5th December 2004, 13:58 | #101 | Link |
(schein)heilig
I don't care about where additional lame settings are placed. Who needs more than "alt presets" anyway? But better leave azid options where they are. BeLight tabs are meant to be encoder tabs, while azid is a decoder.
There's an issue with OTA's gain settings and AAC encoding. I thought this has been mentioned here already, but I can't find it; so sorry if I'm repeating known things. When encoding to AAC (using BeLight 0.19) and "View command line" is disabled OTA's gain always jumps to "PostGain" when pressing "Start". Also the logfile shows that BeSweet indeed uses "PostGain" in this case. When "View command line" is enabled the GUI still jumps back to "PostGain" (including the command line string) but according to the logfile "PreGain" (or "hybrid", depending which you chose) is used. For other destination formats (I only tested mp3) BeLight doesn't display this behaviour.
Brother John When lost in BeSweet's options, have a look at the Commandline Reference. DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen! |
5th December 2004, 14:28 | #102 | Link | |||||||
Swallowed in the Sea
Re: Size issues again
Heyaaaa...
Sorry for the delay guys. Quote:
5th December 2004, 18:43 | #103 | Link | |
digitally remastered
Oh, I forgot something: Another good thing would be if settings are automaticly loaded with starting the prog.
May The FourCC Be With You |
10th December 2004, 16:06 | #105 | Link | ||
11th December 2004, 15:24 | #106 | Link |
Excellent work with the new GUI, Kurtnoise13.
I just noticed one thing though. The old version supported DTS input. This one doesn't seem to support DTS input. I tried selecting 'All Files' at the input then chose my DTS file but when I hit Start it crashed. Anyway, just ignore this if its too much trouble. You must have your own reasons why you didn't add DTS input support. I'll just use the old one for DTS inputs and use BeLight for AC3 inputs. Nice job.
My awesome rig for ripping: i286 CPU @ 10MHZ 8 Mbyte RAM 2MB Trident Graphics 20MB Hard Disk 3,600RPM 14" VGA Monitor Built-in PC speaker Windows 3.1 WinZip and WinRar - (for compressing my DVD movies) (I'm a HQ freak so I always do a 2-floppy disk rip) |
11th December 2004, 15:59 | #107 | Link |
Happy XviD user
And a feature request:
When you open a file with the "open file with" windows dialog, and choose belight, belight opens but the input file box is empty instead with the file you opened.
Mira detras de ti... ĦUn mono con tres cabezas! (Guybrush Threepwod) |
11th December 2004, 19:28 | #108 | Link | |||
Anyway, I hope to finish to finalize the new release tomorrow...sorry for the delay. |
12th December 2004, 22:40 | #109 | Link |
As I said yesterday, here's a new build : 0.20 beta 1. It's just bugs fix release. A lot of internal/external bugs have been corrected...I hope everything is ok.
Just one note : BeLight now saves/load your own options as soon as you close/open it. So, the loading & saving manual settings has disappeared from the Menu. @WinsomePix : I tested on 2 different PC with a 1024x768 resolution and all seems to work fine (no cut off, etc...). Please, tell me if all it's ok for you too. [edit]--typo Last edited by Kurtnoise; 14th December 2004 at 09:15. |
14th December 2004, 12:19 | #111 | Link |
bug-report/feature-request...
Hi Kurtnoise13,
I am pretty new to BeLight - used BeSweetGUI til now and got quite used to it's overloaded GUI; but as I am always looking for new challenges I decided to give BeLight a try... What I can't find at first sight is where to enter the path to BeSweet.exe -- or does besweet HAS to be in %PATH% ? Or does BeLight _need_ to be in the same directory? - there was no readme.txt/install.txt or whatsoever in "BeLight-0.20b1.zip" Next thing is when clicking on 'Input' and dropping down the 'Files of type' list, there are entries like " --- BeSweet List Files ---" and " --- Container Files ---"; the first include .lst and .mux and the second .avi and *.* What I am missing is an entry for the sound formats as such (the types above " --- BeSweet List Files ---"). Furthermore this does not work at all: If I have a test.lst and a test.mux in one directory and select "LIST Files (*.lst)" only test.lst is shown; so is only test.mux shown when I selected "MUX Files (*.mux)". That's what I expected -- but when I select " --- BeSweet List Files ---" as Type NEITHER of both is shown while I expected BOTH... -- I thing You only ment those entries to be separators but then You also should prevent those to be selected at all... gr33tz, guru |
14th December 2004, 13:31 | #112 | Link | ||
Re: bug-report/feature-request...
14th December 2004, 13:43 | #113 | Link | ||
14th December 2004, 17:34 | #114 | Link | |
Re: Re: bug-report/feature-request...
On the other hand (and/or if this is not possible) it should be a piece of cake to associate ALL the filter-types of one section to the according separator, or not? - i.e. selecting " --- BeSweet List Files ---" sets the filter to "*.lst or *.mux" Just a suggestion guru Last edited by guru1968; 14th December 2004 at 17:36. |
14th December 2004, 20:34 | #117 | Link | |||
Re: Re: Re: bug-report/feature-request...
BTW, I need you to have your point of view. I'm preparing some Presets for transcode processing. That's why I would like to have some feedbacks or suggestions for these things. I post 2 pictures : and 0.20 beta2 (with the 2 bugs corrected) to see how we can manage the different presets. So, what do you think about that ? Is it ok or not ?? Thanks guys .... |
14th December 2004, 20:42 | #118 | Link | |
Re: Re: Re: Re: bug-report/feature-request...
am I just missing it? |
14th December 2004, 23:20 | #120 | Link | |
And i think all the presets for all the speakers config. would be better (tape, radio, internet and streaming for 2.0 and 5.1 in HE) Anyway it looks great. Go on with the GUI Kurtnoise13 |
