12th January 2014, 18:48 | #18781 | Link |
Well i figure it' be worth mentioning here for all the ppl here that might still use vista like myself. 3D rebuild will NOT work on vista, the test build i received from Jdobbs works fine on the extraction part but FRIM errors out on the actual frameserving / encoding part. So w7 and up is mandatory.
12th January 2014, 21:39 | #18784 | Link |
No, need to assume. You can be assured no XP support and no it is not Jdobbs fault. Program he uses require win 7 at minimum to work.
If you fail to plan; you plan to fail, would you not agree? Think about it. |
13th January 2014, 01:07 | #18786 | Link |
Failed Video MVC Reencode with 3D Movie Hugo
When doing a movie only copy of Hugo 3D to BD-9 on a Windows 8.1 system, the reencode using FRIMEnoder has failed on two attempts. On the first, it failed on the first pass at around 99%, and on the second it failed on the first pass at around 83%. The log file simply says Failed video encode.
Let me know if what I need to provide to help in the troubleshooting. In the mean time I'm going to attempt a rebuild of a different movie to see if the same thing occurs. Last edited by DarWun; 13th January 2014 at 01:13. |
13th January 2014, 05:48 | #18789 | Link | |
Thank you for your answer. |
13th January 2014, 10:38 | #18790 | Link |
aka Rabomil
OK and only ABR, not CRF.
I have a question about the quality of the new 3D mode. Does it make a difference in quality to use the existing (x264) quality profiles, or is there just one quality? I assume that the tweak lines concerning encoder settings do not work in this new 3D mode. Am I right? |
13th January 2014, 14:38 | #18791 | Link | |
I could add tweak settings that are specifically aimed at FRIMEncode if that's any help. Last edited by jdobbs; 13th January 2014 at 14:41. |
13th January 2014, 15:32 | #18792 | Link | ||
Jdobbs, not sure if you considered this but I was wondering if you process 3d disc, does you program give option to copy as 2D or will it force 3D output. If it does 3D can you add option to have final output 2D instead of 3D.
Also I think we don't need this anymore as a hidden option, what do you think. Quote:
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 13th January 2014 at 15:36. |
13th January 2014, 15:48 | #18793 | Link | |
I need to remove the DTSX_ENABLE setting and add the new one (IGNORE_3D). DTSX_ENABLE has no effect now. Last edited by jdobbs; 13th January 2014 at 15:51. |
13th January 2014, 15:59 | #18795 | Link |
Jdobbs, Can BD-RB capable of handling of secondary video processing with new version of tsmuxer.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 13th January 2014 at 16:02. |
13th January 2014, 16:10 | #18797 | Link |
I am not thinking straight coffee time for me.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 13th January 2014 at 16:18. |
13th January 2014, 16:21 | #18798 | Link |
Also may I suggest to add check of frim decoder and encoder version to inspect.exe report
13th January 2014, 16:49 | #18800 | Link |
While you are at it, you may want to check the following. Basically I replace tsmuxer.exe with new version from Roman (tsMuxeR_2.6.12) and inspect said ok in my case, it shouldn't be doing that or it is expected.
If you fail to plan; you plan to fail, would you not agree? Think about it. Last edited by HWK; 13th January 2014 at 16:53. |
