22nd June 2010, 16:27 | #8621 | Link | |
I also wanted to comment that I have had no issues at all what so ever with this program so far(knocks on wood), and I have done movie only back ups, full back ups, and have done BD5's, ALL turned out fantastic! Last edited by thegame; 22nd June 2010 at 17:40. |
22nd June 2010, 19:49 | #8622 | Link | |
So, I am guessing movie-only backup will not preserve menus, right? What about a Full backup with custom size like 50GB - would this re-encode video? Also, last night I tried the "other movie only output" and chose "mkv container, 1920x1080,AC3 Audio" but it errored out without much detail: [22:04:48]PHASE TWO - Rebuild Started - [22:04:48] Rebuilding stream 00020 [1 of 11] - [22:04:48] Rebuilding stream 00021 [2 of 11] - [22:04:48] Rebuilding stream 00022 [3 of 11] - [22:04:48] Rebuilding stream 00023 [4 of 11] - [22:04:48] Rebuilding stream 00024 [5 of 11] - [22:04:48] Rebuilding stream 00025 [6 of 11] - [22:04:48] Rebuilding stream 00026 [7 of 11] - [22:04:48] Rebuilding stream 00027 [8 of 11] - [22:04:48] Rebuilding stream 00028 [9 of 11] - [22:04:48] Rebuilding stream 00029 [10 of 11] - [22:04:48] Rebuilding stream 00030 [11 of 11] - [22:04:48] Building ALTERNATE OUTPUT Structure - ERROR in attempt to mux (MKVMERGE) [22:37:47] - Failed to REBUILD Any idea what happened? Also, would it be possible continue the process without re-doing it from scratch? Thanks for any help and suggestions!! |
22nd June 2010, 23:26 | #8623 | Link |
Will there also be an option to remove secondary video when secondary audio is dts express? or is there a possible way to reencode dts express (because it cannot be demuxed) and put it back? i heard eac3to can do that
23rd June 2010, 00:04 | #8624 | Link |
FYI: I did a Mary and Max Movie only encode that completed normally but the audio was around 10 seconds fast. I remuxed it with another program and finally got it back in sync. It seems when the movie starts a clip plays with a film projector noise playing but for some reason BD_Rebuilder skips this audio and plays the audio for the rest of the film causing it to go out of sync. This has happened only once in a while for movie only encodes and usually it has a very small .m2ts that I can skip but this time it didn't work with it missing. Also did a Wyatt Earp backup that was extremely long (3:10 minutes), this movie had a 640K Dolby Digital 5.1 audio track that I kept and when it finished it came out at 224K instead of the usual 640k. I did not configure it any differently than the encodes I completed earlier that used 640k as the final output. I was just wondering if BD_Rebuilder changed it to save space for the video or if it's a bug?
23rd June 2010, 15:23 | #8625 | Link |
I have had my first problem with BD-RB in quite some time.
The Blu-ray, an older release, is Stargate Extended Cut. The full backup to BD5 completes successfully, but on play back on my Sony S360 and PowerDVD none of the button highlights work, so there is no way to select/change menu buttons. The Blu-ray starts with a brief Lions Gate advert that becomes a 10 second count down to either play the movie or go to the main menu. But on the backup, there is no way to make a selection so the movie just starts. With the original, the choice is available. After the conclusion of the movie, the main menu is displayed but again there is no button highlights to change or select, thus no more can be done but select stop. |
23rd June 2010, 15:32 | #8626 | Link |
To la large to fit BD9
Hi Jdobbs, I tried about 4 times to back up Green Zone. 3 times as Movie only to a BD9 size 7.7gb. every time it comes
out to 22.gb and imgburn gives me an error, it said the source is to large to fit BD9. All three time it gives me this error: Also as you could see from my graphics on the bottom, it has these two compress files with number, I didn't open them, afraid it could be a self extracting virus..well I don't know what when wrong with this Movie with the latest ver/BD_Rebuilder I also had a similar problem with THE BOOK OF ELI. "Oh on the four time i did was full movie with similar out come,in imgburn. source to large to fit on BD25. I am going to try another movie I already backup to BD5 and try it to BD9. I'll post result to see if is only these two movies have some sort problem: ----------------------- [00:26:10] BD Rebuilder v0.34.02 (beta) - Source: GREEN_ZONE - Input BD size: 32.61 GB - Approximate total content: [01:54:46.421] - Target BD size: 7.72 GB - Windows Version: 6.0 [6002] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [00:26:10] PHASE ONE, Encoding - [00:26:10] Extracting A/V streams [VID_00010] - [00:31:19] Reencoding: VID_00010 (1 of 1) - [00:31:19] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 165,109 frames - Bitrate: 8,163 Kbs - [00:31:19] Reencoding: VID_00010, Pass 1 of 2 - [02:07:45] Reencoding: VID_00010, Pass 2 of 2 - [03:56:32] Video Encode complete - [03:56:32] Reencoding audio tracks (if req'd) - [04:00:41] Multiplexing M2TS [04:22:50]PHASE ONE complete [04:22:50]PHASE TWO - Rebuild Started - [04:22:50] Rebuilding AVCHD file Structure [04:47:40] - Encode and Rebuild complete [04:47:40] BURNING BD structure to disc - ImgBurn completed successfully [05:35:53]JOB: GREEN_ZONE finishedhttp://forum.doom9.org/attachment.php?attachmentid=11201&stc=1&d=1277303901 Last edited by raul124; 23rd June 2010 at 15:40. |
23rd June 2010, 15:50 | #8627 | Link | |
And this advice solved my problem: click |
23rd June 2010, 16:26 | #8628 | Link |
The last two titles I have done have severe problems with their respective sounds and subtitles.
