30th September 2005, 19:53 | #263 | Link | |
Swallowed in the Sea
YAMB 1.3 is out
Finally...I kicked my own ass and I release a new YAMB version.
Changes from version 1.2.1 to 1.3 : Quote:
In addition, I would say that you can see MediaInfo.dll in these packages. It's just to have some infos concerning import settings (just move the mouve on edit area). By example : Enjoy... |
30th September 2005, 21:22 | #265 | Link |
Life's clearer in 4K UHD
Very, very nice work indeed Kurt
Shame Bond is not here to comment.... Where is that boy? Just tested some basic muxes so far.... But will try some tougher ones tomorrow! Many thanks
30th September 2005, 21:49 | #266 | Link |
I've found a bug
When you try to extract an MPEG-4/SP/ASP or AVC stream from an MP4 file the "Extract Track".... "in RAW format" and "to new MP4 file" options operate the wrong way round (ie: the RAW option creates an MP4 file and MP4 option creates an RAW file). Plus when you try and change/switch between the RAW and MP4 output options YAMB crashes... Cheers
1st October 2005, 07:40 | #267 | Link | |||
And yesterday, I forgot to mention one thing : if you want to change output folder for the mux, you need to make a double click on the edit area to open the SaveDialog box... |
1st October 2005, 10:35 | #268 | Link | |
YAMB (v1.3.0)
Cheers
1st October 2005, 11:42 | #269 | Link |
I've just installed YAMB v1.3 using your "setup.exe"... But when I tried muxing and de-muxing I got this: -
EDIT: I don't seem to be able to use YAMB at all with your build of MP4Box.exe Cheers
1st October 2005, 11:57 | #270 | Link |
clueless n00b
isn't that error message rather self-explaining?
1st October 2005, 12:30 | #271 | Link | |
Does this error message mean "libmmd.dll" is missing from YAMB or from Kurt's MP4Box.exe compile! This error only shows up when installing Kurts full version of YAMB (ie: with his MP4Box compile). When running YAMB "lite" (for want of a better expression), this error message does not appear! Cheers
1st October 2005, 12:38 | #272 | Link | |
clueless n00b
IIRC libmmd.dll is a dll from the intel compiler.. you just need one in your system but without it, a bunch of apps I know that have been compiled with the intel compiler cannot be executed.
1st October 2005, 13:01 | #273 | Link |
i extracted the yamb only package to my mp4box folder and i got a "access violation at adress blabla in module yamb.exe. read of adress blabla". after clicking ok yamb seems to open normally.
i use win2000
1st October 2005, 13:21 | #274 | Link |
Indeed...I forgot to put libmmd.dll in the whole package. So, redownload it (same link as above) or grab the library here.
@Bond: pretty strange...did you use a win98 or older system before ? if yes, wait the non unicode version. |
1st October 2005, 13:23 | #275 | Link | |
1st October 2005, 14:53 | #276 | Link | |
I'm able to confirm my previously mentioned "Extract Track" bug (YAMB crash) also happens with your supplied build of MP4box.exe Cheers
1st October 2005, 18:04 | #277 | Link |
Try this build please...
1st October 2005, 18:08 | #278 | Link |
no error anymore
1st October 2005, 18:34 | #279 | Link |
Yep... you seem to have cracked it with your revised build Kurt!
Nice one... a brilliant little application EDIT: The AAC-HE "signalling" option works well.... It even flags up the "AAC h" icon in ShowTime player now... Cheers
