1st April 2009, 11:42 | #3102 | Link |
I don't have the time to look into VLC's source code, but I assume it takes changes in the cell-id as chapter points, which have a 1-to-1 relationship to chaptermarks found in the IFO for 99% of the DVDs that are not using multiple angels.
1st April 2009, 14:36 | #3103 | Link |
NY Frame of Mind
Thank you dean! I appreciate the apology and accept it in the spirit it was intended.
You, in fact, have been very helpful in your previous responses to me. (thank you for the pm,as well) So, moving forward, in that spirit, I have deleted my post(s). No hard feelings. Last edited by rapscallion; 1st April 2009 at 17:58. Reason: spelling |
1st April 2009, 17:19 | #3104 | Link | |
Yup i have the same problem with some working and others not working with DTS-HD and i have a Kaiboer K300 seams we need a fix. |
1st April 2009, 19:44 | #3105 | Link | |
1st April 2009, 21:47 | #3106 | Link | |
just the DTS HR track then it works just fine though. |
2nd April 2009, 12:09 | #3107 | Link | |
It wont work ! You have to mux it fully new with the untouched Source Files. It works 100% fine with all DTS-HRA i tried so far on my Popcorn A110 DTS-HD MA Audio works fine here. Also with the latest Version of TSMuxer I agree we need a fix for DTS-HD/HR muxing. Theres obviously something wrong when Standalone Players cannot handle the Output from TSMuxer. Last edited by ACrowley; 2nd April 2009 at 12:13. |
2nd April 2009, 14:08 | #3109 | Link | |
I have many others with DTS-HD Master and it plays the core just fine but no matter what i do with the ones that dont it just wont work until i remux to have just the DTS core and not the Master audio then it works and only then. |
2nd April 2009, 18:16 | #3110 | Link | |
However, i ve no Problems with DTS-HD MA/Core with latest Version on Popcornhour A110. Its DTS-HRA what makes Problems (also not the Core) But, when you dont have a HD Audio capable Receiver, why do you mux the DTS HD Data with possible Problems, doesnt make Sense for me? Last edited by ACrowley; 4th April 2009 at 08:45. |
2nd April 2009, 18:35 | #3111 | Link | |
4th April 2009, 09:59 | #3114 | Link |
I have a TviX 6500 and have sound problems (No sound) with several BD disc, one example are this Licence to Kill 1989 1080p Blu-ray CEE AVC DTS-HD
Info regarding sound track. Audio #1 ID : 4352 (0x1100) MenuID/String : 1 (0x1) Format : DTS Format/ : Digital Theater Systems Format_Profile : HRA Duration/String : 2 h 13 min Bitrate : 3 045 Kbps Kanal(er) : 6 kanaler Kanalplatser : Front: L C R, Surround: L R, LFE Samplingstakt : 48,0 KHz Upplösning : 24 bits |
4th April 2009, 10:03 | #3115 | Link | |
Newer Version of TSmuxer wont work properly with DTS HRA Tracks I assume it works for your Player too with old 1.2.9 Version. Works for me with DTS HRA on my NMT A110 http://www.videohelp.com/tools/tsMux...sions#download Last edited by ACrowley; 4th April 2009 at 10:06. |
4th April 2009, 10:03 | #3116 | Link |
And this BD disc works Never Say Never Again 1983 1080p Blu-ray AVC DTS HD-MA 5.1
Audio ID : 4352 (0x1100) MenuID/String : 1 (0x1) Format : DTS Format/ : Digital Theater Systems Format_Profile : MA Duration/String : 2 h 14 min Kanal(er) : 6 kanaler Kanalplatser : Front: L C R, Surround: L R, LFE Samplingstakt : 48,0 KHz Upplösning : 24 bits Språk : Engelska So its must be the Format_Profile : HRA that cause problem in the TsMuxer |
4th April 2009, 10:06 | #3117 | Link | |
To bad , the "Create Blu-Ray disc" is not supported :-( Is there a newer version that works with HRA and Create Blu-Ray disc ? Last edited by piratburner; 4th April 2009 at 10:10. |
5th April 2009, 06:49 | #3120 | Link |
the latest version tsMuxer should supports subtitle right? I tried to with Fearless bluray as a test but with no luck. Both WDTV and WMP will not display the subtitle when requested. Is this a bug? I know subtitle worked fine with other versions of tsMuxer
tsmuxer |