Both titles were done one after another in batch mode with the same basic setup concerning languages and subtitle streams. Apocalypto, full backup, 25gb, TRYING to keep the 640 DD sound stream and director's comment. The main movie does NOT play the normal (Mayan) sound stream - it is muted; DC works. BUT when using the m2ts in tsmuxer i can demux a 640kb sound stream which even after demuxing to ac3 cannot be played - it seems blank but it's 664.107.520 in size (the identical size as the 4353 stream - cf. below). Strange thing is: the track is named: xx.4352.ac3 while tsmuxer states the 4353 to tb the DD 640 stream whereas 4352 should be the first soundstream, a 1500 LPCM. So even if I may have by mistake clicked the first audio track (4352 LPCM) which I cannot remember but thus cannot rule out: why was an AC3 created with seemingly correct file size which does not play? I demuxed the original AC3 and muxed it back into the rebuilder m2ts and had sound afterwards. Here are the log files: Code:
[Status] LABEL=APOCALYPTO VERSION=v0.34.02 (beta) SOURCE_SIZE=39587413181 SOURCE_VIDEO_SIZE=39355932672 TARGET_SIZE=24326963200 REDUCTION=.612245246271164 RESIZE_1080=0 AUDIO_TO_KEEP=deu;eng;fra;fre; SUBS_TO_KEEP=deu;eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=2 REBUILD_COMPLETE=1 [00025] AUDIO=1 PGS=1 M2TS_TARGET=2924400214 NSIZE=2770624512 FLINK=0 MLINK=0 [00001] AUDIO=101 PGS=1 M2TS_TARGET=21324858179 RATE=18177 NSIZE=19918602240 FLINK=0 MLINK=0 Code:
----------------------- [15:40:44] BD Rebuilder v0.34.02 (beta) - Source: APOCALYPTO - Input BD size: 36,87 GB - Approximate total content: [02:43:35.313] - Target BD size: 22,66 GB - Windows Version: 5.1 [2600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [15:40:44] PHASE ONE, Encoding - [15:40:44] Extracting A/V streams [VID_00025] - [15:49:11] Reencoding: VID_00025 (1 of 2) - [15:49:11] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 29,970fps, 45.374 frames - [15:49:11] Reencoding: VID_00025, Pass 1 of 1 - [16:18:56] Video Encode complete - [16:18:56] Reencoding audio tracks (if req'd) - [16:18:56] Multiplexing M2TS - [16:20:52] Extracting A/V streams [VID_00001] - [16:32:59] Reencoding: VID_00001 (2 of 2) - [16:32:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 199.033 frames - Bitrate: 18.177 Kbs - [16:32:59] Reencoding: VID_00001, Pass 1 of 1 - [00:15:07] Video Encode complete - [00:15:07] Reencoding audio tracks (if req'd) - [00:15:56] Multiplexing M2TS [00:29:51]PHASE ONE complete [00:29:51]PHASE TWO - Rebuild Started - [00:29:51] Rebuilding BD file Structure [00:30:08] - Encode and Rebuild complete - WORKFILES folder removed. [00:30:08]JOB: APOCALYPTO finished. ----------------------- [00:30:08] PROCESSING BATCH FILE [74] ++++++++++++ Problem #2 is Red Heat - again full backup to 25gb. This time main movie has all desired sound streams BUT the extras do NOT have any sound at all and only one subtitle stream SPANISH which I have never selected. This time I have no chance of muxing sound to the extra material because the size won't fit at all and I will do the title again - only question is: what has led to the problems and how may I overcome them. Code:
----------------------- [00:30:10] BD Rebuilder v0.34.02 (beta) - Source: RED_HEAT - Input BD size: 33,84 GB - Approximate total content: [02:20:40.763] - Target BD size: 22,66 GB - Windows Version: 5.1 [2600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [00:30:10] PHASE ONE, Encoding - [00:30:10] Extracting A/V streams [VID_00212] - [00:30:13] Reencoding: VID_00212 (1 of 9) - [00:30:13] Collecting video information - Source Video: MPEG-2, 720x480 - Rate/Length: 29,970fps, 3.926 frames - [00:30:13] Reencoding: VID_00212, Pass 1 of 1 - [00:30:28] Video Encode complete - [00:30:28] Reencoding audio tracks (if req'd) - [00:30:28] Multiplexing M2TS - [00:30:29] Extracting A/V streams [VID_00004] - [00:30:32] Reencoding: VID_00004 (2 of 9) - [00:30:32] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.896 frames - [00:30:32] Reencoding: VID_00004, Pass 1 of 1 - [00:31:30] Video Encode complete - [00:31:30] Reencoding audio tracks (if req'd) - [00:31:30] Multiplexing M2TS - [00:31:32] Extracting A/V streams [VID_00008] - [00:31:35] Reencoding: VID_00008 (3 of 9) - [00:31:35] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.232 frames - [00:31:35] Reencoding: VID_00008, Pass 1 of 1 - [00:33:01] Video Encode complete - [00:33:01] Reencoding audio tracks (if req'd) - [00:33:01] Multiplexing M2TS - [00:33:04] Extracting A/V streams [VID_00005] - [00:33:07] Reencoding: