October 2011, 22:50 | #6438 | Link |
Hi nev,
I've been trying to get wasapi exlusive BITEXACT over ReClock with Lav Filters. Here is my HW, SW: GeForce GTX 550 TI on Clarkdale (i3 540/H55) nVidia driver version: 280.26 TMT5 5.0.1.114, MPC-HC 1.5.3.3757 with LAV Filters v. 0.37, ReClock 1.8.7.7... Media: Chris Botti Live; the unique 96/24/5.1 PCM source i can find out yet... Here is how to configure my MPC-HC: Internal filters: completely disabled while lav fiters are enabled and preferred on external filters section. Here is the chain on MPC-HC: And if you notice ReClock only detect WASAPI Exclusive [B]but not bitexact: While it detects Wasapi exclusive bitexact on TMT 5: (I uploaded a BDMV, please create an ISO with ImageBurn and open it on Virtual Clone Drive's fake driver. Otherwise TMT downsamples it to 48/6/16... Here is the sample file: http://www.mediafire.com/?26z6a1w3lkia68a Could you have a look at? EDIT: I've met this issue only with PCM unmolested streaming, no issues with DTS HD or THD bitsreaming. LATEST EDIT: Fixed: http://forum.doom9.org/showthread.ph...40#post1534340 - - - - - _ _ _ _ _ Last edited by rica; 26th October 2011 at 22:10. |
23rd October 2011, 23:00 | #6439 | Link | |
In this mode wavpack will create 2 files on encoding (.WV + WVC) if it can't encode lossless with the specified bandwidth. The WV will then be lossy or lossless and if lossy, a WVC is created to make it possible to make the process lossless. Suppose the WV is lossy, then WV + WVC = lossless. A very nice concept anyway ! |
23rd October 2011, 23:17 | #6440 | Link |
Does LAVVideo support DXVA with Ati? I'm getting extremely high CPU usage for H264/BR playback but with FFDShow's DXVA I get barely any. I didn't realise until now that LAVVideo was chewing through my CPU until I went to play some 1080P content.
Happy to stick with FFDShow's DXVA if Lav Video is no good for Ati users anymore. |
