Old 28th November 2010, 22:52   #4941  |  Link
bur
as reported by madVR in "movie resolution"
Where do I get that information? I checked in the tray icon and the MadVR settings but found nothing.
bur is offline   Reply With Quote
Old 28th November 2010, 23:20   #4942  |  Link
TheElix
Will madVR ever by able to take screenshots somehow?
TheElix is offline   Reply With Quote
Old 28th November 2010, 23:36   #4943  |  Link
Trigunflame
Trigunflame's Avatar
Alt+PrintScreen = Your Friend.
Trigunflame is offline   Reply With Quote
Old 28th November 2010, 23:37   #4944  |  Link
adam777
Both taken from CTRL+J
adam777 is offline   Reply With Quote
Old 29th November 2010, 21:10   #4945  |  Link
TheElix
I get black screen with Alt+PrintScreen. With PrintScreen only I get a screenshot with windowed MPC-HC and task bar.
And even if it worked, what do you suggest? Pasting it in Paint and saving each and every screenshot, giving it a unique name and delaying the watch?
Old 29th November 2010, 21:19   #4946  |  Link
dansrfe
he suggests it because there is simply no other alternative. you could try an easier method of capturing maybe using FastStone Capture (which is what I use) since it can predefine windowed areas and autosave. until madshi adds capture support this is a perfectly fine alternative.
Old 29th November 2010, 22:21   #4947  |  Link
janos666
You should disable the FS exclusive mode when you want to use the PrintScreen.
Did you try FRAPS? It should work on D3D surfaces as well.
janos666 is offline   Reply With Quote
Old 30th November 2010, 09:51   #4948  |  Link
Peekstra
When I use tvlevels in madVR I get grey blacks although I would not expect this to happen with my configuration: beamer set to HDMI range normal (not expanded), MPC-HC render settings set to use tv levels, decoder (if setting available) configured to use tvlevels.
When I configure madVR to use PC levels the grey's become black again... is this correct?
Configuration: Windows 7 x86, Nvidia GT220, beamer connected as monitor 2 on extended desktop.
Peekstra is offline   Reply With Quote
Old 30th November 2010, 09:54   #4949  |  Link
namaiki
With the PC levels setting, madVR expands from TV levels to PC, so that is correct.
My TV automatically expands TV levels to PC, so I use the TV levels setting so that it is not expanded by madVR.
namaiki is offline   Reply With Quote
Old 30th November 2010, 10:02   #4950  |  Link
Peekstra
But my whole setup is set to use tv levels so no expansion should be needed?
Old 30th November 2010, 10:04   #4951  |  Link
namaiki
Your graphics card seems to be outputting PC levels, so you must expand from TV to PC to get black.
Old 30th November 2010, 10:13   #4952  |  Link
Peekstra
But when I use EVR instead of madVR, MPC-HC's tvlevels are used and the blacks are correct.
Old 30th November 2010, 10:21   #4953  |  Link
namaiki
If you mean 0-255 is selected for output range (in MPC-HC renderer options which only applies to EVR-CP and possibly EVR Sync and VMR9(renderless)), then that means it's being expanded.
Old 30th November 2010, 12:10   #4954  |  Link
Peekstra
No, I use the 16-235 output range (TV levels) with EVR-CP to get correct blacks. So it's strange that I need to use 0-255 levels in madVR when I leave all the other settings alone.
Old 30th November 2010, 12:23   #4955  |  Link
namaiki
What happens if you change EVR-CP to 0-255? (on my PC with Intel graphics, regardless of option selected, levels are always expanded)
Also, might you happen to be using CoreAVC? (make sure that input and output are both set to TV levels, and none on "Auto detect")
Old 30th November 2010, 12:36   #4956  |  Link
Thunderbolt8
how does it look when using other renderes, other than EVR and madVR? maybe EVR is wrong here?
and does this behaviour actually change when using 3dlut files for TV and PC levels?
Old 30th November 2010, 13:27   #4957  |  Link
Peekstra
I'll try the 0-255 setting, but it should give wrong levels when the beamer is set to HDMI range normal instead of expanded, right?
I hope to be able to do some testing on both suggestions later this week.
Old 1st December 2010, 16:17   #4958  |  Link
leeperry
Kid for Today
I can also easily get 0.32 to freeze when looping an A/B section in exclusive mode w/ PotPlayer...but it never freezes w/ the debug version
After +10 loops, it freezes at the end of the loop and I have to kill PotPlayer from the task manager.
This could be due to a bug in PotP, I'll run more tests on my previously problematic files: http://www.sat-universe.com/showpost...0&postcount=45
Fixed a problem where AB repeat display incorrectly
Old 1st December 2010, 22:01   #4959  |  Link
Mark_A_W
3 eyed CRT supporter
Please be aware that madshi has (correctly) labelled the levels controls in reverse to everyone else.
I want my levels unmolested (no expansion, black at 16), so in madVR I pick "TV".
However if ffdshow was doing the conversion to RGB I would pick "PC Levels" in ffdshow.
Just pick the one that gives you the correct result and check for banding using a smooth ramp pattern.
Mark_A_W is offline   Reply With Quote
Old 2nd December 2010, 01:53   #4960  |  Link
Gser
The expansion is quite nice actually but only if you have a high contrast monitor and no backlight bleeding like me. Twas horrible on my old monitor.
Gser is offline   Reply With Quote