VID_00005 (4 of 9) - [00:33:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.304 frames - [00:33:07] Reencoding: VID_00005, Pass 1 of 1 - [00:34:25] Video Encode complete - [00:34:25] Reencoding audio tracks (if req'd) - [00:34:25] Multiplexing M2TS - [00:34:27] Extracting A/V streams [VID_00007] - [00:34:32] Reencoding: VID_00007 (5 of 9) - [00:34:32] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.048 frames - [00:34:32] Reencoding: VID_00007, Pass 1 of 1 - [00:36:29] Video Encode complete - [00:36:29] Reencoding audio tracks (if req'd) - [00:36:29] Multiplexing M2TS - [00:36:33] Extracting A/V streams [VID_00006] - [00:36:41] Reencoding: VID_00006 (6 of 9) - [00:36:41] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 3.065 frames - [00:36:41] Reencoding: VID_00006, Pass 1 of 1 - [00:37:58] Video Encode complete - [00:37:58] Reencoding audio tracks (if req'd) - [00:37:58] Multiplexing M2TS - [00:38:04] Extracting A/V streams [VID_00209] - [00:38:36] Reencoding: VID_00209 (7 of 9) - [00:38:36] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 17.910 frames - [00:38:36] Reencoding: VID_00209, Pass 1 of 1 - [00:51:39] Video Encode complete - [00:51:39] Reencoding audio tracks (if req'd) - [00:51:39] Multiplexing M2TS - [00:52:00] Extracting A/V streams [VID_00211] - [00:52:41] Reencoding: VID_00211 (8 of 9) - [00:52:41] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29,970fps, 28.140 frames - [00:52:41] Reencoding: VID_00211, Pass 1 of 1 - [01:14:00] Video Encode complete - [01:14:00] Reencoding audio tracks (if req'd) - [01:14:00] Multiplexing M2TS - [01:14:52] Extracting A/V streams [VID_00000] - [01:23:23] Reencoding: VID_00000 (9 of 9) - [01:23:23] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 24,000fps, 150.000 frames - Bitrate: 16.974 Kbs - [01:23:23] Reencoding: VID_00000, Pass 1 of 1 - [07:45:27] Video Encode complete - [07:45:27] Reencoding audio tracks (if req'd) - [07:45:27] Multiplexing M2TS [08:17:34]PHASE ONE complete [08:17:34]PHASE TWO - Rebuild Started - [08:17:34] Rebuilding BD file Structure [08:18:04] - Encode and Rebuild complete - WORKFILES folder removed. [08:18:04]JOB: RED_HEAT finished. ----------------------- [08:18:04] PROCESSING BATCH FILE [75] Code:
[Status] LABEL=RED_HEAT VERSION=v0.34.02 (beta) SOURCE_SIZE=36338321400 SOURCE_VIDEO_SIZE=35420866560 TARGET_SIZE=24326963200 REDUCTION=.660895981196458 RESIZE_1080=0 AUDIO_TO_KEEP=deu;eng;fra;fre; SUBS_TO_KEEP=deu;eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=9 REBUILD_COMPLETE=1 [00212] AUDIO=0 PGS= M2TS_TARGET=83594438 NSIZE=33515520 FLINK=0 MLINK=0 [00004] AUDIO=1 PGS= M2TS_TARGET=98728089 NSIZE=91305984 FLINK=0 MLINK=0 [00008] AUDIO=0 PGS= M2TS_TARGET=116521397 NSIZE=96841728 FLINK=0 MLINK=0 [00005] AUDIO=1 PGS= M2TS_TARGET=119956618 NSIZE=87914496 FLINK=0 MLINK=0 [00007] AUDIO=1 PGS= M2TS_TARGET=158933788 NSIZE=223070208 FLINK=0 MLINK=0 [00006] AUDIO=0 PGS= M2TS_TARGET=228787342 NSIZE=236212224 FLINK=0 MLINK=0 [00209] AUDIO=0 PGS=0000100 M2TS_TARGET=1172137196 NSIZE=712255488 FLINK=0 MLINK=0 [00211] AUDIO=0 PGS=00000001 M2TS_TARGET=1838488858 NSIZE=1310140416 FLINK=0 MLINK=0 [00000] AUDIO=1111111 PGS=0010000100100 M2TS_TARGET=20618252296 RATE=16974 NSIZE=19878893568 FLINK=0 MLINK=0 |
23rd June 2010, 18:49 | #8629 | Link |
Third title from this batch run turned out to have errors as well:
Title is: "This is Spinal Tap", full backup 25gb Problems are these: Of the 9 subtitle streams for the main movie 3 are totally wrong. 1/9 Dan is French 3/9 Deu is French 5/9 Fin is French ... all others seem correct. The rebuilder m2ts loaded into tsmuxer states 4 pgs streams: 0 - track=4608, lang=fra 1 - track=4609, lang=nor 2 -track=4610, lang=swe 3 -track=4611, lang=deu The original m2ts according to tsmuxer has different tracks for those languages: track=4609, lang=fra track=4610, lang=deu track=4611, lang=nor track=4613, lang=swe What makes BD RB get off track here? Problem # 2 is: ONE out roughly a dozen extras/streams does NOT have any audio although the original m2ts has the same soundformat than the stream before or after it and all the other were encoded correctly. Here are the logs: Code:
