8th March 2009, 09:55 | #8484 | Link | |
I had such AC3 File yesterday. Its a AC3 from a DVB-C HD Capture. The First Frame/032ms is 2.0. eac3to/tsmuxer etc cant detect the AC3. Cutting out 32ms works perfect |
8th March 2009, 11:42 | #8485 | Link |
OK, I'm sorry, I just assumed that seeing as I processed an HD-DVD DD+ track using QuickFix.cmd (which I'm sure is part of ToNMT) and it then played on my PS3 as DD+ that it must be doing some sort of conversion. All I know is, you can play DD+ from a HD-DVD on a PS3 in the AVCHD format.
8th March 2009, 14:52 | #8486 | Link | |
Is this actually used in real life anywhere?
This will be fixed in the next build. |
8th March 2009, 14:58 | #8487 | Link | ||||
No. And I see no reason to do that.
------ Guys, I'm very much willing to fix bugs in eac3to. But I'm not going to spend hours and hours on trying to figure out which of the various tools you're using is responsible for a specific problem you have. If you want me to look into a problem then you should better provide some convincing proof that the problem is actually caused by eac3to. |
8th March 2009, 15:46 | #8488 | Link |
eac3to v3.13 released
http://madshi.net/eac3to.zip Code:
* fields and frames are counted and displayed separately now * added DIRAC bitstream parser * added support for "-24.975" and "-changeto24.975" * Blu-Ray subtitle demuxing: PTS value is now written to both PTS + DTS * joining MKV files is now declined with a proper error message * last chapter is now removed, if it's less than 10 seconds from end of movie * fixed: "-normalize" didn't work with stdout, anymore * fixed: audio delay was incorrect when 1st m2ts part contained no audio data * fixed: very small WAV files were not detected correctly * fixed: "eac3to source.eac3 dest.dts -core" crashed Last edited by madshi; 8th March 2009 at 16:52. |
8th March 2009, 15:52 | #8489 | Link | |
8th March 2009, 16:12 | #8491 | Link |
The extracted THD is not identified by MediaInfo nor can it be played in MPC-HC with decoders such as CyberLink. The converted THD+AC3 can be be but the duration and playback is wrong (or presumably the playback is "accurate" but the conversion is screwy). The extracted THD can be played with a plugin for Winamp based upon mlpdec module from FFmpeg and as said converts okay to DTS.
I thought it might demonstate that the THD track was odd and thus the dodgy conversion to THD+AC3. But anyway it is not really worth spending anymore time on -especially as the conversion to DTS is fine. Again, I do appreciate your time and excellent tool. Oops, typo in the new version release above... should be v3.13 -madshi needs a well deserved break |
8th March 2009, 16:55 | #8492 | Link | ||
No, not at all. Most probably PDVD always reports MLP for every THD+AC3 track. |
8th March 2009, 16:59 | #8493 | Link | |
Aging Video Hobbyist
eac3to v3.13 command line: eac3to E:\MAMMA_MIA!\BDMV\STREAM\00289.m2ts 1: test.vc1 ------------------------------------------------------------------------------ M2TS, 1 video track, 1 audio track, 3 subtitle tracks, 0:02:40, 60i /1.001 1: VC-1, 1080i60 /1.001 (16:9) 2: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz, dialnorm: -4dB (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB) 3: Subtitle (PGS), English 4: Subtitle (PGS), Spanish 5: Subtitle (PGS), French [v01] Extracting video track number 1... [v01] Creating file "test.vc1"... Video track 1 contains 4800 frames. eac3to processing took 11 seconds. Done. |
8th March 2009, 18:13 | #8494 | Link |
No, this specific THD (at least) cannot be identified by MediaInfo or played by MPC-HC but after conversion to THD+AC3 it can. As far as I recall, other unaltered THD+AC3 (such as from BD) can likewise be identified and played but I would have to check more to confirm. Would have to check PDVD identification as well.
The duration of the THD+AC3 (converted) is crazy long and the counter plays fast. Plus as said the audio drops out or in other words is a bit warbly. As for the BD subtitle problem, would that affect their display in MPC-HC? Because I notice that whether they are shown or not is unreliable and sometimes takes toggling off/on in the menu under subtitles and under splitter, but I assumed that was the fault of the internal splitter. Also, did the same problem exist with extraction from HD DVD or is that not applicable? Is there any way to fix already extracted SUP files (copy PTS value to DTS -if that turns out to be the fix)? |
8th March 2009, 22:28 | #8495 | Link |
No, it shouldn't be THAT noticeable, but again it's the principle of the thing And sure, recoding to TrueHD would be great, but no more affordable: you need the same program from Dolby. Surcode has an MLP encoder but I don't know if there's any way to convert the output to useful TrueHD.
8th March 2009, 23:20 | #8496 | Link | |||
eac3to doesn't handle interlaced VC-1 streams well in the moment. That's still on my to do list. Frame/field counting should work fine for h264 and MPEG2, though. Quote:
These are most probably not eac3to problems. So let's please finally stop discussing this. Unless you find some proof for an eac3to bug. Why don't you try for yourself? |
9th March 2009, 00:22 | #8497 | Link |
Sorry. Interlaced, of course! And my post was indeed about a VC-1 clip. If you can detect/identify the messes that are these hybrid VC-1 clips, you will join neuron2 as the only who's figured these out AFAICT.
9th March 2009, 01:37 | #8498 | Link |
This seems like a very useful tool, however I'm not sure about a few of these additional programs or plug-ins that are required for some of its most useful features.
The Nero HD-DVD/Blu-Ray plug-in isn't even available anymore, so I'm not sure how people who didn't buy it during the relatively short window it was for sale would get it. As for the Arcsoft plug-in, I'm not sure which of their programs this one comes with, however I haven't heard great things about their software so I wouldn't really want to pay for it anyway. And Surcode's DTS plug-in is ridiculously expensive. Are there any alternatives to some of these impractical plug-ins? |
9th March 2009, 05:27 | #8499 | Link |
Madshi
Sorry to do this to you but there seems to be a problem introduced in 3.13. The output audio is corrupted when the input file is a wav. I ran... "D:\Vtemp\programs\eac3to\eac3to.exe" mh2.wav mhtest2.flac ...with this test file. It's processed correctly in 3.12. NB if you play back the corrupt output file turn your speakers down. The noise is pretty loud Thank you. |
9th March 2009, 08:59 | #8500 | Link | |
32-bit and 64-bit floating point WAV files made with Audacity crash eac3to 32-bit doesn't. All the FLAC files have differen't sizes and aren't identical to test3.wav. Notice the repeated sound in the beginning. I've included a reference FLAC file named audacity.flac. http://www.stfcc.org/misc/wavs.zip (51,803,165 bytes) - should be finished uploading within 30 minutes of posting this. |
eac3to |
