19th April 2012, 12:08 | #1185 | Link |
Hi there,
Excuse me if my question seems stupid, but I'm wondering : Which sharpening filter is used by QTGMC to post-process the deinterlaced video ? And by the way, is it possible to use that sharpner without the deinterlacer ? NB. I'm asking this because I'm actually trying the PureVideo built-in deinterlacer and it seems good for the speed it gives, but the only problem is that the video it generates is not as sharp as that generated by QTGMC.
MhX Digital - An Old Fan Of x264 |
19th April 2012, 13:36 | #1186 | Link |
The sharpening method is "temporal limited contra-sharpening". (Well, usually. You can opt to use a purely spatial variant, but that one is substantially "less good" in the given context.)
The method could be extracted into a stand-alone, that's perfectly possible. But it wouldn't make too much sense to use it in conjunction with another (fast) deinterlacer. For the given sharpening method, one full circle of motion-search and motion-compensation must be done via MVTools, plus the temporal limiting in itself. Read: if you would have it as a stand-alone, then it would be rather slow. You would lose most of the "speed benefit" of PureVideo, the result would be similarly-slow as QTGMC is anyway. On top of that, if you sharpen the PureVideo Deinterlacer in the same way as QTGMC does, then the ("per-pixel") deficits of PureVideo would become more pronounced.
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) Last edited by Didée; 19th April 2012 at 14:16. Reason: You don't "loose", but "lose" something. |
19th April 2012, 14:13 | #1187 | Link | |
26th April 2012, 07:18 | #1192 | Link |
Hi All!
-Vit- I hope You help me. How organize denoising clip using QTGMC? sigma for fft3d and dfttest have different scale, especially for last version dfttest. When I am using dfttest in my script i use value near 100 for my source (VHS Rip). When I use inside QTGMC I see less removing noise. My script for denoising Code:
SetmtMode(3,4) AVISource("tape1.avi").Trim(0,129057) AssumeTFF() GetChannel(1) SetmtMode(2,4) source=ConvertToYV12(interlaced=true).Crop(16,12,-16,-12) bob=source.nnedi3(field=-2,threads=1).nnedi3_rpow2(2,nsize=4,cshift="Spline36Resize",fwidth=720,fheight=576,threads=1) super = bob.MSuper(pel=2, sharp=1) backward_vec2 = MAnalyse(super, isb = true, delta = 4, blksize=16, overlap=8, chroma=false) backward_vec1 = MAnalyse(super, isb = true, delta = 2, blksize=16, overlap=8, chroma=false) forward_vec1 = MAnalyse(super, isb = false, delta = 2, blksize=16, overlap=8, chroma=false) forward_vec2 = MAnalyse(super, isb = false, delta = 4, blksize=16, overlap=8, chroma=false) bc2 = bob.MCompensate(super, backward_vec2) bc1 = bob.MCompensate(super, backward_vec1) fc1 = bob.MCompensate(super, forward_vec1) fc2 = bob.MCompensate(super, forward_vec2) Interleave(bc2,bc1,bob,fc1,fc2) dfttest(sigma=100.0,tbsize=5,sbsize=16,sosize=12,threads=1) Edibob=SelectEvery(5,2) Edibob.SeparateFields().SelectEvery(4,0,3).Weave().AssumeTFF() DelayAudio(-0.04) I am try by self but inside a lot of parameters. yup. |
26th April 2012, 13:42 | #1193 | Link |
QTGMC isn't supposed to be a replacement for custom denoising. I only added the feature because it was easy after adding noise bypass.
In any case it can't do such a large temporal radius. This is possibly the closest: Code:
# EZDenoise = dfttest sigma / 4, or ffttest sigma unchanged QTGMC(Preset="Whatever", EZDenoise=25.0, Denoiser="dfttest", ChromaNoise=true, DenoiseMC=true, NoiseTR=2) Last edited by -Vit-; 26th April 2012 at 13:47. |
3rd May 2012, 22:44 | #1195 | Link |
-Vit- and Didée, can i ask you something?
I'm using qtmc, create the script but i getting this error; Code:
SeparateFields: YV12 height must be multiple of 4 (QTMC-3.32.avsi,line 355) (video.avs, line 27) |
3rd May 2012, 23:16 | #1196 | Link |
Crop or resize your source so its height is divisible by 4.
Groucho's Avisynth Stuff |
4th May 2012, 00:55 | #1197 | Link |
You advise to resize an interlaced source!
No problem, but to prevent hell breaking loose, let's also state how to resize properly in this case: Code:
ww=width() hh=height() pointresize(ww,hh+hh%8, 0,0,ww,hh+hh%8) QTGMC(...) crop(0,0,ww,hh)
4th May 2012, 07:13 | #1198 | Link | |
..... ww=1280 hh=694 pointresize(ww,hh+hh%8, 0,0,ww,hh+hh%8) a= last b=a.QTGMC("Slower", SourceMatch=2, Lossless=2, EZKeepGrain=1, Sharpness=1) crop(0,0,1280,694) ..... Thank you for support. @Groucho2004 thank you for helpful answer. |
4th May 2012, 07:48 | #1199 | Link |
That's not correct. Your video can't be 1280*720 (can it?), because that video size never should be interlaced. For other sizes, you don't get the right framing.
Use it like was posted. Code:
XXXsource("...") ww=width() hh=height() pointresize(ww,hh+hh%8, 0,0,ww,hh+hh%8) QTGMC("Slower", SourceMatch=2, Lossless=2, EZKeepGrain=1, Sharpness=1) crop(0,0,ww,hh) # If you need additional cropping a/o resizing, do it _below_this_line_
4th May 2012, 08:15 | #1200 | Link | |