========================== [15:40:43] BD Rebuilder v0.34.02 (beta) [15:40:43] BEGIN - BATCH SEQUENCE ========================== ----------------------- [15:40:43] PROCESSING BATCH FILE [73] ----------------------- [08:18:06] BD Rebuilder v0.34.02 (beta) - Source: SPINAL_TAP - Input BD size: 39,45 GB - Approximate total content: [05:22:38.111] - Target BD size: 22,66 GB - Windows Version: 5.1 [2600] - One Pass ABR Mode enabled - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [08:18:06] PHASE ONE, Encoding - [08:18:06] Extracting A/V streams [VID_00064] - [08:18:07] Reencoding: VID_00064 (1 of 28) - [08:18:07] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 659 frames - Bitrate: 500 Kbs - [08:18:07] Reencoding: VID_00064, Pass 1 of 1 - [08:18:19] Video Encode complete - [08:18:19] Reencoding audio tracks (if req'd) - [08:18:19] Multiplexing M2TS - [08:18:20] Extracting A/V streams [VID_00065] - [08:18:20] Reencoding: VID_00065 (2 of 28) - [08:18:20] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 659 frames - [08:18:20] Reencoding: VID_00065, Pass 1 of 1 - [08:18:23] Video Encode complete - [08:18:23] Reencoding audio tracks (if req'd) - [08:18:23] Multiplexing M2TS - [08:18:24] Extracting A/V streams [VID_00027] - [08:18:26] Reencoding: VID_00027 (3 of 28) - [08:18:26] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 807 frames - Bitrate: 6.196 Kbs - [08:18:26] Reencoding: VID_00027, Pass 1 of 1 - [08:18:57] Video Encode complete - [08:18:57] Reencoding audio tracks (if req'd) - [08:18:57] Multiplexing M2TS - [08:18:58] Extracting A/V streams [VID_00029] - [08:19:00] Reencoding: VID_00029 (4 of 28) - [08:19:00] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 802 frames - Bitrate: 6.361 Kbs - [08:19:00] Reencoding: VID_00029, Pass 1 of 1 - [08:19:27] Video Encode complete - [08:19:27] Reencoding audio tracks (if req'd) - [08:19:27] Multiplexing M2TS - [08:19:28] Extracting A/V streams [VID_00028] - [08:19:31] Reencoding: VID_00028 (5 of 28) - [08:19:31] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 803 frames - Bitrate: 6.160 Kbs - [08:19:31] Reencoding: VID_00028, Pass 1 of 1 - [08:19:59] Video Encode complete - [08:19:59] Reencoding audio tracks (if req'd) - [08:20:01] Multiplexing M2TS - [08:20:02] Extracting A/V streams [VID_00008] - [08:20:07] Reencoding: VID_00008 (6 of 28) - [08:20:07] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 2.734 frames - Bitrate: 4.866 Kbs - [08:20:07] Reencoding: VID_00008, Pass 1 of 1 - [08:21:39] Video Encode complete - [08:21:39] Reencoding audio tracks (if req'd) - [08:21:40] Multiplexing M2TS - [08:21:42] Extracting A/V streams [VID_00010] - [08:21:45] Reencoding: VID_00010 (7 of 28) - [08:21:45] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 2.435 frames - Bitrate: 5.986 Kbs - [08:21:45] Reencoding: VID_00010, Pass 1 of 1 - [08:23:07] Video Encode complete - [08:23:07] Reencoding audio tracks (if req'd) - [08:23:09] Multiplexing M2TS - [08:23:11] Extracting A/V streams [VID_00004] - [08:23:14] Reencoding: VID_00004 (8 of 28) - [08:23:14] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 2.755 frames - Bitrate: 5.698 Kbs - [08:23:14] Reencoding: VID_00004, Pass 1 of 1 - [08:24:49] Video Encode complete - [08:24:49] Reencoding audio tracks (if req'd) - [08:24:50] Multiplexing M2TS - [08:24:52] Extracting A/V streams [VID_00025] - [08:24:59] Reencoding: VID_00025 (9 of 28) - [08:24:59] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 3.030 frames - Bitrate: 6.348 Kbs - [08:24:59] Reencoding: VID_00025, Pass 1 of 1 - [08:26:57] Video Encode complete - [08:26:57] Reencoding audio tracks (if req'd) - [08:26:58] Multiplexing M2TS - [08:27:01] Extracting A/V streams [VID_00009] - [08:27:06] Reencoding: VID_00009 (10 of 28) - [08:27:06] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 3.460 frames - Bitrate: 6.296 Kbs - [08:27:07] Reencoding: VID_00009, Pass 1 of 1 - [08:29:11] Video Encode complete - [08:29:11] Reencoding audio tracks (if req'd) - [08:29:13] Multiplexing M2TS - [08:29:16] Extracting A/V streams [VID_00001] - [08:29:21] Reencoding: VID_00001 (11 of 28) - [08:29:21] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 3.768 frames - Bitrate: 6.302 Kbs - [08:29:21] Reencoding: VID_00001, Pass 1 of 1 - [08:31:44] Video Encode complete - [08:31:44] Reencoding audio tracks (if req'd) - [08:31:45] Multiplexing M2TS - [08:31:49] Extracting A/V streams [VID_00024] - [08:31:54] Reencoding: VID_00024 (12 of 28) - [08:31:54] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 4.378 frames - Bitrate: 5.697 Kbs - [08:31:55] Reencoding: VID_00024, Pass 1 of 1 - [08:34:20] Video Encode complete - [08:34:20] Reencoding audio tracks (if req'd) - [08:34:22] Multiplexing M2TS - [08:34:25] Extracting A/V streams [VID_00012] - [08:34:31] Reencoding: VID_00012 (13 of 28) - [08:34:31] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 4.146 frames - Bitrate: 6.306 