20th April 2020, 23:12 | #8961 | Link |
Does m4v containers support HEVC? Can you play mkv or mp4?
Upon googling it I don't see anywhere that it says it supports HEVC. https://trac.ffmpeg.org/ticket/7685 tag for codec hevc in stream #0, codec not currently supported in container Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument Error initializing output stream 0:0 -- encoded 0 frames Conversion failed! Sent from my Pixel 3a using Tapatalk Last edited by jlw_4049; 20th April 2020 at 23:16. |
21st April 2020, 08:08 | #8962 | Link |
I am not sure if "m4v" here is just an MP4 container with a renamed extension ... or really a different container specification. I have seen this extension used for MPEG4-ASP elementary video (without container) as well.
If there is MPEG4 (or newer) video multiplexed with audio, it certainly needs a container. I would assume that Apple TV should use ISO Base Media MP4 v2 as container too, just with some specific atoms. The MP4 container supports HEVC video streams already (L-SMASH and MP4Box support their multiplexing); whether Apple TV supports them, is a different chapter. |
22nd April 2020, 06:13 | #8964 | Link |
qaac and fps slowdown
I've started to play around with qaac which I had never used. I chose these options:
and I ran it on an MP2 file, this is the log: My question is: did it go directly from MP2 to AAC or was there some intermediate encoding? (like MP2 to AC3 to AAC or something) |
22nd April 2020, 19:54 | #8966 | Link | |
Temet Nosce
In iTunes and other apple devices (iPhone, Apple TV etc.) they do not play at all. May be a limitation of the Apple devices regarding the container format. I do not know...
http://volutabro.blogspot.com |
22nd April 2020, 19:57 | #8967 | Link | |
Temet Nosce
22nd April 2020, 20:34 | #8968 | Link |
Life's clearer in 4K UHD
Out of interest... Did Apple's documentation mention anything about supported 'Profiles'?
23rd April 2020, 04:06 | #8969 | Link |
Temet Nosce
Nothing specific about that unfortunately.
29th April 2020, 13:50 | #8970 | Link |
Hello. I am trying to figure out how to Downgrade the x264 codec in MeGUI.
Since I save backups during updates, I still have the previous x264 "obsolete" zip file. I would assume I simply extract the x264.exe file I want and overwrite the newer one in the "MeGui\tools\x264" folder, but after doing so, and checking the current version by running Update in MeGUI, it still shows the newer version. So I assume there is a better way to do this, or some Settings file that also needs to be changed as well. [For anyone wondering WHY I want to downgrade, the reason is because my older Samsung TV will not play any of my recent encodes (via USB) after upgrading to x264 r2969. So I want to revert back to x264 r2935 which is the last version I used that works fine.] UPDATE: So while I was waiting for a response, I tried changing my update settings from the STABLE server to the DEVELOPER server, which gave me a newer version of the codec (x264 r2991). I encoded a few second long video just to test it, and it seems like the r2991 fixes the problem. So something is clearly wrong with the x264 r2969 codec. However, I usually prefer to stay with the STABLE updates, so I would still like an answer to my question regarding how to downgrade my x264 codec to a previous version. Thanks. Last edited by slick1109; 30th April 2020 at 02:43. |
29th April 2020, 18:55 | #8971 | Link |
JFYI: It's a Samsung bug. x264 developers accommodated for such buggy players in the newest versions.
https://code.videolan.org/videolan/x...f341027b57f6f8 https://code.videolan.org/videolan/x...f03a302da0ca1c |
30th April 2020, 03:26 | #8972 | Link | |
Hopefully someone else on here will still help me figure out how to downgrade my codec since I prefer to stay with the stable releases for now. |
30th April 2020, 10:14 | #8975 | Link | |
30th April 2020, 11:16 | #8976 | Link | |
Perhaps not. Maybe it is only "cosmetic" in the sense that I will see it shown incorrectly in the Update screen, but it wont actually cause any issues. Thats why I asked the question because I wanted to know for sure, or if there was a proper way to do it. |
1st May 2020, 04:48 | #8979 | Link |
I think the only tool you can't "simply" replace with a different version is Avisynth+ and it's plugins, because MeGUI copies them to various sub-folders. To update Avisynth+ (if MeGUI is using it's portable version) you need to close MeGUI and replace the files in the "MeGUI\tools\avs" and "MeGUI\tools\avs\plugins" folders with the newer/desired versions, then when MeGUI starts it'll copy those files to it's various directories, oblivious to the fact they've changed. If you don't replace the files in those folders, MeGUI will replace Avisynth.dll etc in it's main directory and any copies in sub-folders with the older files again each time it starts.
3rd May 2020, 06:11 | #8980 | Link |
For some reason, whenever I make changes to a preset in the One Click encoder profile, it doesn't effectively update itself until after I close down and restart the application. Clicking the update button isn't enough to make the change.
megui |
