20th March 2011, 14:44 | #6141 | Link | |
Yes. Of course fullscreen exclusive mode can only be used by one application at a time, per monitor. Haven't tried running two madVR instances on two monitors, both in exclusive mode. Might work or fail, don't know. Not that I'd be aware of. madVR itself does not contain any CPU specific assembler code because 99% of the hard work is done via pixel shaders, anyway. So writing assembler code wouldn't bring much benefit. The only real hard limit is that the GPU must be DX9 capable with a reasonable feature set and enough RAM. As far as I know, madVR works with all DX9 ATI, NVidia and Intel GPUs. With Intel, bilinear scaling must be used, though, otherwise playback is not smooth. |
20th March 2011, 15:03 | #6142 | Link | |
madVR reports: - creating Direct3D device failed (88760868) Now this is on Win 7 x86 SP1 and AMD HD5750 with Catalyst 11.2. I've had similar problems in other situations so don't take my case as a reference. |
20th March 2011, 15:18 | #6144 | Link |
Could you please disable the networking stuff by default? It is really annoying for people who don't use it and scary for those who don't understand it.
MPC-HC 2.2.1 |
20th March 2011, 15:33 | #6145 | Link | |
Just happened to activate the subtitle renderer for the first time while using madVR and came to a wrong conclusion... |
20th March 2011, 15:33 | #6146 | Link |
MPC-HC with no zoom. Video frame has Touch Windows from inside and Keep aspect ratio. The problem occur in my 16:10 monitor (the video is 16:9). I would guess that there should be no problem when aspect ratio matched, but I have not test that yet. I hope this helps. Thank you.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
20th March 2011, 16:10 | #6147 | Link | ||
20th March 2011, 16:23 | #6148 | Link |
This is weird, I could not utilize subtitle with MPC-HC's internal sub + madVR in the Haruhi clip (no subtitle @ all in any 3 states of "Position subtitle relatives to the video frame")
My setting: My stuff: MPC-HC 2990 x86, madVR .45, ffdshow 3779 x86, Win7 x64, geForce GTX260 My previous config is: MPC-HC + madVR + ffdshow + DirectvobSub. Thanks alot for your dedicating support on your FREE software ! |
20th March 2011, 16:28 | #6149 | Link | |
WinXP-Pro-SP3, madVR 0.45, ffdshow 3779, MPC-HC 1.5.2.2990, DirectX 9.0c Jun.2010 Code:
madVR reports: - creating Direct3D device failed (8876086c) Although I think Intel GMA 3100 has DX9 capability, it never works. My Intel GMA 3100's detail from driver report. However, I have another platform with ATI Radeon HD 6870, and didn't use madVR on Intel Q35. Last edited by goldie; 20th March 2011 at 16:31. |
20th March 2011, 17:36 | #6150 | Link | ||
Beyond the Corn Border
If I were you, I would: 1. mpc-hc.exe Properties, Compatibility tab, uncheck all. Click Change settings for all users, uncheck all. Task Scheduler, Task Scheduler Library, Actions - delete any with mpc-hc.exe. 2. test the legacy mpc-hc If that works, it must be a SSE/DEP problem: - find an old mpc-hc.exe MSVC2008 build - try to disable DEP on the latest build, put a copy of mpc-hc.exe and the nxtoggle script in a writable directory, launch the script. Test the resulting _mpc-hc.exe. 3. uncheck all external codecs, dxva internal codecs, use VMR (windowed) renderer and EVR (not custom) and last madVR - uninstall/use tool/manually regsvr32 -u any third-party directshow filters like ffdshow(it looks like it is inserting debug output even if it's disabled in the player, but I guess it's safe), Cyberlink (some versions memory leak on play if DXVA mode is selected with non-DXVA renderer like VMR9 on Vista+), DScaler Mpeg2 (known DEP incompatible), ArcSoft(issues with the licensing driver)...etc. 4. unlikely issue with directx: install Directx SDK. The redistributable included with it it's guaranteed to update files. In DirectX Utilities find DirectX Control Panel tool - on the Direct3D 9 tab of it, check Use Debug Version of... and put Debug Output Level slider to 3rd step. Launch DebugView. Launch mpc-hc. Save the log. Restore DirectX defaults. Post debugview log, dxdiag and dxdiag-x64 report. 5. give up, knowing I have at least tried... Get A screenshot software ASAP! Quote:
20th March 2011, 18:05 | #6153 | Link | |
It would also be cool if you could add some more details to common error messages like the "Direct3D device failed". Experience (with e.g. EVR CP) shows that there are plenty of people who don't understand the (origin of the) error, which complicates in solving it (by changing renderer or settings). Just brain-storming here. Maybe add something like: "The madVR video renderer failed. Possible reasons: - GPU is not DX9 compatible, - Insufficient GPU memory, - Graphics driver is not compatible. Please report if you need assistance." I assume that madVR are has some code to detect details about the graphics hardware such as brand and amount of memory? It would be cool if madVR could adjust its initial settings based on that info (if it doesn't already). For example setting Bilinear for Intel chips. What is the minimum required Shader Model? 2.0?
MPC-HC 2.2.1 |
20th March 2011, 18:11 | #6154 | Link |
@fairchild
Another cause of MPC not working can be virus-scanners and other security software. For example Kaspersky often has trouble with MPC. Does it also fail if you simply double-click on mpc-hc.exe, so not opening a file from explorer? Have you tried moving mpc-hc.exe to another location and renaming it?
MPC-HC 2.2.1 |
20th March 2011, 18:26 | #6155 | Link | |
@madshi
I was asked to report a bug: Quote:
20th March 2011, 19:14 | #6157 | Link |
@Rain1: You should choose madVR in MPC-HC output setting and not external filter. That actually prevent you from using external VSFilter as far as I know, but it may help in this case as well.
Yey
20th March 2011, 20:08 | #6158 | Link |
Seems like we have the same issues, I have both, on Win7 64bit SP1 with nvidia.
Home PC: Core i5-2400, 8GB RAM, nVidia GTX560Ti, Windows 7 64bit SP1. Work PC: Intel Xeon X3220 (Core 2 Q6600), 4GB RAM, Intel G45, Windows 7 64bit SP1. |
20th March 2011, 20:37 | #6160 | Link |
The one in my sig with 267.24 driver.