Kbs - [08:34:31] Reencoding: VID_00012, Pass 1 of 1 - [08:37:10] Video Encode complete - [08:37:10] Reencoding audio tracks (if req'd) - [08:37:12] Multiplexing M2TS - [08:37:15] Extracting A/V streams [VID_00006] - [08:37:21] Reencoding: VID_00006 (14 of 28) - [08:37:21] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 4.155 frames - Bitrate: 6.299 Kbs - [08:37:21] Reencoding: VID_00006, Pass 1 of 1 - [08:39:56] Video Encode complete - [08:39:56] Reencoding audio tracks (if req'd) - [08:39:58] Multiplexing M2TS - [08:40:02] Extracting A/V streams [VID_00007] - [08:40:08] Reencoding: VID_00007 (15 of 28) - [08:40:08] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 4.568 frames - Bitrate: 6.220 Kbs - [08:40:08] Reencoding: VID_00007, Pass 1 of 1 - [08:42:39] Video Encode complete - [08:42:39] Reencoding audio tracks (if req'd) - [08:42:41] Multiplexing M2TS - [08:42:44] Extracting A/V streams [VID_00011] - [08:42:51] Reencoding: VID_00011 (16 of 28) - [08:42:51] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 4.845 frames - Bitrate: 6.312 Kbs - [08:42:51] Reencoding: VID_00011, Pass 1 of 1 - [08:45:43] Video Encode complete - [08:45:43] Reencoding audio tracks (if req'd) - [08:45:45] Multiplexing M2TS - [08:45:49] Extracting A/V streams [VID_00005] - [08:45:55] Reencoding: VID_00005 (17 of 28) - [08:45:55] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 5.149 frames - Bitrate: 6.311 Kbs - [08:45:55] Reencoding: VID_00005, Pass 1 of 1 - [08:49:17] Video Encode complete - [08:49:17] Reencoding audio tracks (if req'd) - [08:49:19] Multiplexing M2TS - [08:49:23] Extracting A/V streams [VID_00016] - [08:49:31] Reencoding: VID_00016 (18 of 28) - [08:49:31] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 5.589 frames - Bitrate: 6.313 Kbs - [08:49:31] Reencoding: VID_00016, Pass 1 of 1 - [08:53:07] Video Encode complete - [08:53:07] Reencoding audio tracks (if req'd) - [08:53:09] Multiplexing M2TS - [08:53:13] Extracting A/V streams [VID_00014] - [08:53:21] Reencoding: VID_00014 (19 of 28) - [08:53:21] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 6.535 frames - Bitrate: 5.485 Kbs - [08:53:21] Reencoding: VID_00014, Pass 1 of 1 - [08:56:41] Video Encode complete - [08:56:41] Reencoding audio tracks (if req'd) - [08:56:44] Multiplexing M2TS - [08:56:48] Extracting A/V streams [VID_00002] - [08:56:55] Reencoding: VID_00002 (20 of 28) - [08:56:55] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 5.741 frames - Bitrate: 6.317 Kbs - [08:56:55] Reencoding: VID_00002, Pass 1 of 1 - [09:03:39] Video Encode complete - [09:03:39] Reencoding audio tracks (if req'd) - [09:03:41] Multiplexing M2TS - [09:03:45] Extracting A/V streams [VID_00003] - [09:03:53] Reencoding: VID_00003 (21 of 28) - [09:03:53] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 6.842 frames - Bitrate: 5.736 Kbs - [09:03:53] Reencoding: VID_00003, Pass 1 of 1 - [09:07:48] Video Encode complete - [09:07:48] Reencoding audio tracks (if req'd) - [09:07:50] Multiplexing M2TS - [09:07:55] Extracting A/V streams [VID_00022] - [09:08:02] Reencoding: VID_00022 (22 of 28) - [09:08:02] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 13.538 frames - Bitrate: 2.918 Kbs - [09:08:02] Reencoding: VID_00022, Pass 1 of 1 - [09:11:48] Video Encode complete - [09:11:48] Reencoding audio tracks (if req'd) - [09:11:51] Multiplexing M2TS - [09:11:56] Extracting A/V streams [VID_00013] - [09:12:07] Reencoding: VID_00013 (23 of 28) - [09:12:07] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 8.503 frames - Bitrate: 6.327 Kbs - [09:12:07] Reencoding: VID_00013, Pass 1 of 1 - [09:17:15] Video Encode complete - [09:17:15] Reencoding audio tracks (if req'd) - [09:17:17] Multiplexing M2TS - [09:17:23] Extracting A/V streams [VID_00015] - [09:17:36] Reencoding: VID_00015 (24 of 28) - [09:17:36] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 10.407 frames - Bitrate: 6.330 Kbs - [09:17:36] Reencoding: VID_00015, Pass 1 of 1 - [09:24:03] Video Encode complete - [09:24:03] Reencoding audio tracks (if req'd) - [09:24:06] Multiplexing M2TS - [09:24:14] Extracting A/V streams [VID_00030] - [09:25:35] Reencoding: VID_00030 (25 of 28) - [09:25:35] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 64.589 frames - [09:25:35] Reencoding: VID_00030, Pass 1 of 1 - [09:41:06] Video Encode complete - [09:41:06] Reencoding audio tracks (if req'd) - [09:41:19] Multiplexing M2TS - [09:41:37] Extracting A/V streams [VID_00023] - [09:43:13] Reencoding: VID_00023 (26 of 28) - [09:43:13] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 