Old 22nd March 2020, 13:22   #58901  |  Link
mclingo
[QUOTE=mrmojo666;i'm thinking to buy a 5600xt.
thank you mate[/QUOTE]
Hi, is there a reason you are remaining with AMD, is it 3D support as you might be better served with a NV 2060
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions
Old 22nd March 2020, 16:30   #58902  |  Link
mrmojo666
Hey mclingo, i don't have any 3d display, neither content. Also historically I'm an happy amd user and feel that 5600xt can be another good bargain.
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
mrmojo666 is offline   Reply With Quote
Old 22nd March 2020, 16:50   #58903  |  Link
Piyoko
Is there any way to take raw screenshots of HDR video streams with madVR/MPC-HC? I can't seem to find a setting that allows this, even if I passthrough HDR during playback and disable processing for screenshots, tonemapping to SDR is still always applied.
Piyoko is offline   Reply With Quote
Old 23rd March 2020, 00:56   #58904  |  Link
mclingo
Hi, been having some issues for a while now with some 2160p HDR content where I get glitching on pan shots, oddly always in the same place in the movie suggesting some sort of issue with the rip. This happens on a few of my 4k HDR ripped movies but also in some 4k HDR TV episodes. Its not so bad Its unwatchable, I see this maybe 2-3 times in a movie and maybe once or twice in a long TV episode but everything remains at zero in MADVR, no frame skips or glitches. It seems to be an issue with 2160p23 on my particular TV, if I use smooth motion in MADVR this completely resolves it but i'm not sure I can live with the albeit small amount of ghosting. its odd though it always at the same place in these videos but if there was an issue with the rip surely smooth motion would not fix that.
Anyone have any ideas whats causing this, any suggestions as to something else I might try, 1080p is totally fine, no issues at all.
Old 23rd March 2020, 12:21   #58905  |  Link
GoodGravyMan
I thought I read there was an issue with smooth motion and the 113 beta.
GoodGravyMan is offline   Reply With Quote
Old 23rd March 2020, 12:49   #58906  |  Link
mclingo
i'll definately have a look at that but i think i've had this issue longer than that, cheers.
Old 23rd March 2020, 18:01   #58907  |  Link
Asmodian
That issue is smooth motion crashing with the beta, it is not something subtle.
madVR options explained
Old 23rd March 2020, 21:49   #58908  |  Link
mclingo
ah yes, I remember that now, cheers I wont bother reinstalling, i'm going to see if I can live with SMOOTH MOTION again, last time I lasted a day
Old 26th March 2020, 05:05   #58909  |  Link
tyguy
tyguy's Avatar
Was gsync added to madvr? I had gsync notification on and forgot to turn it off. Loaded up a movie and it was displaying gsync on. I opened up my stats and no longer have the “1 frame repeat every x minutes.”
tyguy is offline   Reply With Quote
Old 26th March 2020, 10:21   #58910  |  Link
chros
chros's Avatar
The future of madvr is not that promising at this point link, link
The only good thing about it is that we don't have to buy new GPUs
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 26th March 2020, 11:02   #58911  |  Link
Sunset1982
guys I got a question regarding 120 Hz output.
will it be possible (with an HDMI 2.1 GPU) to setup madvr to output 23,976 movies at 120 Hz? (without smooth motion or any interpolation)
I am asking, because the new LG Oleds support 120Hz BFI and I ask myself if we could benefit from the BFI with 23,976 movies played througt madvr. Or does LGs Real Cinema option do that?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 26th March 2020, 11:05   #58912  |  Link
no you need 119p support.
on the other hand just use smooth and BFI. BFI will pretty much create the same ghosting anyway.
Old 26th March 2020, 18:59   #58913  |  Link
VBB
VBB's Avatar
What Huhn said. That is my plan, should I ever replace my C7: set desktop to 120Hz, enable smooth motion, and use BFI on top of that, if it doesn't dim the screen too much.
@Sunset1982 - BFI and Real Cinema are completely different animals. The former inserts black frames to reduce the perception of stutter, the latter ensures proper cadence. But to answer your question, yes, you will benefit from BFI when using madVR.
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 26th March 2020, 19:42   #58914  |  Link
mclingo
thing is though mate, even in its current now quite old state MADVR is miles ahead of any other renderer, even if we languished on this verion for a nother 5 years I doubt there would be anything that would do a better job.
I'm going to remain positive about this, MADSHI is clearly a decent guy, even if we dont get all or any of the features envy does it will still exist in some form I believe and still be better than any other alternative.
Old 26th March 2020, 20:39   #58915  |  Link
VBB
VBB's Avatar
It would be a shame, though, if Mathias stopped updating/developing the software version. From a financial standpoint, like someone said on AVS, it would probably make a lot more sense to commercialize a software rather than a hardware product. Reasonably priced, I think a lot of us would want to support madVR and its further development.
Old 26th March 2020, 23:41   #58916  |  Link
ryrynz
ryrynz's Avatar
It was entirely his plan last year to release a stable build but he just keeps on tweaking.. He has his phases and release phase is when it's done lol.
Old 27th March 2020, 01:04   #58917  |  Link
glc650
Sounds like what I've experienced. Best examples: It Chapter 2 from 1:04:00 to 1:04:05 - objects on the building pulsate/are extra blurry during panning (plus the top landing of the fire escape pulsates). And 1917 from 00:42:35 to 00:42:50 - very blurry/shaky around the wood planks during panning. I'm running 92.17 on Windows 10 with a Geforce 1060.
glc650 is offline   Reply With Quote
Old 27th March 2020, 03:52   #58918  |  Link
ryrynz
ryrynz's Avatar
Try the latest 113 beta build and make sure you don't have smooth motion or or it'll crash, it should mostly resolve those issues provided there are no issues with your televisions processing or the rip itself.
Old 27th March 2020, 20:43   #58919  |  Link
SirMaster
I think we will most certainly at least get a finalized stable HDR dynamic tone-mapping build when hes done tweaking that.
Beyond that I am optimistic he will add some things, even if maybe he charges a bit for a commercial software version.
SirMaster is offline   Reply With Quote
Old 27th March 2020, 21:21   #58920  |  Link
angmav
Hi sorry if this is the wrong section to ask but I am currently have high render times as well as
dropping frames Running win 10 1909 and nvidia ver 442.74 with a 1080ti running latest madvr version
Any guidance would be greatly appreciated sorry if this is being asked in the wrong forum
Sent from my iPhone using Tapatalk
angmav is offline   Reply With Quote
