25th April 2009, 13:47 | #2402 | Link | |
Life's clearer in 4K UHD
AVCHD on SD Card Testing - 1280x720
EDIT: Here's a sample.
25th April 2009, 13:51 | #2403 | Link |
Programmer (or just 教务长)
Here is another small SAMPLE#12 - 1280x720 - 1.5MB.
I hope it will work. You can do some tests yourself: Generate SDHC output and try this: 1) Change the value at offset 0x108 in 00000.CPI file from 0x51 to 0x41. Just the first octet. If it is 51 -> 41, 52 -> 42, etc. 2) Change the value at offset 0x82 in 00000.MPL file the same way. Last edited by deank; 25th April 2009 at 13:58. |
25th April 2009, 14:53 | #2406 | Link |
Just tried samples 11 & 12.
Both play audio - 11 gives a piano, 12 gives tone. Both a black screen though. Also tried my own 720p@23.976 AC3 6ch = no go, just the direct navigator. Haven't tried editing the files like you suggested - wouldn't know how. All on my PAL BD35 firmware v1.4 |
25th April 2009, 14:58 | #2408 | Link | |
Best regards. |
25th April 2009, 15:03 | #2410 | Link |
I have a Panasonic TH-46PZ81B TV with built-in SD card slot, that can play std-def and high-def SD camcorder captures...
25th April 2009, 16:09 | #2411 | Link |
Here's my first test. Source is NTSC 1080i 29.97. I wasn't exactly sure how to handle the conversion, so I tried to keep the same settings and keep the file interlaced.
My first attempt actually plays in my BD60. Great work, deank! Here is my test sample, please let me know if it works. SD_TEST_DS001 Can someone please share the best settings for MeGUI x264? What is the best way to handle 1080i 29.97 broadcast source, should it be de-interlaced and converted to another framerate? Here are the settings I used: |
25th April 2009, 16:37 | #2412 | Link |
Programmer
Testing now on BD30
UPDATE: MKV 720p would not work, but maybe I am getting menu struture wrong. Should DCIM folder remain? I had removed it. Also I copied the AVCHD file to PRIVATE, so it was: PRIVATE -->AVCHD ----->AVCHDTN ----->BDMV Direct Navigator came up on BD30 and said there were no pictures to load. Anyone get their MKV files working an Panny BD player and if so what steps did you follow? UPDATE: Forgot to mention, this was a 1280x720 MKV. I will see if I have other resolutions to test but this is a very common one for 90% of my MKV files. Last edited by jfcarbel; 25th April 2009 at 17:17. |
25th April 2009, 16:38 | #2413 | Link | |
When I selected the SD Card, it loaded into the "Direct Navigator" playlist screen showing your clip as "001 multiAVC 00:15". When I pressed OK or Play, it said "Cannot Play" and it did not play. So, I hit Return to escape back out of the "Direct Navigator" AVC playlist screen and returned to the blank Panasonic blue background with the Blu-ray logo in the background and no menu. I pressed Play from this default player background page and then I saw flashes of Blue to Black to Green colors, then your video and audio played fine. After the video completed, the screen flashed Blue, Black and Green again then returned to the Panasonic blue background screen. Last edited by davsim; 25th April 2009 at 16:47. |
25th April 2009, 16:57 | #2414 | Link | |
SAMPLE#11: plays video and audio fine. loads properly in the Direct Navigator playlist screen Last edited by davsim; 25th April 2009 at 17:14. |
25th April 2009, 17:14 | #2416 | Link | |
SAMPLE#12: an interesting result: played from the playlist, a continuous audio tone is heard, but there is no picture, just a black screen. BUT, if I scan forward, I can see a few frames of orange, red SMPTE leader countdown numbers as shown in your uncropMKV screenshot. Another odd thing is that the scan forward (fast forward) doesn't stay on as normal, it flashes forward showing you video for a few seconds, then goes back to normal play speed and shows the blank/black screen. On a normal program, scan/fast forward will stay active until manually deactivated. It is possible that the clip is too short and stops at the end, but it is odd that it only shows a few picture frames before going back to black even at the slowest scan forward speed. Last edited by davsim; 25th April 2009 at 17:16. |
25th April 2009, 17:19 | #2417 | Link | ||
Programmer
UPDATE: Does not play with the DCIM or MISC files present either, bummer. I just don't get how Dean's 1280x720 MKV sourced worked on my BD30 but not this one. I am going to format my SDHC with Panasonic Formatter and give it another go to see if that makes any difference. UPDATE2: Tried the reformat and added DCIM and MISC from the Sample10 that had worked on my BD30, but no luck. Here is mediainfo for my file: Quote:
25th April 2009, 17:24 | #2418 | Link | |
You've just identified the first BD player that will handle 1920x1080@60P video. Congratulations. It wold be interesting to see how well the BD60 will handle it in BR and DVD-R. Thanks and best regards. Last edited by mariner; 25th April 2009 at 17:28. |
25th April 2009, 17:35 | #2419 | Link |
Programmer
Panasonic BD30 Latest 2.8 firmware
SAMPLE#12: Does not play, panasonic video menu does show and title shows multiAVCHD, but when go to play clip just get black screen and pops back to menu. SAMPLE#11: Show video menu, video appears to play but its only a thumbnail in upper left corner that flashs on and off with just the first frame from the video, so no go on the BD30 Last edited by jfcarbel; 25th April 2009 at 17:51. |