86.598 frames - Bitrate: 6.832 Kbs - [09:43:13] Reencoding: VID_00023, Pass 1 of 1 - [10:44:39] Video Encode complete - [10:44:39] Reencoding audio tracks (if req'd) - [10:44:58] Multiplexing M2TS - [10:46:49] Extracting A/V streams [VID_00017] - [10:48:31] Reencoding: VID_00017 (27 of 28) - [10:48:31] Collecting video information - Source Video: MPEG-4 (AVC), 720x576 - Rate/Length: 25,000fps, 101.802 frames - Bitrate: 6.472 Kbs - [10:48:31] Reencoding: VID_00017, Pass 1 of 1 - [12:01:45] Video Encode complete - [12:01:45] Reencoding audio tracks (if req'd) - [12:02:06] Multiplexing M2TS - [12:04:41] Extracting A/V streams [VID_00000] - [12:10:59] Reencoding: VID_00000 (28 of 28) - [12:10:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 119.550 frames - Bitrate: 17.534 Kbs - [12:10:59] Reencoding: VID_00000, Pass 1 of 1 - [17:15:21] Video Encode complete - [17:15:21] Reencoding audio tracks (if req'd) - [17:16:44] Multiplexing M2TS [17:25:11]PHASE ONE complete [17:25:11]PHASE TWO - Rebuild Started - [17:25:11] Rebuilding BD file Structure [17:25:25] - Encode and Rebuild complete - WORKFILES folder removed. [17:25:25]JOB: SPINAL_TAP finished. ========================== [17:25:25] END - BATCH SEQUENCE ========================== Log # 2 needs another post because the text is too long |
23rd June 2010, 18:49 | #8630 | Link |
Log #2
[Status] LABEL=SPINAL_TAP VERSION=v0.34.02 (beta) SOURCE_SIZE=42354989928 SOURCE_VIDEO_SIZE=42012499968 TARGET_SIZE=24326963200 REDUCTION=.570888979667205 RESIZE_1080=0 AUDIO_TO_KEEP=deu;eng;fra;fre; SUBS_TO_KEEP=deu;eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=28 REBUILD_COMPLETE=1 [00064] AUDIO= PGS= M2TS_TARGET=1329358 RATE=500 NSIZE=1738752 FLINK=0 MLINK=0 [00065] AUDIO= PGS= M2TS_TARGET=1469660 NSIZE=2813952 FLINK=0 MLINK=0 [00027] AUDIO=0 PGS=01 M2TS_TARGET=27325261 RATE=6196 NSIZE=26406912 FLINK=0 MLINK=0 [00029] AUDIO=0 PGS=00 M2TS_TARGET=27435038 RATE=6361 NSIZE=26161152 FLINK=0 MLINK=0 [00028] AUDIO=1 PGS=00 M2TS_TARGET=27682031 RATE=6160 NSIZE=27488256 FLINK=0 MLINK=0 [00008] AUDIO=1 PGS=10 M2TS_TARGET=75638642 RATE=4866 NSIZE=73654272 FLINK=0 MLINK=0 [00010] AUDIO=1 PGS=10 M2TS_TARGET=81966227 RATE=5986 NSIZE=77776896 FLINK=0 MLINK=0 [00004] AUDIO=1 PGS=10 M2TS_TARGET=88506585 RATE=5698 NSIZE=84781056 FLINK=0 MLINK=0 [00025] AUDIO=1 PGS=10 M2TS_TARGET=107918818 RATE=6348 NSIZE=105627648 FLINK=0 MLINK=0 [00009] AUDIO=1 PGS=10 M2TS_TARGET=122082886 RATE=6296 NSIZE=119261184 FLINK=0 MLINK=0 [00001] AUDIO=1 PGS=10 M2TS_TARGET=133336165 RATE=6302 NSIZE=129785856 FLINK=0 MLINK=0 [00024] AUDIO=1 PGS=10 M2TS_TARGET=140612468 RATE=5697 NSIZE=136949760 FLINK=0 MLINK=0 [00012] AUDIO=1 PGS=10 M2TS_TARGET=146764820 RATE=6306 NSIZE=143118336 FLINK=0 MLINK=0 [00006] AUDIO=1 PGS=10 M2TS_TARGET=146816155 RATE=6299 NSIZE=142854144 FLINK=0 MLINK=0 [00007] AUDIO=1 PGS=10 M2TS_TARGET=159141006 RATE=6220 NSIZE=153839616 FLINK=0 MLINK=0 [00011] AUDIO=1 PGS=10 M2TS_TARGET=171259113 RATE=6312 NSIZE=163540992 FLINK=0 MLINK=0 [00005] AUDIO=1 PGS=10 M2TS_TARGET=182471572 RATE=6311 NSIZE=176824320 FLINK=0 MLINK=0 [00016] AUDIO=1 PGS=10 M2TS_TARGET=197920437 RATE=6313 NSIZE=193628160 FLINK=0 MLINK=0 [00014] AUDIO=1 PGS=10 M2TS_TARGET=202293577 RATE=5485 NSIZE=198942720 FLINK=0 MLINK=0 [00002] AUDIO=1 PGS=10 M2TS_TARGET=203024126 RATE=6317 NSIZE=197394432 FLINK=0 MLINK=0 [00003] AUDIO=1 PGS=10 M2TS_TARGET=220771333 RATE=5736 NSIZE=210898944 FLINK=0 MLINK=0 [00022] AUDIO=1 PGS=10 M2TS_TARGET=232343471 RATE=2918 NSIZE=225454080 FLINK=0 MLINK=0 [00013] AUDIO=1 PGS=10 M2TS_TARGET=301932746 RATE=6327 NSIZE=294641664 FLINK=0 MLINK=0 [00015] AUDIO=1 PGS=10 M2TS_TARGET=368885524 RATE=6330 NSIZE=367312896 FLINK=0 MLINK=0 [00030] AUDIO=1 PGS=10 M2TS_TARGET=2295418376 NSIZE=908175360 FLINK=0 MLINK=0 [00023] AUDIO=1 PGS=10 M2TS_TARGET=3305166276 RATE=6832 NSIZE=3244339200 FLINK=0 MLINK=0 [00017] AUDIO=1 PGS=10 M2TS_TARGET=3693408245 RATE=6472 NSIZE=3612887040 FLINK=0 MLINK=0 [00000] AUDIO=1111 PGS=010101010 M2TS_TARGET=12938175640 RATE=17534 NSIZE=12536893440 FLINK=0 MLINK=0 |
23rd June 2010, 22:14 | #8631 | Link | |
I believe this option will only work for BD-25 full backups though. If BD5/9 full backup is selected, the files need to be reencoded to be AVCHD compliant. Regardless, there seems to be a problem with BD-RB on some titles, though rare, and I just wanted to inform jdobbs of my experience. |
23rd June 2010, 22:39 | #8632 | Link | |
no drop frames problem, but a problem with rebuilding Sherlock Holmes
Hi, thanks for this great tool and forum!
