7th February 2010, 22:45 | #761 | Link |
Having issues with the x264 build from the dev-server here.
The resulting video does not play correctly with ffdshow (skipping several frames, repeatable) and it cannot be muxed with MKVtoolnix. I coded the file again with the new x264 build and again it failed. Downgraded to x264 from stable server: File is 100% ok, muxes fine. Any idea what's wrong with the dev-build? Thanks |
8th February 2010, 04:27 | #763 | Link | |
could some one suggest me how can i reverse all the chnges that have been made in last 2 updates ( the first had some files other than x264 build updated and the second has x264 and a few more ) after that i didnt update at all.. |
8th February 2010, 17:22 | #764 | Link | ||
I have forced a downgrade at the development server now. I have still no problems but there have been several reports like yours. Quote:
It may be that the video is fine but your decoder can't play it properly. Try adding --weightp 0 to the custom command line. |
8th February 2010, 17:49 | #765 | Link |
I'm not sure if this will help, but I have been using an AMD optimized 1416 version compiled by outlaw87 over at Doom10 without any problems. My encodes are TGMC'ed DVD videos...
Here's the link to grab the build, if you guys want to try it out. http://doom10.org/index.php?topic=26.msg1265#msg1265 My settings are simply CRF 21 with Preset "Slower", tuning Film. Nothing else. |
9th February 2010, 01:35 | #767 | Link |
Just for the record, I too had issues with x264 1416. My encode would go for about an hour and then x264 would crash. It did this twice in a row so I reverted to 1400 and things worked fine again.
mozzle |
9th February 2010, 22:58 | #769 | Link | |
program --profile high --level 4.1 --preset slow --tune film --pass 2 --bitrate XXXX --stats ".stats" --thread-input --b-pyramid normal --slices 4 --vbv-bufsize 15000 --vbv-maxrate 15000 --aud --nal-hrd --threads 4 --output "output" "input" |
11th February 2010, 18:47 | #770 | Link | |
What x264 build did you use to fix the problem? Last edited by thedozer; 12th February 2010 at 11:16. |
12th February 2010, 21:03 | #771 | Link |
NY Frame of Mind
see post # 767 above. Also the dev server will now downgrade to 1400, just click on the "update" option to see it.
"Talk to me Goose" Last edited by rapscallion; 12th February 2010 at 22:24. Reason: changed not to now |
13th February 2010, 11:08 | #775 | Link |
I can confirm that:
Megui from development server produces videos that neither the DXVA decoder of MPC-HC nor FFDSHOW can decode properly. Megui from stable server produces videos that play perfectly on both. Most likely it's the newer x264 versions that are problematic. |
13th February 2010, 13:02 | #776 | Link | |
13th February 2010, 15:22 | #777 | Link |
So here's what I did for you:
Uninstalled Megui, and did a fresh install of 1056. Updated to the latest core and tools from stable server. Encoded a video (Unrestricted DXVA - Very High Quality, preset: slower) It plays beautifully. Updated the x264 (only) from the development server. (I have also tested to update the core and tools, the problem is exactly the same) Encoded the same video with the same settings. Upon playback MPC-HC DXVA crashes, MPC-HC with FFDSHOW decoding skips tons of frames. Both of the videos are included in the following rar: http://www.massmirror.com/a32d872045...6f8ac531b.html The one with the underscore "_" is the problematic. I'm using Windows 7 x64, a quad core, source file is a 291MB HFYU avi, script consists of opening the source with AviSource and converting to YV12 with ConvertToYV12. |
13th February 2010, 15:35 | #778 | Link |
x64 - so maybe vfw4x264.exe or x264_64.exe could be part of the problem. Please rename the file vfw4x264.exe and rename avs4x264.exe to vfw4x264.exe. Does the newly encoded file still crash? If yes, then rename x264_64.exe to something else and rename x264.exe to x264_64.exe. Does the new encode crash? Rename the original vfw4x264.exe back to vfw4x264.exe and try again. If it is still not working then delete/rename vfw4x264.exe and rename the original x264.exe back to x264.exe and try it again.
13th February 2010, 18:17 | #780 | Link |
I'm having the same results as "help_me!" in a Win7 32bit system with a Core2Duo processor
I also encoded different types of video files like: AVI(Xvid), MP4(H264) and MKV, and I always have the same result which is skipping frames mostly at the beginning of the videos. I only use FFDShow for decoding though. |