unfortunately, when I am trying to rebuild the movie from the harddrive to BD-R size, it is stopping at the stage of VID_00178.AVS.264 this happened the 2nd time already Help is really appreciated! Alderik Quote:
24th June 2010, 04:52 | #8634 | Link |
Special SeeD
@jdobbs I tried again the Princess and the Frog with BD Rebuilder 0.34.02, video is without corruption, but now there is a pause between each m2ts change, then, in order to discard encoding/decoding bugs, I proceeded to use 45.36 GB as Output size so no re-encoding was needed, still the output has the pause problem:
----------------------- [17:04:01] BD Rebuilder v0.34.02 (beta) - Source: PRINCESSANDTHEFROG - Input BD size: 44.72 GB - Approximate total content: [03:43:39.446] - Target BD size: 45.36 GB - Windows Version: 6.1 [7600] - One Pass ABR Mode enabled - X264 Tweak(s) enabled - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [17:04:05] PHASE ONE, Encoding - [17:04:05] Extracting A/V streams [VID_00067] - [17:04:11] Reencoding: VID_00067 (1 of 132) - [17:04:11] Collecting video information - [17:04:11] Keeping original video (no reencode) - [17:04:11] Reencoding audio tracks (if req'd) - [17:04:11] Multiplexing M2TS - [17:04:17] Extracting A/V streams [VID_00100] - [17:05:03] Reencoding: VID_00100 (2 of 132) - [17:05:04] Collecting video information - [17:05:04] Keeping original video (no reencode) - [17:05:04] Reencoding audio tracks (if req'd) - [17:05:04] Multiplexing M2TS - [17:05:44] Extracting A/V streams [VID_00101] - [17:05:55] Reencoding: VID_00101 (3 of 132) - [17:05:55] Collecting video information - [17:05:55] Keeping original video (no reencode) - [17:05:55] Reencoding audio tracks (if req'd) - [17:05:55] Multiplexing M2TS - [17:06:04] Extracting A/V streams [VID_00102] - [17:06:13] Reencoding: VID_00102 (4 of 132) - [17:06:13] Collecting video information - [17:06:13] Keeping original video (no reencode) - [17:06:13] Reencoding audio tracks (if req'd) - [17:06:13] Multiplexing M2TS - [17:06:23] Extracting A/V streams [VID_00103] - [17:06:41] Reencoding: VID_00103 (5 of 132) - [17:06:41] Collecting video information - [17:06:41] Keeping original video (no reencode) - [17:06:41] Reencoding audio tracks (if req'd) - [17:06:41] Multiplexing M2TS - [17:06:58] Extracting A/V streams [VID_00104] - [17:07:13] Reencoding: VID_00104 (6 of 132) - [17:07:13] Collecting video information - [17:07:13] Keeping original video (no reencode) - [17:07:13] Reencoding audio tracks (if req'd) - [17:07:13] Multiplexing M2TS - [17:07:25] Extracting A/V streams [VID_00105] - [17:08:02] Reencoding: VID_00105 (7 of 132) - [17:08:02] Collecting video information - [17:08:02] Keeping original video (no reencode) - [17:08:02] Reencoding audio tracks (if req'd) - [17:08:02] Multiplexing M2TS - [17:08:33] Extracting A/V streams [VID_00106] - [17:09:37] Reencoding: VID_00106 (8 of 132) - [17:09:37] Collecting video information - [17:09:37] Keeping original video (no reencode) - [17:09:37] Reencoding audio tracks (if req'd) - [17:09:37] Multiplexing M2TS - [17:10:23] Extracting A/V streams [VID_00107] - [17:10:41] Reencoding: VID_00107 (9 of 132) - [17:10:41] Collecting video information - [17:10:41] Keeping original video (no reencode) - [17:10:41] Reencoding audio tracks (if req'd) - [17:10:41] Multiplexing M2TS - [17:10:54] Extracting A/V streams [VID_00108] - [17:13:24] Reencoding: VID_00108 (10 of 132) ... - [17:52:37] Extracting A/V streams [VID_00515] - [17:52:38] Reencoding: VID_00515 (110 of 132) - [17:52:38] Collecting video information - [17:52:38] Keeping original video (no reencode) - [17:52:38] Reencoding audio tracks (if req'd) - [17:52:38] Multiplexing M2TS - [17:52:39] Extracting A/V streams [VID_00516] - [17:52:40] Reencoding: VID_00516 (111 of 132) - [17:52:40] Collecting video information - [17:52:40] Keeping original video (no reencode) - [17:52:40] Reencoding audio tracks (if req'd) - [17:52:40] Multiplexing M2TS - [17:52:42] Extracting A/V streams [VID_00517] - [17:52:46] Reencoding: VID_00517 (112 of 132) - [17:52:46] Collecting video information - [17:52:46] Keeping original video (no reencode) - [17:52:46] Reencoding audio tracks (if req'd) - [17:52:46] Multiplexing M2TS - [17:52:50] Extracting A/V streams [VID_00518] - [17:52:53] Reencoding: VID_00518 (113 of 132) - [17:52:53] Collecting video information - [17:52:53] Keeping original video (no reencode) - [17:52:53] Reencoding audio tracks (if req'd) - [17:52:53] Multiplexing M2TS - [17:52:56] Extracting A/V streams [VID_00519] - [17:52:58] Reencoding: VID_00519 (114 of 132) - [17:52:58] Collecting video information - [17:52:58] Keeping original video (no reencode) - [17:52:58] Reencoding audio tracks (if req'd) - [17:52:58] Multiplexing M2TS - [17:52:59] Extracting A/V streams [VID_00520] - [17:53:00] Reencoding: VID_00520 (115 of 132) - [17:53:00] Collecting video information - [17:53:00] Keeping original video (no reencode) - [17:53:00] Reencoding audio tracks (if req'd) - [17:53:00] Multiplexing M2TS - [17:53:01] Extracting A/V streams [VID_00521] - [17:53:05] Reencoding: VID_00521 (116 of 132) - [17:53:05] Collecting video information - [17:53:05] Keeping original video (no reencode) - [17:53:05] Reencoding audio tracks (if req'd) - [17:53:05] Multiplexing M2TS - [17:53:09] Extracting A/V streams [VID_00522] - [17:53:11] Reencoding: VID_00522 (117 of 132) - [17:53:11] Collecting video information - [17:53:11] Keeping original video (no reencode) - [17:53:12] Reencoding audio tracks (if req'd) - [17:53:12] Multiplexing M2TS - [17:53:14] Extracting A/V streams [VID_00523] - [17:53:15] Reencoding: VID_00523 (118 of 132) - [17:53:15] Collecting video information - [17:53:15] Keeping original video (no reencode) - [17:53:15] Reencoding audio tracks (if req'd) - [17:53:15] Multiplexing M2TS - [17:53:16] Extracting A/V streams [VID_00524] - [17:53:18] Reencoding: VID_00524 (119 of 132) - [17:53:18] Collecting video information - [17:53:18] Keeping original video (no reencode) - [17:53:18] Reencoding audio tracks (if req'd) - [17:53:18] Multiplexing M2TS - [17:53:19] Extracting A/V streams [VID_00525] - [17:53:23] Reencoding: VID_00525 (120 of 132) - [17:53:23] Collecting video information - [17:53:23] Keeping original video (no reencode) - [17:53:23] Reencoding audio tracks (if req'd) - [17:53:23] Multiplexing M2TS - [17:53:27] Extracting A/V streams [VID_00526] - [17:53:30] Reencoding: VID_00526 (121 of 132) - [17:53:30] Collecting video information - [17:53:30] Keeping original video (no reencode) - [17:53:30] Reencoding audio tracks (if req'd) - [17:53:30] Multiplexing M2TS - [17:53:33] Extracting A/V streams [VID_00527] - [17:53:35] Reencoding: VID_00527 (122 of 132) - [17:53:35] Collecting video information - [17:53:35] Keeping original video (no reencode) - [17:53:35] Reencoding audio tracks (if req'd) - [17:53:35] Multiplexing M2TS - [17:53:36] Extracting A/V streams [VID_00528] - [17:53:37] Reencoding: VID_00528 (123 of 132) - [17:53:37] Collecting video information - [17:53:37] Keeping original video (no reencode) - [17:53:37] Reencoding audio tracks (if req'd) - [17:53:37] Multiplexing M2TS - [17:53:38] Extracting A/V streams [VID_00529] - [17:53:42] Reencoding: VID_00529 (124 of 132) - [17:53:42] Collecting video information - [17:53:43] Keeping original video (no reencode) - [17:53:43] Reencoding audio tracks (if req'd) - [17:53:43] Multiplexing M2TS - [17:53:46] Extracting A/V streams [VID_00530] - [17:53:49] Reencoding: VID_00530 (125 of 132) - [17:53:49] Collecting video information - [17:53:49] Keeping original video (no reencode) - [17:53:49] Reencoding audio tracks (if req'd) - [17:53:49] Multiplexing M2TS - [17:53:52] Extracting A/V streams [VID_00531] - [17:54:00] Reencoding: VID_00531 (126 of 132) - [17:54:00] Collecting video information - [17:54:01] Keeping original video (no reencode) - [17:54:01] Reencoding audio tracks (if req'd) - [17:54:01] Multiplexing M2TS - [17:54:08] Extracting A/V streams [VID_00532] - [17:54:19] Reencoding: VID_00532 (127 of 132) - [17:54:19] Collecting video information - [17:54:19] Keeping original video (no reencode) - [17:54:19] Reencoding audio tracks (if req'd) - [17:54:19] Multiplexing M2TS - [17:54:27] Extracting A/V streams [VID_00533] - [17:54:36] Reencoding: VID_00533 (128 of 132) - [17:54:36] Collecting video information - [17:54:36] Keeping original video (no reencode) - [17:54:36] Reencoding audio tracks (if req'd) - [17:54:36] Multiplexing M2TS - [17:54:43] Extracting A/V streams [VID_00534] - [17:54:52] Reencoding: VID_00534 (129 of 132) - [17:54:52] Collecting video information - [17:54:52] Keeping original video (no reencode) - [17:54:52] Reencoding audio tracks (if req'd) - [17:54:52] Multiplexing M2TS - [17:55:00] Extracting A/V streams [VID_00535] - [17:55:07] Reencoding: VID_00535 (130 of 132) - [17:55:07] Collecting video information - [17:55:07] Keeping original video (no reencode) - [17:55:07] Reencoding audio tracks (if req'd) - [17:55:07] Multiplexing M2TS - [17:55:14] Extracting A/V streams [VID_00536] - [17:55:21] Reencoding: VID_00536 (131 of 132) - [17:55:21] Collecting video information - [17:55:21] Keeping original video (no reencode) - [17:55:21] Reencoding audio tracks (if req'd) - [17:55:21] Multiplexing M2TS - [17:55:28] Extracting A/V streams [VID_00537] - [17:55:31] Reencoding: VID_00537 (132 of 132) - [17:55:31] Collecting video information - [17:55:31] Keeping original video (no reencode) - [17:55:31] Reencoding audio tracks (if req'd) - [17:55:31] Multiplexing M2TS [17:55:34]PHASE ONE complete [17:55:34]PHASE TWO - Rebuild Started - [17:55:34] Rebuilding BD file Structure [17:56:27] - Encode and Rebuild complete [17:56:27]JOB: PRINCESSANDTHEFROG finished. Code:
[Options] RESIZE=0 MODE=0 ENCODE_QUALITY=0 PRIORITY_CLASS=1 TARGET_SIZE=46450 VERBOSE_STATUS=1 AUDIO_TO_KEEP=all SUBS_TO_KEEP=all TRELLIS=1 KEEP_INTERLACING=1 COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 DISABLE_FFMS=0 FIXED_CRF=20 SECONDARY_CRF=20 SHOW_ENCODER=1 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=46450 PROCESS_SECONDARY=0 QUICK_EXTRAS=0 CRF_ENCODING=1 TWEAK_PASS_ONE=--deblock -2:-1 --aq-strength 0.8 --psy-rd 0.80:0 TWEAK_PASS_TWO=--deblock -2:-1 --aq-strength 0.8 --psy-rd 0.80:0 SECONDARY_USE_QUALITY=1 SD_CONVERT=0 B_PYRAMID=1 ONEPASS_ENCODING=2 FULL_AVCHD=0 AUTO_QUALITY=0 DEINTERLACE=0 AC3_192=0 REMOVE_OUTPUT=0 [Paths] SOURCE_PATH=J:\BLU-RAYS\PRINCESSANDTHEFROG\ WORKING_PATH=D:\TEMP\MOVTEMP\D2VAVS\ |
24th June 2010, 14:42 | #8636 | Link | |
24th June 2010, 19:54 | #8637 | Link | |
DVD Magistrate
I am having a vc-1 encode problem. Note however that I can play vc-1 mkvs fine. The error is that "the filter graph manager will not talk to me" No sure how to proceed. Tried all the different versions of Haali I could fine. Here is log:
24th June 2010, 20:24 | #8638 | Link | |
I am seeing an identical problem with VC-1 video main title (Star Trek IV movie). The Haali filter doesn't extract a thumb for the m2ts file. MPC isn't able to play the file. The file is definitely intact (as for example Nero Showtime will play it fine)... Thanks Bob |
